shooting in the "Raw"
Started Jul 12, 2002 | Discussions
Thomas Regular Member • Posts: 268
For those of you that thought I was referring to nudity, sorry.
How much space do the raw files take up? Is it advantageous to shoot RAW at a wedding for example? Or does it take up too much space on the cards?
I am a S1 user anxiously awaiting my S2 which should be here in about a week...any info on RAW you can give me is appreciated--especially as it applies to large family wall portraits as this has been the only thing I have had problems with on the S1. How is the Fuji software that comes with the camera?
Thomas
Mike Flood
Mike Flood Senior Member • Posts: 1,592
Re: shooting in the "Raw"
space on the cards?
Thomas
All Raw format files are just over 12+ megabytes.
The advantage, in my view is that you get the full resolution image.
Saving the same file as RGB.TIF would have yielded a 35+ meg file and you can't make changes like you can in processing Raw files.
Since the original raw image file is not touched you can make multiple copies at different image sizes and other settings. Compare them, use small ones for web pages, use the largest ones for great prints.
Raw format saved my bacon this morning.
Last night the shots I was doing were with available incandesant light in the living room. Today I prepared to replace the old rusty garden windmill of my wife's with a new one. I wanted before and after photos.
I set up the tripod, composed the shot and took several including her and our dog.
Then I took the old windmill down, put the new one in and shot more pictures.
I got in the house and found that I had failed to check the camera settings.
(of course I know no one else ever does that)
I had left the color on "Incandesant" so all the shots outside were very much too blue. I began thinking about what Photoshop settings I would use to do the color correction. Then I looked at them with Finepix Viewer, clicked on them and started up the Raw Image convertor.
Then instead of selecting "camera settings" for the image conversion I selected "custom settings", changed the color to "Fine" (I don't know why they don't call that "Daylight") and made a couple of other setting changes for sharpness, set the size at 1440 X 960 and let it do the conversions.
Before you do the conversion you can see what the results of the settings you select in the preview window.
Saved me a lot of fiddling with Photoshop
If there's one feature of the S2 I like compared to the S1, it's gotta be the Raw file mode.
By the way, if you view the images from the camera memory in the Fuji Finepix viewer you can click on an icon in the viewer to start either a version that saves a .tiff file with all the Exif info intact or just some of the Exif info. The raw files can be saved as two different type of 16 bit files for use with Photoshop or other apps that can handle 16 bit or as 8 bit sRGB files.
Have fun
frank barret Regular Member • Posts: 317
see the manual
You can download the complete hyper utility and raw convertion manual in pdf format and see the specifications.
http://home.fujifilm.com/products/digital/digitalcamera/fxs2pro/
by the way, what is color space in practical terms, and which one is better for Mac, etc.
space on the cards?
Thomas
for great prints.
after photos.
her and our dog.
pictures.
settings.
convertor.
Have fun
Frank Barret
Raul Veteran Member • Posts: 8,240
You did trick me into your thread: nice caption, that is what I call
marketing.
I have a D1 and S1 and a D1x. I shall be buying the S2.
The Fuji conversion sooftware better be good as Nikon is.
Enjoy and accept my envy
Raul
Muzz Forum Member • Posts: 79
I'm interested in the raw format - does the S2 also write a jpg file like the Canon D60 so you can view "normal" color when reviewing images on the lcd or do you get the"green" look?
Muzz
OP Thomas Regular Member • Posts: 268
Thanks Mike!
Do the Raw files have significantly more detail than capturing as a jpeg? I am wondering here about wall portraiture specifically.
Thomas
You can sure view in camera the raw files as they are with no
green(?) look.
Raul
Muzz
Mike Flood
Re: "Raw" vs Jpg
Thomas wrote:
Thanks Mike!
Thomas
There should be the maximum amount of detail the camera can deliver, saved as Raw.
It's difficult to make a full comparison since you can't (at least I can't) view a screen filling Raw image. But saving your raw file as a 16 bit tiff and opening it in Photoshop should be far superior to a file saved with any degree of jpg compression. I have only printed one of the file that was originally raw. It looks great but then so did most of the ones I shot with my S1.
