Respectfully, I don't believe that this is true. I believe the lens goes to "near infinity" when powering on.Just in case you don't know, to set the 20mm lens to hyperfocal position just set focus mode tu manual, then switch the camera off and on again. This will put the 20mm in its hyperfocal position. I'd set it to f/4 at least to have a depth of field that goes from infinity to say 2 meters from you.
Did you mean to write "smaller apertures" (or perhaps "larger f-numbers")?Of course, "near infinity" is pretty close to the hyperfocal, for larger apertures.
Not really. When the aperture is large (small f-number), the hyperfocal is close to "near infinity".Did you mean to write "smaller apertures" (or perhaps "larger f-numbers")?Of course, "near infinity" is pretty close to the hyperfocal, for larger apertures.
That's what I meant, being a little approximate. Thank you for the clarification Fredrik!Respectfully, I don't believe that this is true. I believe the lens goes to "near infinity" when powering on.Just in case you don't know, to set the 20mm lens to hyperfocal position just set focus mode tu manual, then switch the camera off and on again. This will put the 20mm in its hyperfocal position. I'd set it to f/4 at least to have a depth of field that goes from infinity to say 2 meters from you.
As far as I know, there is no detailed information about the focus distance being communicated between the lens and camera in the 4/3 or m4/3 system. If this was communicated, there would be a requirement for expensive and complicated focus distance calibration of the lenses, which is outside of the scope for this price range.
Of course, "near infinity" is pretty close to the hyperfocal, for larger apertures. So keeping the lens in manual focus mode and not touching the focus ring will be a pretty good solution when stopping down a bit and not photographing close objects.
Ah, I had somehow misinterpreted what you wrote to mean that the close-to-infinity was just "near enough" if the lens is well stopped down, but of course that wasn't at all what you meant. Having re-read it (and your reply) I see you were exactly correct.Not really. When the aperture is large (small f-number), the hyperfocal is close to "near infinity".Did you mean to write "smaller apertures" (or perhaps "larger f-numbers")?Of course, "near infinity" is pretty close to the hyperfocal, for larger apertures.
On the other hand, as you stop the aperture down (larger f-numbers), the hyperfocal creeps downwards, away from infinity, smaller focus distance numbers.
So approximating the hyperfocal with infinity only works for larger apertures (small f-number), as I tried to explain.
