is there any EF to A mount adapter?
Started Sep 19, 2010 | Discussions
3systermuser Contributing Member • Posts: 972
if you know any please recommend me one.
I want to share some of my EF lenses with my A900 and 5D2.
derek.
Mike K Veteran Member • Posts: 5,525
Re: is there any EF to A mount adapter?
The EF mount (sensor to outer flange) is among the longest in the 35mm SLR industry. Thus you can use this longer mount distance for the depth of an adapter to mount other lenses to Canon, but Canon lenses cannot be mounted to other camera bodies. For example Nikon lenses can be mounted on a Canon body, but not the other way around. More choices for Canon owners.
Also for this reason, there are very few lenses (medium format) capable of being adapted to Sony alpha.
http://www.novoflex.com/index.php
http://www.cameraquest.com/adaptnew.htm
Mike K
 Mike K's gear list:Mike K's gear list
Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS D60 Canon EOS 6D Canon EF 135mm F2L USM +9 more
Rock and Rollei Senior Member • Posts: 2,087
Er, shortest, rather than longest - it's the shortness that allows adaptors to fit between the camera and lenses designed with a longer flange focal distance. It's a large part of the reason why there's no adaptor, the rest being the slightly awkward nature of matching electrical contacts.
Mike K
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS M Canon EOS 6D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS M5 +37 more
