3D pictures with NEX5 + Sigma 105/2.8 macro
Started Sep 7, 2010 | Discussions
Knallberto Veteran Member • Posts: 5,478
14x 3D pictures (MPO) with NEX5 and Sigma 105/2.8 macro (Canon mount)
StereoPhotoMaker writes "Finepix Real3D W1" into EXIF ... bad, bad ...
http://www.megaupload.com/?d=2GV03PU5
3dreal Senior Member • Posts: 2,271
Re: 3D pictures with NEX5 + Sigma 105/2.8 macro
magnificent 3ds.
Did you use a slider?
Can you pls give us a bit more technical details also about the light.
3dsweep is not suitable for such work, if then only with nex-lenses.
could you pls explain how you managed to produce mpo-files? 3dsweep does only work with nex-lenses, sony told.
OP Knallberto Veteran Member • Posts: 5,478
(free) StereoPhotoMaker makes it all
For lightning normal bulb/flourescent was used. Also a slider - you get for few dollars (ebay.com) - macro rail.
i knew this already. people from germany, austria and switzerland pls go to stereoforum.org where are multiple and deep discussions all around 3dstereo-in german only. its owner/administrator is 3dstereo-video/photo-pro.
And he is also co-author/translator of Stereophotomaker-german version and Stereodatamaker.
bongo Senior Member • Posts: 1,675
How do you view these photos in 3d??
more bONGO at
http://www.thebongolian.com
http://www.bongolia.com
 bongo's gear list:bongo's gear list
Leica X Vario
