canon s90 macro
Started May 23, 2010 | Discussions
Henry A Greenblatt Regular Member • Posts: 190
canon s90 macro
Having great difficulty getting sharply focused photos in macro. Any general advice for camera settings to achieve this? For example does Aperture Priority vs P vs Shutter priority matter when using the macro setting for sharpness? Camera is stabilized on a fixed object or tripod so that can be taken out of the equation. I've not had difficulty getting good macro shots with my other cameras so I assume I'm setting something less-than-optimally.
thanks in advance,
Hank
slackjawgaze1 Junior Member • Posts: 37
Re: canon s90 macro
Hi
When I take macro photos with my s90 i do the following:
1.select "macro" on rear thumb wheel
2.menu button - change face aiaf to "centre" (then "frame size to small")
Then when focusing you will have a very small geen box on the rear lcd to focus
on your subject - this will ensure very precise focusing.
Also another tip - is subject likely to move? (ie flower in wind)
1.change from fixed focuing on half shutter press to continuous focusing when half
pressed (this changes the box from green to blue).
2.menu button - change "servo af" from off to "on"
Carl
Re: canon s90 macro
Some s90 macro examples examples using previous techniques.
OP Henry A Greenblatt Regular Member • Posts: 190
Re: canon s90 macro
thank you so much. I will try your advice and get back to you to let you know how it works out for me or if I have any difficulty. I love your macro shots, the shallow depth of field and nice background blur are just what I'm looking for and with flowers as you predicted.
Hank
Re: canon s90 macro
Let me know how you get on - add some examples etc
cheers
carl
Re: canon s90 macro
how do I change from face aiaf to center? (what is aiaf?)
how do change the focusing when the shutter is half way down to go from the green to the blue box?
thanks for your patience.
Hank
Re: canon s90 macro
yooperguy Senior Member • Posts: 1,870
Re: canon s90 macro
Read page 84 (and top of 85) of your user guide for info on AiAf. Read page 87 for info on Servo AF and blue box during half press.
Dennis
 yooperguy's gear list:yooperguy's gear list
Canon PowerShot G15 Samsung NX100 Samsung NX20 +1 more
Re: canon s90 macro
hi
1. turn on camera
2. push menu button on rear of camera
3. hit down arrow on centre pad - this then shows AF FRAME
4. hit right arrow on centre pad - this then shows CENTER (hit right key to select it).
5. hit menu button again to save and exit all done
thanks
carl
Re: canon s90 macro
When I hit the down arrow on the center pad, it does not show AF FRAME, it shows AF Frame Size, and the only two choices are small and normal, not CENTER.
Am I in the right spot?
thanks, Carl, I appreciate your patience.
Hank
