Wireless radio trigger for NEX!!
Started Oct 2, 2010 | Discussions
Gregory Kemp Contributing Member • Posts: 668
I have been trying to find a reliable way to trigger external flashes with the NEX, particularly so I can use my infrared converted NEX with flash. This way seems to work quite well, I am able to reliably trigger 3 flashes that I use for shooting in my small lightbox. I have tested shutter speeds from 1/5 - 1/160 and got good results.
Here you see a wireless radio flash trigger taped to the NEX on-board flash and attached to a cheap optical slave flash trigger. I then cover this assembly with a small bag made for my lensbaby so it does not leak any light when triggering the external flashes:
Just to show the NEX triggering its own flash for this shot - the flashes from above and the side were triggered by the NEX's onboard flash, not by the camera that took this picture:
Here is a quick test shot with the NEX-5 triggering 3 flashes - 1 above in a softbox (Canon 430EZ), 1 on the right through an umbrella (Minolta 5600HS) and 1 on the left through umbrella (Minolta 5400HS). Just to prove its possible to trigger flashes with the NEX (I had been having trouble getting it to trigger an optical slave, but with the radio popper trick it works much better).
Here ithe radio trigger I used:
http://www.amazon.com/CowboyStudio-NPT-04-Wireless-Receiver-cowboystudio/dp/B002W3IXZW/ref=sr_1_1?ie=UTF8&qid=1286043360&sr=8-1
And here is the optical trigger:
http://www.dealextreme.com/details.dx/sku.8291
I am still hoping for Sony to give us real options for controlling flashes, but this will do the trick for now.
PS, I actually do clean things before I take pictures of them, but no matter what theres still dust and particles on things I take pics of.
Greg
http://www.flickr.com/photos/gkemp/
James M Hilliard Regular Member • Posts: 472
Re: Wireless radio trigger for NEX!!
novak977 Senior Member • Posts: 1,400
Hi Greg,
great post,
I did almost identical thing, few months back!
http://forums.dpreview.com/forums/read.asp?forum=1042&message=35949509
novak
http://www.supernovak.com
http://www.flickr.com/photos/rogic
FED-S (my father's) > Canon AE1 (my brother's) > Minolta Maxxum 3xi (my first precious) > Minolta Dynax 400si (hello Canada) > Minolta Dimage 7i (darling) > Konica Minolta 5D (first DSLR) > Sony Alpha A100 (killer baby) > Sony Alpha A700 (serious tool) > Canon 5DMkII (weird computer with average lenses) > Back to A700 (reassured about the greatness) + A900 (depth of colours and pixels)
 novak977's gear list:novak977's gear list
Sony a6000 Sony RX1 Sony Alpha NEX-3N Sony a7 II Sony E 30mm F3.5 Macro +10 more
OP Gregory Kemp Contributing Member • Posts: 668
Oh nice! I thought I'd thunk this one up first...oh well. I have been searching high and low, on this forum and google, bing etc looking for flash trigger options for the NEX, then thought I would give this a try. Cant believe I missed your post...
Greg
Kiril Karaatanasov Senior Member • Posts: 2,129
Does not NEX have pre-flash?
I see a lot of discussion on the DX page about using the optical trigger with digital cameras featuring P-TTL type of metering.
 Kiril Karaatanasov's gear list:Kiril Karaatanasov's gear list
Sony a6300 Sony a7R III
i haven't paid attention - this system works nice and syncs no prob up to 1/200s - it probably don't then?
Grant Senior Member • Posts: 1,976
Thanks so much Geregory. Great idea and inexpensive. Thanks for the links also.
Grant
 Grant's gear list:Grant's gear list
Canon EOS 5D Mark II Sony Alpha NEX-5N Canon EOS 5D Mark IV Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM +14 more
leebog New Member • Posts: 16
Ive seen that in my quest to find a real flash solution for the NEX. They just want to lure in naive Sony NEX and DSLR owners, look at the pics, its just a standard hot shoe foot to attach it to the camera.
rurouni Regular Member • Posts: 427
That's a really innovative approach to going wireless Nice post!
