S90 Lens Cleaning
Started Jul 10, 2010 | Discussions
Regan Cheng New Member • Posts: 3
S90 Lens Cleaning
Hi. Lately went on a hike in Yosemite and there was quite a bit of mist from the waterfalls. Anyways, my lens got a little wet and now has some spots. What is the best way to clean this streak free without damaging the lens?
Thanks,
Jack West Senior Member • Posts: 1,144
Re: S90 Lens Cleaning
i'm not sure what everyone else is doing but heres what i do: i first always use a rocket blower to get out the big rocks & dead birds.- then a drop of lens cleaning fluid on a lens tissue or micro fiber cloth and wipe in small circles fairly softly & quickly as you don't want the lens to retract while your doing this. on my dslr there's a way to lock the camera for cleaning but i don't know of this feature in a p&s camera. a lighted magnifying glass is very handy too.
CeeDave
CeeDave Senior Member • Posts: 1,275
You can just turn it on and then remove the battery.
Chris in Red Stick
Esmail New Member • Posts: 24
Hi all,
I'd like to revive this short threat about the best way to clean the lens of the S90.
I have a small, what appears to be, waterspot that won't go away with the "air poofer" or the use of a lens pen (from my astronomy days).
What is the recommended way to deal with this?
Thanks,
Esmail
ps: of course another issue is how to make sure the lens does not retract while you are trying to clean it - but as suggested removing the battery might do the trick.
the battery removal trick works great i found out. for a stubborn water spot i would go to the local camera store and get some lens cleaning fluid - then use only lens tissue or micro cloth to gently rub in small circles. this is all after using the air blaster of coarse.
