noise removal software
Started Dec 26, 2009 | Discussions
marcus300 Regular Member • Posts: 238
Help wanted.
I'm looking to get a noise removal program and wondered which was best?
I'm aware of two such programs: Noise Ninja & Neat Image.
I use both a D40 and D200 if this makes any differance to which would work best with my cameras.
thanks
Marc
 marcus300's gear list:marcus300's gear list
Nikon D300 Nikon AF-S Nikkor 300mm f/4D ED-IF
CaseyJ Senior Member • Posts: 1,855
TopazLabs Denoise
I have tried them all, Neat Image, Noise Ninja, Picture Cooler, etc, and the only one I would pay for (and have paid for) is TopazLabs Denoise. Slow but the very best of the lot in my humble opinion.
http://www.topazlabs.com/
CaseyJ
 CaseyJ's gear list:CaseyJ's gear list
Nikon D40 Nikon D5500 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Micro Nikkor 40mm F2.8 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +2 more
OP marcus300 Regular Member • Posts: 238
Re: TopazLabs Denoise
Thanks Casey, I was not aware of this program....The samples they have posted look excellent.
BiscuitMonster Senior Member • Posts: 1,021
Re: noise removal software
Since I've been trying out the Lightroom 3 beta, I really can't imagine ever bothering with external noise reduction software again. LR3 produces excellent results from all the raw files I've thrown at it (Nikon D90/D300s/D700, Canon G10/S90/50D, Pentax K10D, K-7).
 BiscuitMonster's gear list:BiscuitMonster's gear list
Fujifilm X100S Nikon D300S Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Tamron SP AF 60mm F2 Di II LD IF Macro +3 more
(unknown member) Forum Pro • Posts: 14,338
I too like Topaz Denoise. However, be aware that:
1. It is only available as a Photoshop (or compatible) plugin. There is no standalone program so it's not going to work for you unless you have an application to host it.
2. As already mentioned, it's very slow although the results are worth it.
Also, if you use Photoshop and any of the compatible NR plugins, it's pretty easy to use a surface mask and that's a great way to protect detail whilst taking the noise out of skies and other smooth surfaces.
I should have mentioned that I do use Photoshop 7 but never tried with a noise removal plugin added. thanks
Anada Senior Member • Posts: 1,500
G'MIC for Gimp
Another very slow but VERY good is G'MIC for Gimp. The best thing in these are the fact that you don't pay anything. I've used both Noiseware plugin on PS and G*MIC plugin on Gimp, and G*MIC has been the better one on D300, D200 and Panasonic TZ7.
Antti
some pics: http://www.pbase.com/anada
 Anada's gear list:Anada's gear list
Panasonic Lumix DMC-ZS40 (TZ60) Nikon D300 Huawei Honor 7
charleyd Senior Member • Posts: 1,132
I am using Noiseware Community Edition 2.6. It is freeware. I checked it against ninja and a couple of other programs. I could see no difference in the results. In a couple of instances it actually did a cleaner job. Get it at http://www.imagenomic.com and give it a try.
cdj
990,5000,d100,d200,d300,nikkor 50mm 1/1.8,nikkor 24-85,tamron 28-300,sb800
Gale Bizet Forum Pro • Posts: 15,266
Agree with topaz denoise..nt
egrivel Senior Member • Posts: 1,841
Re: G'MIC for Gimp
I found the G'MIC page at
http://gmic.sourceforge.net/index.shtml
but I don't quite see how this is a noise reduction software... am I looking at the right thing?
Eric
http://www.lumenssolutions.com/
berleconi Contributing Member • Posts: 720
test
REBlue Senior Member • Posts: 2,092
Which ones work on raw files? I liked Noise Ninja, but it doesn't do raw files.
http://community.webshots.com/user/REBlue01
http://www.flickr.com/photos/reblue/sets/
maverick01 Contributing Member • Posts: 771
Re: test
berleconi wrote:
Independent noise reduction test of many tools
http://www.michaelalmond.com/Articles/noise1.htm
http://www.michaelalmond.com/Articles/noise_conc.htm
top 3
noise ninja http://www.picturecode.com
neat image http://www.neatimage.com also a free version
PC http://www.focusforensic.shorturl.com/ free denoiser
While a nice test, one should keep in mind that this test was last revised in 2005 and noise removal software has improved much since then.
Derek Hawkins Senior Member • Posts: 2,049
NX1 and NX2. I actually prefer NX1's noise redution to Noise Ninja....Go figure.
Re: Which ones work on raw files?
I use NX2, but it sometimes takes away too much detail for my liking.
DezM
DezM Forum Pro • Posts: 34,874
Noiseware and Dfine
Amazing how there's quite a few responses. My personal favorites are Imagenomic Noiseware: http://www.imagenomic.com/nwpg.aspx
.....and Nik Dfine 2.0:
http://www.niksoftware.com/dfine/usa/entry.php
Dez
http://photos.dezmix.com
 DezM's gear list:DezM's gear list
Nikon D850 Nikon Z6
1971_M5
1971_M5 Veteran Member • Posts: 7,122
Photoshop
When I had a super-zoom bridge cam, I was always looking to remove noise. So... I bought Neat Image. Problem was... it de-noised the entire picture. Subsequently, I got a copy of Photoshop Elements (for reasons other than noise reduction) and I found an added bonus... it had an NR filter built-in and it was effectively much better since I could select the area(s) to apply the NR. Maybe the new versions of NR software can do this, but frankly I'm not interested; Photoshop (I use the old v4 Elements) does what I need in this regard. Typically, with the D300, I only need to apply NR to the sky in a few limited situations.
JF
 1971_M5's gear list:1971_M5's gear list
Nikon D7100 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,364
I use Noise Ninja for years and tested some months ago TopazDenoise. Generally it is praised and has good results with some reviews claiming it the best of the available solutions.
My personal experience (certainly it can be different for others):
1) I did not perceive any better results than Noise Ninja - mainly if you know to work with NN setup outside the default values
2) TopazDenoise is veeery slow (as mentioned previously)
3) If you have a major area underexposed, near detailless, Topaz constructs a strange pattern in the area, Noise Ninja presents ramdom artifacts
I decided to stay with Noise Ninja after the expiration of my try out period.
O.Cristo - An Amateur Photographer
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Coraggio Junior Member • Posts: 38
which noise reduction sw can plunin NX2?
My work flow is pretty rely on NX2, and its noise reduction is not so satisified due to loose many details. Any of the recommendation above that can plug-in for NX2?
Y Burger New Member • Posts: 9
I like DFine 2.0 (NIK software) best. No need for separate camera profiles anymore and it is fast. It also supports Photoshops Smart Filters which can be a big plus. As mentioned earlier, be sure to check out the NR in Lightroom 3 (beta). Results seem also very promising!
YB
