DPP - Focus distance information
Started Dec 5, 2010 | Discussions
Mjollnir Regular Member • Posts: 380
In DPP, you can bring up a box with information about the images from the camera, such as the name of the lens and focal length, etc.
But I can't see any line that tells you how far away you were from the point of focus. Is there any reason for this? I would have thought there would be some way to calculate this based upon the lens's focus settings.
Is there any way to calculate it yourself with the information available from Canon RAW files?
canuck dave
canuck dave Veteran Member • Posts: 3,038
Re: DPP - Focus distance information
Does any software do that?
Olga Johnson Forum Pro • Posts: 24,360
Some software does report distance, such as Breezebrowser.
As to Canon, I found a comment made by Chuck Westfall here, scroll down a bit to see the message.
http://www.openphotographyforums.com/forums/archive/index.php/t-210.html
Olga
guinness2
guinness2 Veteran Member • Posts: 4,457
Hi , it depends on the lens too, for example my 17-85IS should give it contrary to others.
Honestly, mostly this info is not visible. I really miss it.
The most EXIF would give Exifer free SW, if it still exists.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
guinness2
Hi Olga, pls don't take me wrong, but his comment is 4 years old
Canon EOS Rebel SL3
guinness2
So I tried the example I gave, did found Exifer on cached server, installed in WindowsXP mode and used 17-85IS picture. There is lot of info given, but focusing distance unknown
Focus distance [m]: unknown (2)
P.S. Neither DPP nor DxO got it.
Canon EOS Rebel SL3
You are correct...
However, there was a time when Canon did include distance info and then they stopped it (and it could have been 4-5 years ago). If I remember correctly, the distance provided was not always reliable. When they stopped providing it, Breezebrowser wasn't showing it either. I think Chris Breeze had discussed that but I cannot find his comment about it. Then Chris started adding it to BB, but not for all cameras. Sorry. Wish my memory was better than all this vague stuff.
Basically what I'm trying to say is that I believe Chuck's statements are still valid today.
Olga
imqqmi Veteran Member • Posts: 8,632
DPP doesn't seem to support it. The only tool I know that works is ExifTool (command line) and ExifToolGui. Recently, I've noticed pbase does show the distance to my pictures and the distances seem pretty accurate. The pictures were post processed using lightroom 3 and have been tweaked in photoshop cs2 and exported using export-> jpg.
Click on full exif:
10-22mm
http://www.pbase.com/imqqmi/image/130747609
100-400L
http://www.pbase.com/imqqmi/image/130838677
sigma 18-50mm f/2.8
http://www.pbase.com/imqqmi/image/128461671
85mm f/1.8
http://www.pbase.com/imqqmi/image/128461729
24-70mm f/2.8
http://www.pbase.com/imqqmi/image/126191984
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
ironic Regular Member • Posts: 176
My zenfolio account shows focus distance also, and it seems accurate.
http://ironic.zenfolio.com/p350851998
guinness2
Re: You are correct...
Olga Johnson wrote:
I have too strange feeling, that I saw once the distance info when on 17-85, but no way to remember when and how
Doesn't E-TTL II use it ?
I will try to search my thread from the past. My long-term memory is much better than the short-term one
Canon EOS Rebel SL3
hbx2004 Veteran Member • Posts: 3,162
Hi,
All current Canon dslr cameras support "distance" info. Why I quoted distance here? Because this value is never exact distance value (because camera isn't distance metering device).
Camera only need "good enough" distance information to determine exposure parameters when flash is used.
Distance info is comming from lens and depends on focus barrel/ring position. Inside lens, there are physical contacts, which read position/rotation of focus barrel. Resulting value is sent to camera (which, of course make use of this value) and is also written into image metadata (Makernote section).
In case of Canon, there isn't single distance value, but two of them: Focus distance lower value and Focus distance upper value. If image is in focus, then actual distance is allways between lower and upper value.
Scale of reported lower/upper distance values given by lens isn't linear. Reason is simple: flash need more precise values in cases when subject is closer. Let's take EF-S 17-55 f/2.8 as example. This lens can report 28 different distance value pairs, starting at 0.33m. The distance sequence is:
Low. Upper
0.33 0.34
0.34 0.41
0.41 0.44
0.44 0.47
0.47 0.49
0.49 0.52
6.43 12.33
12.33 136.23
81.91 655.35
-as you can see, closer distances are more densed (more precise) as far distances.
Of course, some other lens can have more (or less) distance value pairs.
Some software packages (LR, for example) show single distance value (which should give impression of "exact" value). What they basically do is:
(Low+Upp) / 2 = distance
-this is "precise" enough for distances up to (let's say) 3 meters, but missleading for bigger distances. Assuming you use above lens and subject is at distance of 15 m:
(12.33+136.23) / 2= 74.28 m!
-which is totally wrong.
DPP doesn't show distance values -anyway, DPP does make use of it for Lens Correction option.
Thanks for reading,
Bogdan
azakeyh Regular Member • Posts: 206
Hello,
I use Bridge with PS CS 5 of Adobe.
I can see the distance from the subject only when shot Raw.
az03
 azakeyh's gear list:azakeyh's gear list
Sony RX100 Canon EOS 550D Canon EOS 5D Mark III Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM +5 more
PhilPreston3072 Senior Member • Posts: 2,636
DPP can give you rough guide of the focus position, not focus distance in the "Lens Aberration Correction" tool under the NR/Lens/ALO tab if you've shot in RAW. You can see whether the focus was closer to infinity or closer to the minimum focus distance with the shooting distance slider.
I think one of the difficulties with embedding shooting distance information is that some zoom lenses aren't parfocal, meaning that the focus is not constant across the zoom range. But I'm sure shooting distance can be calculated given the info from the exif.
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
Himanshu Gaurav Regular Member • Posts: 473
Wow what a reply
..I don't know where u got all that data from but I am really impressed !!
guinness2
Re: DPP - Focus distance information... to hbx2004
Hi Bogdan,
an impressive info.
Where exactly do you see fucusing distance in LR3 ?
I tried all presets for metadata in library and still don't see it.
Canon EOS Rebel SL3
Boardhead Senior Member • Posts: 1,122
An excellent post, Bogan. Thanks!
I can vouch for this. I did similar tests with my Canon 300D and came to similar conclusions.
Focus distance info in LR..
Hi,
guinness2 wrote:
...Where exactly do you see fucusing distance in LR3 ?
Some LR users have reported they can "get" focus distance info in LR. I don't use LR on regular basis, so I'm no expert on it's usage -there might be some plug-ins, though.
Anyway, in LR, if you export metadata to XMP file, there you can see
ApproximateFocusDistance value.
Bogdan
Thank you, Phil...
Hi Phil,
Compliments written by you, have special weight for me. Thank you.
Actually I have been waiting before posting, because of my limited english grammar. At the end, I'm happy I could contribute something usefull
Greetings,
Bogdan
guinness2
Re: Focus distance info in LR..thanks
hbx2004 wrote:
Hi,
Bogdan
Canon EOS Rebel SL3
