Best render settings for AVCHD in Sony Vegas (TZ7)
Started Mar 28, 2010 | Discussions
PipeDream Forum Member • Posts: 59
Movies coming out of my TZ7/ZS3 are have always been quite good, reasonably sharp with vivid colors.
However I'm an edit guy and most of what I shoot I also cut and process. Most recently I do that in Vegas Movie Studio Platinum, which I found to be a greatly superior product to Windows Movie Maker, which I used for many years for my Canon's VGA videos.
Panasonic's new AVCHD made me switch to Vegas, and I'm glad I did because compared to it the WMM is a sorry piece of crap (especially the XP version)
Anyway,my problem with editing in Vegas was the final product output quality. Using the most comon WMV or AVI render/compression settings the TZ7 movies were noticeably less sharp and colors substantially paler compared to the original MTS footage. Many told me that was something to be expected if you do any video processing, which always sounded like bologni to me, because video is meant to be worked with.
(By the way I'm not suggesting that the WMM output was any better, it's just that that was VGA and this is HD, and whereas I didn't care that much about a degraded quality of the original VGA video file, now I shoot HD and I expect the HD benefit all the way.)
I kept looking for better render settings until i found this one:
File> Render As>
Save as type "Sony AVC"
Click "Custom"
Project Tab:
Video Rendering Quality: Best
Video Tab:
Format: AVC
Frame Size: Custom
Width: 1280 Height: 720
"Uncheck" Allow source to adjust frame size
Profile: Main
Entropy Encoding: CABAC
"Uncheck" Allow source to adjust frame rate
Field Order: None (Progressive)
Pixel Aspect Ratio: 1.0000
Bitrate (bps): I recommend anywhere from 4,000,000 to 6,000,000 for Vimeo. Only go below for longer videos.
Audio Tab:
Format: AVC
Sample Rate: 48,000 Hz
Bit Rate: 128,000
System Tab:
Format: MP4
RESULT: quality indistinguishable from the original. and if you wanna push it even further, add a 'light shrapening' effect to your footage, and the outcome will be EVEN BETTER than your original MTS file quality.
SIZE you ask? between 45 to 60% of the original MTS size.
The output format is the perfectly universal and usable MP4.
this is especially directed at 'englishman; who posted his kid's ZS3 video on YouTube. he mentioned he doesn't trust Vegas to do the compression, instead running his uncompressed Vegas output through some additional third party software. Give this one a try.
Credit goes to: Alex Hagen of http://vimeo.com/nod7667
Humanoid
Humanoid Veteran Member • Posts: 4,687
Re: Best render settings for AVCHD in Sony Vegas (TZ7)
Thanks for the information!
Ray
 Humanoid's gear list:Humanoid's gear list
Nikon D2X Nikon D3 Nikon D200 Nikon D300 Nikon D700 +9 more
