sample pics of new 85M lens
Started Aug 31, 2010 | Discussions
asproductions Junior Member • Posts: 41
just received the new 85mm lens.
test pics attached.
First impressions
great lens, but the lens hood does not fit as tight onto the body as i would have though.
All Pics taken are at F1.4 with no PP done.
coudet Veteran Member • Posts: 4,141
Re: sample pics of new 85M lens
More samples, please.
test pics attached.
First impressions
Leos Senior Member • Posts: 2,077
Can you make some shots in more challeging condition so we can see the quality of the bokeh ? Like wide open, medium distance to subject and foilage in background (not too close) with highlights. Thanks. I am very excited.
rareshb Regular Member • Posts: 179
It's obvious those pictures are fake. It says right there they were taken on Jan 1, 1970 at 02:00:00. However, we demand MOAR !
test pics attached.
First impressions
Andre De Angelis Senior Member • Posts: 2,191
The lens is already in stores and selling. No reason these images shuold be fake.
It was meant as a joke. The date and time from the EXIF said 1st January, 1970, which is the default UNIX time ( http://en.wikipedia.org/wiki/Unix_time ).
Sorry, my bad. I realized you were joking after posting.
OP asproductions Junior Member • Posts: 41
pics are not fake.
my first pic posting.
How do you correct the time stamop?
The pics where taking with a D2x in manual mode, Auto ISO Auto with no PP in failing light here in Sydney.
I guess you have to find the menu, in camera, to set the time and date.
RodluvanII
RodluvanII Senior Member • Posts: 2,096
For the love of good take some decent snaps!
Do a few portrait, use it like it's intended to be used (not close ups of boxes and an overexposed dog).
Please.
(it's like it's always the gear-heads who buys the lens first, never the photographers)
Sorry if I'm harsh, but it's honestly frustrating to see almost every single time.
 RodluvanII's gear list:RodluvanII's gear list
Nikon D3X Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Nikkor 180mm f/2.8D ED-IF Leica Summarit-M 50mm f/2.5 +11 more
Nikon_Kyo Regular Member • Posts: 380
Thanks for posting the pictures. Looking forward for your next set of pictures.
 Nikon_Kyo's gear list:Nikon_Kyo's gear list
Nikon D800 Nikon D810 Nikon Z7 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 20mm f/2.8D +20 more
Moonwalker Senior Member • Posts: 2,121
new 85M lens
Bokeh is looking good in your samples. Thanks for sharing.
Looking forward to my AF-S 85mm f/1.4G.
Markus
Vphotographic Regular Member • Posts: 286
Re: new 85M lens
Think ill stick with my D version thanks anyway.
Seems to work just fine, bad examples but shows bokeh
f1.4
f8
f11
Regards
Paul Marshall
http://www.vphotographic.co.uk
ericfordh Senior Member • Posts: 1,419
This is one of Nikon's most obnoxious ongoing blunders. On my 24G the hood is constantly shifting so that its shadow is visible at the edge of the frame. I wish they would take a note from Zeiss and make hoods that properly snap into place and stay there.
So the lens is already out in Australia/NZ... hope it hits the USA on schedule.
VividExposures Contributing Member • Posts: 989
Lens hood
When I bought a 50 1.8, it didn't come with a lens hood. I bought a 52mm screw in version made of rubber. I like it very much, and have been using it on a 35mm 1.8 as well. Perhaps something similar could be used for the 24 and 85?
http://www.amazon.com/amp-77mm-Rubber-Lens-Hood/dp/B0012FLFHO/ref=sr_1_3?ie=UTF8&s=electronics&qid=1283264798&sr=8-3
Re: Lens hood
I had a rubber hood for one of my lenses once. They work fine, but I don't like screw-in hoods of any kind, if I can avoid them.
Ray Soares Veteran Member • Posts: 3,121
Thanks for sharing...
Looking VERY good by the way...
It seems IMHO, a perfect bokeh, same kind or a bit better than my 85 D
Best
Ray Soares
See my pictures at http://www.pbase.com/raysoares
 Ray Soares's gear list:Ray Soares's gear list
Nikon D7000 Nikon D4 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm F1.4G +1 more
brightcolours Forum Pro • Posts: 15,885
Rubber hoods
Lens (sun) hoods are good protection for the lens against bumps into hard things. But not when they are rubber.
You can't really use a rubber hood for a 24mm, as that lens is so wide it will need a petal design hood.
SuisseNikon Regular Member • Posts: 478
protective filter for this lens?
what protective filter if any do you guys use on your 85 f/1.4D and/or plan on using on the 85 f/1.4G?
 SuisseNikon's gear list:SuisseNikon's gear list
Nikon D700 Nikon D7000 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 85mm F1.4G +2 more
Re: protective filter for this lens?
Well, first to make clear, I do not have any 85mm f1.4.
I do not use ANY protective filter on my lenses, because they are useless.
What do you want to protect against? Falling? A filter will not protect a falling lens. Finger smudges? You have to clean a filter too, so why not just clean the lens.
Filters can have adverse effects on resolution, on contrast and can give ghost lights in night scenes.
Use a hood for protection (and lens cap when not shooting), and only use a "protective filter" when it makes sense (like sand blowing around on the beach).
And get a good quality lens brush to clean dust and particles off, and a good lens cleaning fluid and microfiber lens cloth to clean front (and back) elements.
