Cheapo Ebay triggers and Batteries
Started Mar 17, 2010 | Discussions
garyb1985 Forum Member • Posts: 67
I bought some of the cheap pt04 ebay triggers a while ago and they worked fine at first (with the supplied alkalines). however I then got some rechargable AAAs and am now having problems triggering with them, they only work at a very close range.
The rechargables are rated at 1.2v and standard AAAs are 1.5v, do you think it is this that makes a difference?
Anyone else had similar issues?
Light is Light, its what you do with it that counts
http://www.gbmultimedia.co.uk
CharlieDIY
CharlieDIY Veteran Member • Posts: 7,120
Re: Cheapo Ebay triggers and Batteries
No, because I don't try rechargeables in everything. Give it a shot with alkaline AAs (or AAAs) and see if that corrects things.
slowhands Veteran Member • Posts: 5,470
It has been a recurring topic.
Fresh batteries OF THE REQUIRED RATINGs for the electronics are a good thing, and not a significant cost for the PT04's.
I (try to) always make sure the receivers are switched "OFF" when not in use.
I also try to keep the Xmtrs and Rcvrs in a hard case, along with spare batts in my bag.
Some triggers "test" buttons are easily accidently depressed, running down the battery when you aren't looking. A friend's AB triggers went flat in the bag, only to be discovered at the start of an event. The assistant ran to the closest store for replacement batts (and a spare set).
Also - if the PT04's operate in the 433MHz frequency range...this frequency is also used for many other consumer devices (garage door openers, older wireless phones, etc.). I found an antenna mod for the Xmtr better matched the antenna to the frequency, and solved the inconsistancy issues I had with Cactus V2s units.
 slowhands's gear list:slowhands's gear list
Canon EOS 40D Canon EOS 350D Canon EOS 7D
ImagingImpulse Forum Member • Posts: 94
I found fresh batteries always had mine working better. Now they just sit in the drawer at home.
Just one of the reasons why I switched to the Cybersyncs.
The trade-off's result in consistent, reliable firing of the flash.
Brian
marceloanelli Regular Member • Posts: 250
Gary,
all chinese "cheap" radio must use alkaline battery. If you use NiH rechargeable battery may experience degradation on syncronization of radios. I use them and with fresh recharged battery of 850 may work for a while.
Sorry for my ugly english...
Marcelo Anelli C.
http://www.marceloanelli.com/
OP garyb1985 Forum Member • Posts: 67
Fair enough, thanks everyone! Alkalines it is!
Zorpie Senior Member • Posts: 2,836
Hi Gary,
Yes, I would say that the transmitter would probably show a significant power output drop in a reduction of 1.5V to 1.2V per battery. You will probably see the same reduction in power output (and range) when the alkalines drop below 1.5V too.
Zorpie
http://www.pbase.com/zorpie
If it seems too good to be true - then it isn't. If you cannot believe your eyes - then don't.
