K5 raw is 14 bit
Started Sep 20, 2010 | Discussions
Ronald E. Chambers
Ronald E. Chambers Senior Member • Posts: 1,249
K5 raw is 14 bit
The K5 raw output is 14 bits as compared to the 12 of the K7. Seems like the DR should be improved some with this.
RON C
 Ronald E. Chambers's gear list:Ronald E. Chambers's gear list
Pentax smc FA 50mm F1.4 Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) Pentax K-1 II Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro +4 more
saghost Senior Member • Posts: 1,520
Re: K5 raw is 14 bit
RON C
Maybe... but in and of itself, that doesn't matter.
There's some number of photons the well can hold, and there's a limit that gets lost in read noise/shot noise/etc. This is the "analog" dynamic range of the photosite.
When I do my analog to digital conversion, I chop that up into a bunch of different levels, and assign the resulting photon count (charge of the photosite) to one of those bins.
Going from 12 to 14 bits just means I have 4 times as many bins that are 1/4 the size (for a given sensor) - it doesn't mean that the analog range of the sensor got larger.
With 14 bits, I can assign an intensity much more precisely within my range, but my range of sensitivity may or may not have changed.
Having said that, one of the reasons a company might choose to go to 14 bits is a larger analog range. (another is marketing, yet another is the IC package provided on the chip...)
Walter
Ronald E. Chambers
OP Ronald E. Chambers Senior Member • Posts: 1,249
I agree but Sony sensors have been much better that the Samsung ones as far as DR. Look at the KX. I'll bet there is more output for K5.
RON C
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
see GordonBGood comment
http://forums.dpreview.com/forums/readflat.asp?forum=1036&message=36380071
"...Eric, I don't really know if these specifications are derived from real ones or not and how many errors there might be if they are, but I really hope that the new camera does not have 14 bit raw or if it does offer it, it offers the option to turn it off as Nikon cameras that offer it do. From measurements on the 16.2 MP sensor of the Sony A55, the minimum noise (the black read noise) at the lowest ISO is still likely just about a half of a 12-bit level, but even if one wanted/needed to capture the very widest in Dynamic Ranges at lowest ISO, that would mean that all files where that (DR) was not available (as in high ISO ones) or necessary would grow by an unnecessary over four MBytes, which would put average compressed raw file sizes up into the 25 MBytes per image region. ..."
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
Russ Houston
Russ Houston Veteran Member • Posts: 6,377
The K10D was 14bit raw, IIRC. However, Pentax went back to 12bit raw for the K20D and K7. Don't know why.
Russ
http://www.flickr.com/photos/rfortson/
http://www.pentaxphotogallery.com/russfortson
Even bad photography can be fun
 Russ Houston's gear list:Russ Houston's gear list
Olympus OM-D E-M5 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +7 more
rhlpetrus Forum Pro • Posts: 26,210
BITs and DR are different things
RON C
DR is distance from ground noise to photosite saturation. Number of bits is how you split that range for each channel. having more bits only helps if DR is wide enough, otjerwise it's just a waste of banwidth and memory space.
From D90 and D300s comparison at DxO Mark it seems that for APS-C sensors, no extra DR is gained, maybe just some extra tone gradation.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
etoastw Regular Member • Posts: 432
K10D was 12 bit as well -- Pentax claimed the processing was 22-bit or something like that, but that didn't seem to have much of an impact on anything.
 etoastw's gear list:etoastw's gear list
Panasonic Lumix DMC-LX7 Fujifilm X100T Pentax K-5 II Pentax smc DA 12-24mm F4.0 ED AL (IF) Pentax smc DA 21mm F3.2 AL Limited +10 more
exdeejjjaaaa
your memory fails you, K10D was 12bit
jeffkrol Veteran Member • Posts: 6,225
not necessarily true... k10, at the time, had the largest DR by RAW analysis.. problem was banding w/ some sensors and it was nosier at higher iso's....
Anyways.. go to bottom.. at iso 100 K10 had excellent DR
http://daystarvisions.com/Docs/Rvws/K20D/pg3.html
As a side note Pentax software outputs fake 16bit TIFFS (actually 8) so some is lost anyways.....
360 minutes from the prime meridian. (-5375min, 3.55sec) 1093' above sea level.
'The exposure meter is calibrated to some clearly defined standards and the user needs to adjust his working method and his subject matter to these values. It does not help to suppose all kinds of assumptions that do not exist.'
Erwin Puts
Richard Murdey
Richard Murdey Veteran Member • Posts: 3,000
As others already pointed out, the sensor characteristics are not improved. 14 bit gives you is some additional precision that is most noticeable on flat, gradually changing tones like a blue sky. In the RAW data at least, there are now many more shades of blue.
