Another S90 Case Option
Started Feb 14, 2010 | Discussions
Tekkie Regular Member • Posts: 120
I've found the Case Logic MEQB-1M to be a perfect fit for my S90. For me an important feature was a permanent belt loop, rather than a temporary clip/snap/velcro strap arrangement. I commute on public transit, and have had several close calls nearly losing mobile phones and other gadgets thanks to loose straps. It's well worth taking a couple of extra seconds to put it on the belt for the peace of mind knowing it won't fall off. This one also came with a small carabiner, though I don't use it. There's a small mesh pocket inside, big enough to hold a spare battery and memory card, but not much else. I don't anticipate problems fitting in the Franiec grip that's on its way. It doesn't seem to be on the Case Logic website (perhaps recently discontinued?), but mine was $10 Canadian at the local Sears department store, and here it is on the WalMart website, also available in other colours:
http://www.walmart.com/ip/Case-Logic-MEQB-1M-Eva-Hardshell-Small-Digital-Camera-Case-Black/10297712
Photos taken with my trusty Sony DSC-F717. I have no connection with the product or stores mentioned, other than being a satisfied customer.
Russ.
SmartAlex Regular Member • Posts: 265
Re: Another S90 Case Option
Seems like it might fall out when you remove it if you're not careful, no?
IMHO, I like the Canon S90 case that's designed for it. Perfect fit, easy to remove, and not a lot of bulk. Plus looks vintage. I like that.
OP Tekkie Regular Member • Posts: 120
Thanks for your comments.
Removal from the case is pretty much a two-handed operation, but not a big deal if you unzip it 2/3 of the way then insert your hand and wrap it around the camera.
Which original Canon case are you referring to? I've seen several (PSC-2600, PSC-2500, PSC-900) that supposedly fit the S90. There's also a nice leather case from China discussed in this thread:
http://forums.dpreview.com/forums/readflat.asp?forum=1010&message=33823156
They all look good, but are expensive and none meet my particular need for a permanent belt loop.
Russ.
Canon PSC900 Deluxe Leather Case is the one I'm referring to. It fits the S90 perfectly and is less than $30.
http://www.amazon.com/Canon-PSC900-Deluxe-Leather-Case/dp/B002OLWITO/ref=sr_1_1?ie=UTF8&s=electronics&qid=1266190877&sr=8-1
gybassman Regular Member • Posts: 246
Lowepro Ridge 10
For $10 at Best Buy you can't beat it, S90 fits perfect.
http://products.lowepro.com/product/Ridge-10,2018,24.htm
 gybassman's gear list:gybassman's gear list
Canon PowerShot G15 Nikon D800 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +9 more
Re: Lowepro Ridge 10
Lowepro seems to add bulk, no? The Canon PSC900 Deluxe Leather Case adds about 3/8" - 1/2" of extra bulk. Still making it pocketable.
tsinvest Senior Member • Posts: 1,143
Lowepro Hipshot 20
Just bought the Lowepro Hipshot 20 in Staples today...great streamlined pouch. I have another bag I use for S90 with some extra space for SD cards and battery, but for just the S90 by itself, this Hipshot bag is the sleekest I have found.
http://products.lowepro.com/product/Hipshot-20,2133,25.htm
 tsinvest's gear list:tsinvest's gear list
Nikon Coolpix P900 Canon G7 X II Nikon D7500 Nikon D80 Nikon AF-P 18-55mm F3.5-5.6G VR +11 more
gottria Regular Member • Posts: 407
Re: Lowepro Hipshot 20
OK, I throw my choice in for the S90 case. Fits it really nice snug so it doesn't add lot of bulk to the camera and has zippered front pocket big enough for just a spare battery and memory card.
http://www.walmart.com/ip/Case-Logic-TBC302-Compact-Camera-Case-Black/10929531
Greg
http://www.CVphotography.net
I saw this case while at Staples and it does fit the S90 just right. It probably is the sleekest case that also has a pocket for a memory card and battery. The Hipshot case on the other hand is just for the Camera, no cards, no batteries - not as wide or thick as the Case Logic case. I would get the Case Logic case if I needed the extra storage and the Hipshot if I just wanted to protect the camera while in my jacket pocket, etc. By the way, with either case I would be very careful of the carabiner clip - it would certainly scratch the camera lcd screen if it rubbed against the little hinge rivets. I took my clip off. I would say that using a metal clip is actually a poor design feature. Regards....
