Best affordable f1.4 lens?
Started Aug 13, 2010 | Discussions
peppermonkey Veteran Member • Posts: 4,709
Re: Super-Tak 50/1.4
Must concur. The Super Takumar's are wonderful lenses.
Love my Super Takumar 55mm M42 f1.8 lens
mh2000 wrote:
I got mine for about $30 off ebay, beautiful lens. FD 50/1.8 is pretty good for cheap too.
Hubert
My cameras: GF1, TZ3, recently fixed (I think) Minolta Hi-Matic 7s, broken Konica Auto S2(couldn't fix, who the heck GLUES screws in??), K1000 and my wife's old K110D
http://www.flickr.com/photos/peppermonkey/
 peppermonkey's gear list:peppermonkey's gear list
Panasonic Lumix DMC-TZ3 Sigma DP2 Sony RX100 II Pentax K110D Panasonic Lumix DMC-GF1 +11 more
zxaar Veteran Member • Posts: 4,154
Re: Ther are many comparable choices
peppermonkey wrote:
The Pentax SMC-M 50mm F2 is a decent lens. Well built.
Go to http://www dot pentaxforums.com and you can see reviews for it.
i spend lot of time there at that forum.
If you notice on this page
http://www . pentaxforums.com/lensreviews/category-SMC-Pentax-M-Lenses.html
people rate it 7.79 out of ten , all the other 50s are scored above 9.
Some of the comments from that review page about 50mm F2
http://www . pentaxforums.com/lensreviews/SMC-Pentax-M-50mm-F2-Lens.html
Cons: Poor performance wide open and doesn't pick up until stopped down to at least f/5.6. Double ugly bokeh.
Cons: could be sharper.
Cons: It's pretty soft when wide open.
Cons: Nowhere close to the 50mm f1.4 in quality
Cons: sharpness wide open, there are faster alternatives
Cons: Slightly soft at widest aperture. This makes it great for soft focus portraits.
Cons: Soft, hard to get focus
Cons: Slightly soft wide open, coating shows the mark of time
Cons: soft at wide aperture
Cons: Soft wide open
Cons: Not too sharp
Cons: My copy is quite soft wide open
Cons: unacceptable near edges unless stopped down a lot
Cons: very soft at f2 and quite soft from 2.8 until f5.6 (camera jpeg) , manual focus can be a problem for a few
Cons: soft at f2
So you see it is hard to call this lense a decent lense when every second person list its wide open performance as CON.
It is dirt cheap but i would avoid it even if someone gave me for free.
It may not compare with others but considering it's dirt cheap (you can find mint ones separately for
That said, SMC-M 50mm f1.4 or f1.7 and the Super Takumar M42 55mm f1.8 are much much better. Course they are also multiples of times more expensive (though still cheap).
zxaar wrote:
fermy wrote:
Canon FD 1.4 and 1.8 are good lenses. Minolta MDs 1.4 and 1.7 are exactly on the same level. Yashica ML 1.7 is a very good lens, my copy is actually very slightly better than Minolta 1.7 and FD 1.8, but very slightly worse than FD and MD 1.4. I assume that ML 1.4 should also be great.
The difference in sharpness between all of these is negligible in practice. It seems that it's impossible to buy a bad 50mm lens. I have 7 of them (including a Minolta macro and Canon FL 1.8) from 3 different manufacturers and all of them are very closely matched, with minor variations in contrast at large apertures. The biggest difference by far is color rendition.
The only bad 50 i can think of is pentax 50mm f2 . It has got bad rep.
::> I make spelling mistakes. May Dog forgive me for this.
Hubert
Umm...you do need to put it into perspective. It's a kit lens. A cheap kit lens even then. And taking that into account, it's a decent lens. Not great but not bad either.
It's no where near as good as the other 50mm or 55mm lenses but then again, the others are really good lenses. If it was a bad lens the review score would reflect that. I got some great photos from it though it's now replaced by my Super Tak 55mm 1.8. Anyone should be able to get some good photos from it. Besides, being a bit soft wide open isn't the most unheard of problem.
Hubert
