Infrared filter, which one?
Started Jan 4, 2010 | Discussions
jonny1976 Veteran Member • Posts: 4,277
i have found some filter from b + w for infrared...but i dopnt' know which buy...there are the 093 and 092, the 093 seems to need a lot of light also during day, the 092 it's more easier and block less spectru
m. Which one shoul di buy?
also other brand suggestion is welcomed
http://www.pbase.com/jon1976
 jonny1976's gear list:jonny1976's gear list
Nikon D2X
JohnK Veteran Member • Posts: 7,083
Re: Infrared filter, which one?
Hi, I like the Hoya R72, (720nm cut off, meaning all wavelengths below 720 nanometers are blocked), gives a nice Wood effect (for Prof. Robt. Wood, first IR photographer) and is not too dark, so AF and AE tend to work pretty well. Also, not as expensive as B+W. I have some IR shots here at
http://www dot johnkennyphotography dot com, many with R72.
Here's a chart explaining "Wratten" numbers which are seen a lot in connection with IR filters.
JohnK
Take a picture, it'll last longer.
 JohnK's gear list:JohnK's gear list
Sony Alpha NEX-5 Sony Alpha NEX-5N Sony a6300 Canon Pixma Pro-100
OP jonny1976 Veteran Member • Posts: 4,277
hi thanks
i have read that the bh 093 is really hard to work with so i prefer a less dramatic filter to work better and easier.
i have read there are some filter for when u use the camera without the ir filter and want the color norma..they are UV/IR block filter. do u know one to suggest?
Nikon D2X
Hi jonny1976, I bought a so-called "hot mirror" filter from maxmax to use for normal photos when the ir blocking dust protector is removed from the SD14 but have found it to be unsatisfactory. No amount of PP gives good results. So I've become adept at removing and inserting the dust protector. It would be great if Sigma would make the IR blocker in an 82mm screw thread, wouldn't it? Perhaps someone else knows of hot mirror that would work.
JohnK