The K10D was 12bit with 22bit processing. Although the RAW data has only 12bit colors, the JPEG processing pipeline took those numbers and converted them to 22bit (adding zeroes) before working on them mathematically produce the image. So rounding errors from bit truncation were avoided.
12-14bit RAW data is pretty subtle difference. 22bit vs. 12bit processing engine is even more subtle.
Worth remembering that any output you are likely to be looking at is no better than 8bit, it all gets downsampled in the end.
 Richard Murdey's gear list:Richard Murdey's gear list
Nikon D750 Carl Zeiss Distagon T* 2,8/21 Carl Zeiss Distagon T* 2,8/25 Carl Zeiss Distagon T* 2/35 Carl Zeiss Planar T* 1,4/50 +12 more
PhotoHawk Contributing Member • Posts: 846
This reference might make things a bit clearer for you. 14 bits do matter on larger pixel cameras. The use of high quality amplifiers also matters. Have a look at the section on DR particularly the graph and its explanation at 5a.
See
http://www.clarkvision.com/imagedetail/digital.sensor.performance.summary/index.html
That the 300s is not better than the D90 is proof that Nikon cut some corners somewhere, not that the theory is faulty.
John Cafarella Contributing Member • Posts: 986
Re: BITs and DR are different things
Considering the impact that going to 14 bit has made on the depth of the buffer, I would hope that there is in fact some increase in DR.
Engineering is all about selecting the best compromise to match your product requirement. It would make no sense to reduce the number of frames that the buffer is capable of without actually gaining some performance in another area.
John Cafarella
Melbourne, Australia
MightyMike Forum Pro • Posts: 40,886
don't forget money as an area
Mike from Canada
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
exdeejjjaaaa
JPG image is created by a raw converter in camera's firmware from already existing (in K10D's case) 12bit raw file w/o any involvement of 22bit ADC in that (.JPG image creation) matter.
Russ Houston
That's right. Thanks for the clarification.
Russ
GordonBGood Veteran Member • Posts: 6,311
Ron and Walter, yes, there is a limit to the number of electrons the photosite "well" can hold, which from the Sony A55 that likely uses the same Sony sensor, is about 16,000 electrons at ISO 200 clipping limit, which is not much different than the older 12 MP sensor of the K-x on a per photosite basis ; however, the K-5 has an extra about 35% photosites in about the same sensor area. This affects the apparent noise vs. detail as to highlight detail graduations in the bright image tones at 100% zoom views due to "shot noise", which is the "physics" noise that arises from the statistical variation in the arrival of a finite number of photons. "Shot noise" affects dark shadow detail very little as the limit of this noise is zero when there are zero photons at absolute dark. The limit on the maximum number of photons captured per photosite at the clipping level affects the maximum ISO sensitivity gain that can be used for full size 100% zoom viewing as to the bright tones in that when there are less than about 400 electrons in the well, as would happen at about ISO 80,000 with this sensor, either one must reduce the detail level with Noise Reduction (NR) or reduce the maximum viewing size or increase viewing distance in order for the images to appear of acceptable quality.
As to the dark shadow detail limit, that is placed by the black read noise, which I can see from raws available from the Sony A55 are at about the same level as that of the K-x. Thus, I expect that the real Dynamic Range (DR) for the sensor from the brightest clipping level to the "noise floor" limit will be about the same as that of the K-x or about 12.5 stops at lowest ISO.
Even if the raw black read noise was incredibly low at lowest ISO at about 1/8192 of the bright clipping level (13 stops of DR), even a signal at 10 stops down with a full well capacity 32,000 electrons at 10 stops below the bright clipping limit would have "shot noise" of about 1/5657 for a combined noise of 1/4655, meaning that all those extra "graduations" would have an almost imperceptible effect as they would just be "buried in the noise", with even more "shot noise" at brighter levels. The intensities that are being assigned with the extra bit depth is really just better defining the noise levels.
MightyMike suggested another alternative that might just make sense: Previous Pentax cameras have been criticized at DPR for not having as much raw "highlight headroom" as competing models. What if the extra two bits were at the top bright end of the range and extended the raw format's capacity to capture normally overexposed highlights without clipping, where they could be recovered by judicious application of tone curves and other raw processing? Would that not make the camera score very highly? Another benefit of doing this is that compressed raw file sizes would not likely increase that much in that these top levels would only generally be used by the small percentage of bright normally overexposed specular highlights, whereas using them as the least significant bits just generally captures high levels of random noise which is hard to compress and would make the files about four MBytes larger on average.
Another possibility is that it is further confusion on Pentax's marketing department in that the raw readings may be delivered as 14 bits but reduced to 12 bits for raw image file output just as the K20D, K200D, K-m/K2000D, and K-7 did.
In short from the above, it is very unlikely that 14 bits used other than as MightyMike suggested in extending the clipping limit would give any larger a real analogue range.
