Post your serial number (Dust stains - affected K5)
Started Dec 7, 2010 | Discussions
pentx4life Contributing Member • Posts: 603
pscl57 Forum Member • Posts: 59
Re: Post your serial number (Dust stains - affected K5)
38322.. two small stains near the center. I will send it for service after the holidays.
http://www.flickr.com/photos/pscl57/
 pscl57's gear list:pscl57's gear list
Nikon D610
zakaria
zakaria Veteran Member • Posts: 6,058
3830796
3 big stains right side and things like watter drops in centre.
my PPG
http://www.pentaxphotogallery.com/zakariamohie
my flickr
http://www.flickr.com/photos/kimkoy/
k5/k200/d300s
 zakaria's gear list:zakaria's gear list
Pentax K-1 II Fujifilm X-H1 Nikon D780 Fujifilm X-T3 HD Pentax DA 15mm F4 ED AL Limited +8 more
gillbod Senior Member • Posts: 1,598
all 383xxxx or 384xxxx so far (nt)
no text
Gerry Winterbourne Forum Pro • Posts: 19,063
3831999 (n/t)
Gerry
First camera 1953, first Pentax 1983, first DSLR 2006
DaleDrechsler Contributing Member • Posts: 710
Re: 3831999 (n/t)
Looks like unfortunately I'm also in the club:
3842386
Dale
Frederick J Stewart Regular Member • Posts: 242
3836425
Becomes barely visible at F13,one obvious small spot in the middle.
Sophie Wilson Senior Member • Posts: 1,785
3865xxx
http://forums.dpreview.com/forums/read.asp?forum=1036&message=37111698 for details.
Quite a long trail, nearly horizontal.
Sophie
 Sophie Wilson's gear list:Sophie Wilson's gear list
Sony RX100 II Panasonic ZS200 Nikon D7200 Nikon D850 Nikon Z7 +35 more
Jimmy DL Contributing Member • Posts: 509
3849902
One long streak of stains on mine. Visible from f22 to f10.
Jimmy ;DL
More images
http://www.dovholt.com (focus on street photography)
http://www.onexposure.net/?member=2594&jimmy-dovholt
http://www.flickr.com/photos/dovholt/
 Jimmy DL's gear list:Jimmy DL's gear list
Ricoh GR Digital III Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18mm F2 R
MightyMike Forum Pro • Posts: 41,273
3820585
there is no pattern as 3820670 doesn't have a stain
Mike from Canada
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
awaldram
awaldram Forum Pro • Posts: 13,271
3828646
does
Which makes sense if its sub assembly issue rather than camera assembly.
Mike from Canada
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax Q7 Pentax K-x Olympus PEN E-PM2 +17 more
Re: 3831999 (n/t) Ref to other thread
I've just posted this on Dale's other thread
http://forums.dpreview.com/forums/read.asp?forum=1036&message=37133284
Gerry
Ronald E. Chambers
Ronald E. Chambers Senior Member • Posts: 1,249
3823937 NO Thank the LORD!!!
RON C
 Ronald E. Chambers's gear list:Ronald E. Chambers's gear list
Pentax smc FA 50mm F1.4 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Pentax K-1 II Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +4 more
thxbb12 Senior Member • Posts: 2,202
3839304176534: no stains :)
I checked at f/32 on a fully white background.. no stains visible, yay!
 thxbb12's gear list:thxbb12's gear list
Panasonic Lumix DMC-GM5 Fujifilm X-T20 Fujifilm X-S10 Fujifilm XF 14mm F2.8 R Fujifilm XF 56mm F1.2 R +6 more
Re: 3839304176534: no stains :)
It seems to be numbers like 382xxxx 383xxxxx and 384xxxxxx
Nikon D610
dlacoutu Contributing Member • Posts: 811
38259xx : YES
Nice string of pearls, nearly dead center...
(but fortunately no dust after 1 1/2 months of use and frequent lens changes)
 dlacoutu's gear list:dlacoutu's gear list
Pentax K-5 Samsung NX100 Samsung NX200 Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc FA 50mm F1.4 +6 more
zardos123
zardos123 Forum Member • Posts: 94
two small stains appear f10 and on in upper right corner #3913xxx crk in oz said to send in for cleaning, would not concede that any other problem is likely
 zardos123's gear list:zardos123's gear list
Pentax K-5 Pentax K-3 Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM
Two Hands Junior Member • Posts: 49
Sadly my k5 has them too, but only visible when cranking up the levels at f22 and up.
Serial 38274xx
docdave37 Forum Member • Posts: 82
Yes, I just found stains while shooting at f22.
My serial number is: 3890279
I sent it back to Amazon along with a description of the problem.
I miss the camera and plan to buy it again once the issue is cleared up.
DAVE
 docdave37's gear list:docdave37's gear list
Ricoh GR III Leica SL2 Sony FE 55mm F1.8 Leica APO-Summicron-SL 35mm F2 ASPH Leica SL 24-90mm F2.8-4
Peter Budd
Peter Budd Senior Member • Posts: 1,226
3822xxx: no stains :)
Peter
GMT
 Peter Budd's gear list:Peter Budd's gear list
Olympus E-M1 III Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-100mm F4.0 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +7 more
