Dimage 7i EVF black
Started Jan 31, 2010 | Discussions
FrankLen New Member • Posts: 4
Dimage 7i EVF black
After the defective CCD had been replaced the EVF of my Dimage 7i worked properly only in certain tilt positions. At last it stopped working entirely (EVF display black). Since warranty was through I bought a otherwise defective Dimage 7i via online auction, took the EVF from that one and installed it to my Dimage. It won't work either!
Is there anybody who experienced similar problems and can provide a solution or hints?
Reg Ister Senior Member • Posts: 1,724
Re: Dimage 7i EVF black
It might be simply the connecting ruban between the electronics and the EVF.
Especially when in the beginning it was dependent on the position of the finder.
I don't know it you can find replacements, but after all those rubans are so common now, that with some imagination one could find a replacement?
Maybe the ruban in your camera for parts is still working!
Reg
PAW=pollution, on a public forum
Barrie Davis
Barrie Davis Forum Pro • Posts: 21,460
Reg Ister wrote:
snip
Ribbon?
Baz
I am 'Looking for Henry Lee ' (could be Lea, or even Leigh) and despite going 'Hey round the corner', and looking 'behind the bush', I have not yet found him. If he survives, Henry is in his mid-60s, British, and quite the intellectual.
What is it all about? Well, something relating to a conversation we had in the pub 35 years ago has come to spectacular fruition, and I'd like him to know how right he was.
If you know somebody who could be this man, please put him in touch with me. Thank you.
 Barrie Davis's gear list:Barrie Davis's gear list
Konica Minolta DiMAGE A2
OP FrankLen New Member • Posts: 4
Hi Reg,
thanks for your hint! I replaced the flat flex cable ("ruban", but I understood anyway) - and the EVF is working again!
However, after a few minutes operation time the EVF image turned rather milky. Like seen through a white veil. Any idea even about that?
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,687
FrankLen wrote:
Hi Reg,
Could this be condensation - IE moisture got inside somehow?
At the moment in the UK condensation in lanses and cameras is qiuite a problem with the temperature variation getting in and out of a car.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Barrie Davis
Adrian Harris wrote:
FrankLen wrote:
Hi Reg,
It could even have happened as the camera warmed itself up after a long period of not being used.... we know that the Dimage 7 range runs a bit warm. I'm thinking internal moisture could have been evaporated onto different surfaces, possibly?
(Suggestion: Pop it in the airing cupboard next to the hot water tank, for a day?)
At the moment in the UK condensation in lanses and cameras is quite a problem with the temperature variation getting in and out of a car.
Yours is a good point; I don't think temperatures have been much different in Germany, Adrian!
Baz
Haha, sorry Baz, sorry Frank, for the ruban (as a dutchman living in a german/french speaking part of france, writing in english... oh boy...)
But great that it i workin again!
Best regards,
Reg
FrankLen wrote:
Hi Reg,
Hi Adrian, hi Barrie,
thank you for the clue. I'll check condensation on weekend and report back!
Barrie Davis
You're doin' OK. Don't worry.
Baz
it seems, condensation had been the issue, indeed! Have been using the camera yesterday - with the EVF working fine!
Thanks again!
gromit1943 New Member • Posts: 1
FrankLen wrote:
Hi Reg,
PLEASE Tell me where you got the ribbon cable!!?  I really need two.
Sincerely,
Terry
Dr T Rowe
neilt3
neilt3 Veteran Member • Posts: 3,008
gromit1943 wrote:
FrankLen wrote:
Hi Reg,
Sincerely,
You buy a camera off eBay and use it for parts .
Ones that are sold as "untested" tend to be cheep .
Just hope the parts you want are still in good order .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
