S95 minor construction changes
Started Aug 19, 2010 | Discussions
sneakerpimp
sneakerpimp Senior Member • Posts: 1,089
1. 2 strap holes to wear camera horizontally.
2. heavy knurling on mode dial.
3. revised top and bottom caps, shiny finish--metal?
4. much reduced thumb grip (due to 'non-slip' paint finish).
5. more conventional shutter button.
6. slightly thinner and lighter.
with the exeption of #5 i really would have liked to have all of these in the S90.
 sneakerpimp's gear list:sneakerpimp's gear list
Canon PowerShot S90 Canon PowerShot G7 X Canon EOS M
Sun_Zeneise Regular Member • Posts: 131
Re: S95 minor construction changes
The body of the Canon S95 is quite similar to that of its predecessor, although it's a fraction of a millimeter less tall and deep, and a few grams heavier . The front panel has some added texture, but otherwise you'd be hard put to tell the cameras apart without seeing the model number.
Source: http://www.imaging-resource.com/PRODS/PS95/PS95A.HTM
SHood Veteran Member • Posts: 4,973
The reduced thumb grip is a big negative for me. I don't see how that can be a positive.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Olympus E-M1 II Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko 300mm F4 IS Pro
sneakerpimp
OP sneakerpimp Senior Member • Posts: 1,089
my sources show the contrary:
http://dpreview.com/news/1008/10081918canonpowershots95.asp
http://www.dpreview.com/reviews/specs/Canon/canon_s90.asp
macshark Senior Member • Posts: 2,848
Any changes to the rear control wheel?
Like click-lock operation like the front control wheel?
Stephenbw
Stephenbw Senior Member • Posts: 2,515
The Canon website shows the S95 to be 5 grams lighter than the S90.
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/index.aspx#
Stephen
 Stephenbw's gear list:Stephenbw's gear list
Fujifilm FinePix X100 Ricoh GR Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Samyang 8mm F2.8 UMC Fisheye +5 more
sneakerpimp
the new finish makes the grip less of a necessity. smaller equals thinner.
sneakerpimp
Re: Any changes to the rear control wheel?
yes but that and the other obvious/big changes are already in discussion. i'm just trying to cover the little things here.
PaulRivers Veteran Member • Posts: 7,420
Ditto. It wasn't terribly ergonomic to begin with, the thumb grip was it's one ergonomic point. I can't see what advantage we would possibly gain by not having it - it's just empty space where it used to be.
If they wanted to save weight, take off the min-hmdi connector. I've never used it. Sure, someone or other has probably used it, but they should be able to do that via the usb port with a special cable, without adding weight to the s95.
ajmiarka
ajmiarka Regular Member • Posts: 112
Are the two holes on top the stereo microphone?
Fhoton Regular Member • Posts: 103
Look like strap holes to me
ajmiarka
So where are the mics then? They aren't on the front.
(unknown member) Forum Pro • Posts: 14,097
Someone in another thread mentioned that there is what appears to be a button by the flash on the top left of the camera. They guessed that it was to manually pop-up the flash. If this is so, it's a much welcome improvement.
Ed_arizona Senior Member • Posts: 1,751
is just a strap hole, would rather pop up button for flash too
Ed in Arizona
'Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.' - Albert Einstein
 Ed_arizona's gear list:Ed_arizona's gear list
Fujifilm X70 Fujifilm X-E3 Rokinon 12mm F2.0 NCS CS Fujifilm XF 23mm F2 R WR
sneakerpimp
an improvement indeed.
trevmar Senior Member • Posts: 2,469
I don't think it is a button, I think it is the top of the strap-fixing hole, isn't it?
RKral Regular Member • Posts: 392
Just by looking at it and the hole on the other side it is clearly the STRAP HOLE. (1 of 2, one on each side, it's obvious to me).
I didn't notice the one on the right. You're probably right. Darn. S100, maybe?
ajmiarka
I see they are strap holes now... sorry.
Two mics are under the lens
snapshot09 Veteran Member • Posts: 4,512
Re: S100?
Have to agree, with the S95 just being announced now, it could have been so much more...guess we have to wait for the S100 for at least another year.
Still don't get "much reduced thumb grip (due to 'non-slip' paint finish)."