Yes, many companies (especially Canon) have gone to 14 bits for largely marketing reasons, and I sincerely hope that Pentax is not one of them, although I could accept using 14 bits to extend the highlight capture/roll-off range as described above.
If we are to believe the specifications we have been given, I doubt that the limit is the imaging engine used as it seems it is still Prime II just as for the K-7, K-x, and K-r, all of which use 12 bit processing although there is a 14 bit Analogue to Digital Converter (ADC) available. Although from the Pentax record for this K-5's release, that possibly should have read PRIME III!
Regards, GordonBGood
Richard, even with the very best sensor with the lowest black read noise coupled with a zero noise conversion, the only place one would actually be able to see the difference due to very high bit depths would be in the very deep deep shadows. For instance, if we had a large sensor with an electron well depth of 100,000 electrons per photosite and a dark read noise of two electrons, we would have a Dynamic Range (DR) of 50,000 : 1 and could justify even a 16-bit conversion. However, we would only enjoy that low noise up to where the shot noise was very low, so that by the time the Signal to Noise Ratio (SNR) got up to about 4,000 : 1 at the 625 electron level or 7.3 stops below the full clipping level, the "shot noise" would be large enough to completely limit the use of that greater bit depth. Blue sky is much brighter than this, and only a few stops below the clipping level for normal exposures, and 14 bits would not make one little bit of difference in the amount of noise in these blue skies, as all of those extra fine shades will just be blurred together by the noise even if we were actually able to pick them out.
However, those eight non-linear bits are quite a bit different than the 12 or 14 linear bits in the raw image file, as the Tone Response Curve (TRC) applied in the conversion to viewable eight bit images actually compresses the bright levels and expands the dark levels in a way that more-or-less matches our human eye's (and monitor's) response to luminance levels in that we aren't actually able to perceive all of the 256 levels given by eight bits when our eyes are fully adjusted to the full range from full bright to maximum dark , as we can only actually perceive about 100 discrete steps between those levels.
Generally, we need at least about at least 10 "good" linear raw bits in order to convert to a normal eight bit JPEG with reasonable image quality.
See
No, the 14 bits don't really matter for any current camera, even the Canon 1D Mark IV and the Canon 5D Mark II, as those high 15 stop Dynamic Range (DR) figures are only extrapolations for the actual sensor dark read noise taken from the high ISO response; at low ISO's these Canon models have too much dark read noise injected by their conversion electronics to allow such high DR results.
No, the reason that the Nikon D300s is not better at DR than the Nikon D90 even though the D300s can capture 14 bit raw image files is that the sensor dark read noise is not smaller than the least significant bits of a 12-bit range at the ISO sensitivity gain levels used for the D300 and D300s. To further confuse the issue, the D90 (and D5000) use some "sneaky" form of chroma Noise Reduction (NR) to make the noise appear to be lower even though this is at the cost of slightly reducing detail retention, especially in the deep shadows.
John, that's the $100 question, why is the specified buffer depth so much less, especially if it turns out not to be a misprint in the specification?
I can't see that Pentax would actually reduce the size in MBytes of the buffer between the K-7 and the new top level K-5, although they may not have been able to increase the amount of buffer memory due to not redesigning the circuit boards to any large amount and not wanting to reduce battery life. Let's say that the K-7 had about 256 MBytes of buffer, which makes sense at about five frames per second (fps) in that about three frames would be flushed to flash memory in the about three seconds of continuous shooting time, which would then require space for about 14 raw files in the buffer or about 18.3 MBytes per raw file, which is just about what they are for the K-7 at low ISO and moderate detail level .
My theory about why the eight raw buffer limit exists (also with an accordingly low JPEG buffer limit) at maximum continuous rate is Pentax's typical conservative specification policy and the existence of these extremely high maximum ISO's in extended ISO mode . To me, it makes sense that the actual raw buffer limit is just proportionally less than that of the K-7 considering the larger pixel dimensions and the faster continuous shooting speed, such that 15 raw captures would seem to be about right for exactly the same shooting environment and ISO sensitivity settings . However, there very well might be only eight raw captures possible for worst case raw files sizes where the maximum raw file size at ISO 51,200 could be as large as 35 MBytes or so.
Thus, there is no discrepancy between the performance of the K-7 and this new K-5, and only confusion about the conditions under which that limit applies .
Kikool Contributing Member • Posts: 601
Many thanks for your explanations
Sorry, my question might appear as trivial, but as my english skills are limited.
So, just to be sure to understand, do you think that the K-5 might be able to shoot about 14-15 raw files in a row under "ideal" shooting conditions, but be limited to 8 files at high ISOs when the files would be at their max. size ?
Thanks a lot
BR
 Kikool's gear list:Kikool's gear list
Pentax K-7 Pentax K-5 Pentax K-1 +1 more