Instead of the gaffer tape, have you tried velcro? It may make dissaembly easier for ya. Just wondering, what sort of sync speed did you manage to get out of this combi? Any chance its around 1/250 or faster?
seachicken2000
seachicken2000 Veteran Member • Posts: 3,237
Should be up to 1/160 second. That's what I get at least.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony a7R +21 more
narci Regular Member • Posts: 178
Hmmm....how about using a a really right stuff flash bracket like this in conjunction with the wireless trigger set up?
http://reallyrightstuff.com/flash/03.html
Sure that would work if you want to drop $350 on that bracket... For what I need its not what I am looking for, I just want to control my flashes mounted on stands.
Arek S Junior Member • Posts: 45
Hi All,
How it is possible it working with preflashes? Does this preflashes does not fire up wireless flashess?
Best wishes
ArekS
 Arek S's gear list:Arek S's gear list
Nikon D4 Nikon Z6 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.8G +5 more
toomanycanons Forum Pro • Posts: 12,955
Pretty slick "solution". I've got a NEX-3 coming in next week and have been researching how to hook up one of my Yongnuo wireless transmitters. I pictured there being some manner of cable that would slip into the accessory port and end in a hotshoe that I could put my transmitter on. It didn't need to look elegant, it just needed to work.
Of course, of course, just tape an optical trigger with transmitter attached to the NEX's puny flash! This is a controlled flash scenario solution (other Yongnuo receivers with strobes, on light stands) and that's really all I was looking for.
Or, not having the optical trigger firing strobes on light stands but, indeed, a strobe with Yongnuo receiver on it just handheld over the NEX, like I do all the time to point my strobe in multiple directions. It would help to have a third hand.
Still, it'd be nice to have that cable I talked about so I wouldn't have to mount the puny flash at all.
bluescoprio23 New Member • Posts: 3
How is it that the TTL Pre-flash not triggering the optical trigger??
I bought the same setup but it is not working................flash firing too early with the TTL pre flash.
nemo107 New Member • Posts: 3
brilliant
scotbot Senior Member • Posts: 1,196
Hi, all the information I can find says that that optical slave reacts to the pre-flash and a number of people have queried this also... Does your NEX somehow not fire a pre-flash?
http://www.scottwylie.co.uk
 scotbot's gear list:scotbot's gear list
Sony a6300 Sony E 50mm F1.8 OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS
David Nall
David Nall Forum Pro • Posts: 16,017
Can you relay the settings you used on your NEX5 to trigger the flash? Thanks, Dave
Visit my gallery at http://www.poperotzy.smugmug.com
 David Nall's gear list:David Nall's gear list
Sony Alpha NEX-7 Nikon D4 Nikon D800E Nikon 1 V2 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +11 more
OWHK Forum Member • Posts: 57
Hi All,
This idea is great, but using a 'passive' slave flash trigger may not work well for other camera pre-flash sequences. I did a project years ago on a digital slave flash trigger and now I am building it again wirelessly.
I am fitting the PCB into a cheap remote control case and powered the circuit with a 23A 12V battery. I use a high-speed, low-power 8-bit microprocessor to do the job. So far it supports 3 different types of cheap wireless slave flash receivers and has 4 programmable pre-flash modes to due with different pre-flash sequences, I am also planning to add an ‘auto-learn’ mode later. The highest synchronize speed for NEX is 1/160 and for LX3 is 1/2000s.
So far it not only works with my NEX5, it also works for almost every DC and D-SLR cameras I owned under all flash modes conditions; including a700, KMD5D, LX3, F30, Canon 300D …
I am working on the second PCB layout and finalizing the firmware programming now. Hoping that the search for a workable wireless slave flash trigger solution to handle the ‘pre-flash’ will be over soon.
Wireless remote trigger mounted on NEX's flash
Supporting 3 different types of receivers
A) Yongnuo YN-04 II
B) PT-04 (brand ?)
C) JYC (model number ?)
Triggered by NEX5 at 1/160s
Triggered by LX3 at 1/2000s !
