Some of the best macro pics ive ever seen with m43
Started May 15, 2010 | Discussions
ashatron Senior Member • Posts: 1,003
Found some great pics - GF1 with Leica 45mm macro is a deadly combination.
And the best part is he won his GF1 in a raffle! crazy times!
http://www.flickr.com/photos/fardels2009/
OP ashatron Senior Member • Posts: 1,003
Re: Some of the best macro pics ive ever seen with m43
That lens can do 1:1 naturally...thats incredible.
David V
David V Senior Member • Posts: 1,182
Those are just ridiculous! Unbelievable! Oh yeah.....They're good too!
 David V's gear list:David V's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm X-T20 +9 more
Brigcam Regular Member • Posts: 163
That last one is great, much better than your run of the mill bug shot.
h00ligan Veteran Member • Posts: 3,102
I saw your link in another thread....wow. Really great shots from mft! Thx for posting!
You're welcome hooligan!
Yeh the last is special!! A little insect battle!
kiri Senior Member • Posts: 1,628
Did he ONLY use a GF1 and the 45mm macro lens for these???
If so, its really incredible!!
But I wouldn't have thought it possible to get that much magnification with that lens... Some of these look to be much greater than 1:1 no?
dietero Contributing Member • Posts: 816
Yes they are!! (nt)
Dietero
'Make God Laugh, tell Him your plans.'
••Excelsior••
Voldenuit
Voldenuit Senior Member • Posts: 1,648
1:1 magnification is at the focal plane. If you stop down (a lot of his shots are at f/18), you get increased DOF both in front of and behind the FP. Course, f/18 doesn't buy you much depth at macro distances, but it's still something.
1:1 is pretty good, I was tracking a bumblebee with the PL45/2.8 today, and I could get close enough that he more than filled the scene. Unfortunately, he really didn't like that, so I backed off after taking a couple of blurred shots. Doh.
Oh, not related to DOF, but I believe he also used a FL-36 or FL360 flash. Awesome stuff, in any event
 Voldenuit's gear list:Voldenuit's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +4 more
Vaughan Williams Contributing Member • Posts: 743
I think for some of the extreme close ups he uses a Raynox close up lens on the front of the 45mm macro to achieve greater magnification.
i know! that 45mm lens is incredible.
Roxy1945 Senior Member • Posts: 1,529
Did he hand-hold for these great pics and did he use Raynox 150 or 250 clipped on the end. Give us the full set-up - Thanks
Tapper123
Tapper123 Senior Member • Posts: 1,701
Very good! (nt)
nt nt nt nt nt
 Tapper123's gear list:Tapper123's gear list
Sony RX100 III Fujifilm X100F Sony Alpha NEX-F3 Olympus E-M5 II Sony E 18-55mm F3.5-5.6 OSS +7 more
deep7 Contributing Member • Posts: 996
1:1 on 4/3 gets you a better close up than 1:1 on 35mm (about twice as close). That's the maths of a smaller object being the same size as a smaller sensor.
Don.
A Land Rover, a camera ... I'm happy!
boyzo Veteran Member • Posts: 4,516
Re:Excellent n/t
Aleo Veuliah
MOD Aleo Veuliah Forum Pro • Posts: 14,723
Superb images
Simplicity is the ultimate sophistication
 Aleo Veuliah's gear list:Aleo Veuliah's gear list
Panasonic Lumix DMC-ZS1 Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-G2 Panasonic Lumix DC-G9 +6 more
EdBen Regular Member • Posts: 189
Great pictures, and that last one is just special!
 EdBen's gear list:EdBen's gear list
Panasonic Lumix DMC-GF1 Olympus E-M5 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH +2 more
PhillipA Veteran Member • Posts: 5,505
Keep in mind that 1:1 on M4/3
...means that an object only 17mm x 13mm covers the full sensor area, whereas on (35mm) full-frame bodies it would only cover 1/4 of the sensor. An object 36mm x 24mm covers the sensor area at 1:1 on full-frame DSLRs. This gives the 4/3 rig the same effect as 2:1 magnification on full frame.
Judge: ' This image may be better in black and white - perhaps even just black! '
mano42 Regular Member • Posts: 177
just WOW
 mano42's gear list:mano42's gear list
Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GM1 +1 more