Greg
Mikeworld Forum Member • Posts: 53
For those who live in Canada, I can recommend the Golla Shield as yet another great case for S90. It is currently on sale for less than half price at the Source.
http://www.thesource.ca/estore/product.aspx?language=en-CA&catalog=Online&category=CameraBags&product=1618553
http://images.thesource.ca/estore/images/EN/banners/promotion/family_EN.jpg
Also, check out this post by a user of this case in another photography related forum to get more details of it.
http://photography-on-the.net/forum/showpost.php?p=9361500&postcount=122
sneakerpimp
sneakerpimp Senior Member • Posts: 1,089
i got the TBC301, same as the 302 but without carabiner and front pocket... it's 1/8" thinner and costs six bucks at Microcenter.
 sneakerpimp's gear list:sneakerpimp's gear list
Canon PowerShot S90 Canon PowerShot G7 X Canon EOS M
Humble Bear Regular Member • Posts: 499
No zipper case for me; they can scratch.
willsmother Regular Member • Posts: 360
Lowe Pro Terraclime 10
Others have commented on the terraclime 30 for the S90. I could not get the 30 in Bankgok, but found a complete range of all the colours of the 10. It is a good snug fit, works well and is eco friendly
No Velcro to snag the wrist strap, no zipper to scratch the LCD
Sorry, can't take a pic of the camera in the case right now as do not have a spare to take photos with
Good luck
Helen
OM1 Contributing Member • Posts: 672
SmartAlex wrote:
I like the Canon [PSC-900] case that's designed for it. Perfect fit, easy to remove, and not a lot of bulk. Plus looks vintage. I like that.
If you are after a vintage look, the DCC-1440 leather soft case should suit you even better:
Ron E Trees Veteran Member • Posts: 3,944
Does the Canon Case...
Let you carry a spare battery and memory? I would have no use for it if it doesn't. If you use the S90 for very long, you are going to need another battery. Yes the little Lowepro cases do add more bulk, but I think they are a bit more versatile also.
I am using this case, http://www.bestbuy.com/site/Lowepro+-+Pouch+-+Black/7092932.p?id=1109233323040&skuId=7092932&st=lowepro&cp=2&lp=3
Ron
 Ron E Trees's gear list:Ron E Trees's gear list
Nikon D610 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR
Found a better image:
Re: Does the Canon Case...
No. It doesn't have a slot for extra battery or memory card. I haven't used it for a long trip or don't take more than perhaps 50-100 shots per day. I imagine I would carry it with my hi-def Sony camcorder bag if that's the case.
Also, this case is stylish and fits perfectly in my jacket pocket with no bulk. Isn't that the whole purpose of the s90 after all?
Just an update...I have a lot of problems getting the camera in this case. Out is no problem, but in is always tricky. It has a cloth lip with a pull string that makes the fit a bit tight and hard to get the cam back into the case. I may return it for the Case Logic case. I really like the HipShot fit, but always struggling to get the camera in the case is getting old.
Eadward Regular Member • Posts: 120
I've got that one too. It's sweet.
 Eadward's gear list:Eadward's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV
Another update for those of you that may have the Hipshot 20. I decided to cut off the nylon flap and pull string from the opening of this case and now I have no problem getting the camera in and out. It didn't matter to me to have the case completely sealed, and now it works as protection for when the camera in in my pocket. It is so much easier to work with without that flap.
