Setting LX3 Custom Modes
JMcCarthy
Member
Chicago area, US
The instructions for Registering Personal Menu Settings (Registering custom settings) on page 60 in the Panasonic LX3 Operating Manual are confusing and possibly incorrect. Here's the sequence that works for me:
(1) In the Picture-Taking Mode, turn the dial to C1 or C2 and press the Menu button. If you chose C1, go immediately to Step (2).
If you chose C2 (for C2-1, C2-2, or C2-3,), choose one of the three extra modes, then back out of that menu page.
(2) In both the Record (red camera) and Setup (wrench) menus, enter custom settings desired for C1 or the C2 sub-mode chosen.
An aside -- A custom mode is very helpful if you often work with a difficult light source (low Kelvin incandescent, discharge lamps, some fluorescents, etc.), consider manually setting the white balance (Pages 79-80 in the Manual) even though LX3 cameras purchased since late 2009 operate quite well in Auto White Balance. The instructions suggest using a white sheet of paper, although an 18%-gray card or similar neutral-gray surface might be better.
(3) Press the Menu button and set the flash by first raising the flash head, pressing the Flash button at the right of the Menu button, and choosing the flash mode. (Force Flash seems to give the best results for me.)
(3) Press the Menu button again, go to the "Setup Menu" (the wrench), go to the "Cust.Set Mem." heading (top of the 2nd page), and select the custom mode being registered. Then push the Menu button and enter "Yes."
(4) Back out of "Cust.Set Mem.," move up to Record (red camera), and turn the camera dial to the default position "P."
(5) Shut down and restart the camera, turn the dial to the just registered C1 or C2 (C2 requires choosing the sub-mode and pressing the Menu button) and check that the registration (including the flash setting with head raised) has been retained correctly in the camera's memory.
It's really easy. Select the custom mode you desire from the dial. make the required changes to the setting you would like as default then go back in the menu and save it over the very same custom setting. done.
If you are starting from scratch then you can choose either A or T mode and then go to menu and save to desired custom dial number. Then go to the custom mode you have just saved and further tweak the settings. done.
I change and tweak mine most times I'm out.
You are terrible confused about this. Keep trying to get it right.
You can use P mode or any other, not C1, C2 at first. Then use Menu> Standard, Natural, etc. then set the Contrast, Sharpness, Saturation and NR in it and click the Menu button and go to the Setup mode whenever you are sure you have all things, such as EC and all set. In Setup go to the Custom Settings and on C1 click to set it and whatever mode you started in will have those settings. Do this for each mode you wish to have new settings in.
Custom mode has nothing to do with AWB, set that in Quick Menu.
After you set your Customs as desired you don't have to turn the camera off.
That's really the hard way to do things....
The proper way is to have the mode dial where you want, say P mode or M mode. Set up the camera in the way you normally would use it, then go to the menu to store that setting in any of C1 to C2-3.
Using the C1 to C2-3 modes seems to be the only way to use one film choice for stills and a different film choice for video.
Not really checked but I thought that any time you used the flash then the flash white balance is used and over-rides anything else you set.
I always use auto white balance for everything and fine tune later in post process, since V2.0 the auto white balance improved dramatically for weird indoor lighting.
(3) etc etc
Seems a lot of hard work to do a simple job.
Regards.......... Guy
LX3 info.... http://homepages.ihug.com.au/~parsog/panasonic/01-intro.html
