K-5 Sensor Staining Issue
Started Dec 22, 2010 | Discussions
bbfolgart New Member • Posts: 20
I have been looking for a DSLR for some time now and the review of the K-5 and spending some time with it at my local camera store has almost convinced me to purchase it. However on other forums they are discussing a sensor staining issue with some K-5 batches. Apparently it is not the sensor itself but the glass that is over the sensor.
My questions are:
1. Is it limited to batches or more widespread? Are certain geographic areas more affected than others? A lot of owners in Spain are reporting this issue. I am in Canada.
2. Is there any way you can tell if the camera is affected by examining it prior to purchase? Is there something I should be looking for to see if it is affected?
Thanks in advance.
jeanphilippe Goube Senior Member • Posts: 1,927
Re: K-5 Sensor Staining Issue
Hi,
looks like the issue is under control now; recent purchases (serial numbers > = 39xxxx) seem not affected; I myself have had to exchange my K5 cause of this stain issue; anyway if you can try the K5 before buying it the test process is quite simple
regards
jpgoube
 jeanphilippe Goube's gear list:jeanphilippe Goube's gear list
Nikon AF-S Nikkor 800mm f/5.6E FL ED VR Nikon AF-S Nikkor 400mm f/2.8E FL ED VR Pentax Q Nikon D500 Nikon D850 +13 more
aplucini Senior Member • Posts: 1,896
I bought my K-5 a month ago and it is free of stains so I think all the cameras affected are no longer in the retail system. I think your chances of getting a stained sensor now are pretty slim.
Allan in Colorado, USA
 aplucini's gear list:aplucini's gear list
Pentax K-x Canon EOS 60D Pentax K-5 Canon EOS 6D Pentax K-3 +16 more
OP bbfolgart New Member • Posts: 20
Thanks.
Can this be visually checked before purchase? Will it show up on test shots? Don't know what I am looking for.
Peter Budd
Peter Budd Senior Member • Posts: 1,175
Yes - just take a shot of white paper or the sky ( blue sky is best but cloudy works ok ) Take it at F22 or higher
Zoom in and scroll around - any stains / marks should be fairly easy to spot.
Peter
GMT
 Peter Budd's gear list:Peter Budd's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +7 more
badabus New Member • Posts: 12
I don't know in which part of Canada you live but if you buy from a renowned shop (as I did), they will test it before you buy. In my case, I had bought on the internet from a store in Toronto. The sensor was indeed affected so I returned it and the tested the new one before sending it back to me.
solarider Veteran Member • Posts: 4,843
If you get a new camera there shouldn't be any issues -pentax produces in small batches and can easily respond to needed attention.
Probably more than a few people returned the camera for no other than poor reasoning without really knowing what to look for or could tell the difference to sensor dust. At least run the sensor cleaning function a half dozen times before testing to minimize dust issues.
If other readers are reading this thread and is a newbie, get some help through the camera dept at your store. or find a camera that matches your experience and abilities. If one doesn't know what to look for, then maybe there is nothing to worry about it
bbfolgart wrote:
Thanks.
“At any given moment, there is a sort of all pervading orthodoxy, a general tacit
agreement not to discuss large and uncomfortable facts… Anyone who
challenges the prevailing orthodoxy finds himself silenced with surprising
effectiveness.” - George Orwell
