Lensbaby on GF1 – Great combination
Started Dec 13, 2009 | Discussions
ethno New Member • Posts: 11
Today it is a cold and miserable day so I decided to stay at home, have a nice cup of tea and play with my cameras. One lens that I have not used for a long time is the Lensbaby for FourThirds that I have been using with my Olympus.
As you can see from the photos below – it fits the Lumix DMW-MA1 adaptor nicely. I took a few test shots and it works fine. I find the idea of being able to capture tilt-shift HD movie clips very exciting indeed.
MarconiQ Forum Member • Posts: 97
Re: Lensbaby on GF1 – Great combination
Nice - please let us know when you have made some with this combo.
Regards, Marcus
Teski
Teski Forum Pro • Posts: 13,060
Same here...
Would love to see some shots with this combo. I remember seeing a couple some time ago from someone, but we haven't seen a whole lot of m4/3 with the lensbaby.
 Teski's gear list:Teski's gear list
Sony RX100 III Leica M Monochrom (Typ 246) Canon EOS-1D X Leica M Typ 240 Sony a7R II +8 more
Diane B Forum Pro • Posts: 20,697
I had the LB 2.0 with EF mount and bought the EOS to m4/3rds adaptor to use it and my 45 TS lens on the G1GF1, but in the ned, I bought a new LB Composer with 4/3rds mount and am using it with the MA-1 adaptor. Works nicely. I debated off and on whether to buy it in EF mount also so I could use it with 5D, but KNEW in the end LOL--that I would only really like it with liveview of the m4/3rds so bought the 4/3rds mount. I added the UWA which gives me about same FOV as the 20 f/1.7--and just bought the FE optic. I'm looking forward to using LB with the Gs. Hope to see some shots from you soon.
Diane
Diane B
http://www.pbase.com/picnic
G1 gallery http://www.pbase.com/picnic/temp_g1
 Diane B's gear list:Diane B's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Apple iPhone XS Max +1 more
Re: Same here...
Here are a couple--with constant rain, I've mainly shot interiors--and low light at that. I opted not to embed but rather give links.
Here are a few experiments with the Composer wide open (f/2.0) and UWA converter (.42 which gives me about same FOV as 20 f/1.7)
http://www.pbase.com/picnic/image/119599185
http://www.pbase.com/picnic/image/119599183
http://www.pbase.com/picnic/image/119599182
and some with the FE optic--which is spherical on FF, but closer to my linear 15mm FE on my 5D with the m4/3rds. Its a 12mm so FOV of 24mm wide open which is f/4.0
http://www.pbase.com/picnic/image/120171064
http://www.pbase.com/picnic/image/120171063
http://www.pbase.com/picnic/image/120171062
and one with the Composer/UWA and creative aperture
Hope to get out and do some interesting shooting with it.
Diane
Diane B
Steven Wandy Veteran Member • Posts: 5,424
Ethno,
Like Diane I also had the LB 2.0 and decided to sell it and get the Composer in 4/3 mount. It is much easier to control and get the focus point where you want it. Though a lot of LB users will say that it is unpredictability of the LB that is part of its appeal. Your decision.
Enjoy the lens on the GF1,
Steve
 Steven Wandy's gear list:Steven Wandy's gear list
Canon PowerShot G7 X Olympus PEN E-PL1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus Body Cap Lens 15mm F8.0 +6 more
Activatedfx Contributing Member • Posts: 957
I had a LensBaby ... for about 2 weeks. After the initial "wow" factor wore off, I realized that what I was getting were basically "blurry" images. Every once in awhile, you can get a shot that really "works" with the LensBaby look, but 99 out of 100 are throwaways. I can't tell you how many people said they were glad I stopped using the LB, because they were tired of the look.
12photosayear Junior Member • Posts: 34
Nice setup. Do you remember where you bought your wrist strap? It looks sturdy!
 12photosayear's gear list:12photosayear's gear list
Panasonic LX100 Olympus E-M5 II
I find the look I got from the LB 2.0 as opposed to the Composer quite different. I'm able to use selective focus much more easily--and with the addition of the better/larger set of aperture disks (able to stop down further) I can control the focus area a lot more.
I do think, and of course this is a personal decision, that many people twist the lens too far. Since I've shot with a tilt shift for a good while I know that its only a matter of a few degrees to change the focal plane of the lens. Experimenting with the lens you find that you can get a focus area that is very sharp--and by moving the lens in the direction of an off center subject--but very gradually and not nearly as much as one would think--you can keep that focus area quite sharp---and by stopping down, increase that area quite a lot. I'm spending some time with it to determine just how much I need to 'bend' to get the look I want. I think it takes a bit of time to become accustomed to shooting with it. Having a focusing ring on the lens makes a huge difference over the LB 2.0--and I guess the successor to that lens. Then again--some prefer the more 'randomness' of the twisty LB like the current Muse.
With the FE--you don't get that blurred edge as much---even wide open at f/4.0--but a different look than I get with my linear 15mm FE.
Diane
Diane B
I am not the OP, but I have been using the Op Tech wrist strap and very comfortable with it on the EP1 (and now 2).
http://www.optechusa.com/product/detail/?PRODUCT_ID=6&PRODUCT_SUB_ID=&CATEGORY_ID=4
What I also like is I got the one with the quick release so that I can change it to a neck strap when I wish very quickly.
http://www.optechusa.com/product/detail/?PRODUCT_ID=20&PRODUCT_SUB_ID=&CATEGORY_ID=4
They are both rated at up to 2.5 lbs so even with the Lensbaby Composer and the FE Optic they are still good - though I am a bit more careful with that combination on the EP2.
Steve
Thanks for the info on the wrist straps.
Steve
Bill Harris Senior Member • Posts: 1,945
Interesting.
I like the effect, in particular the picket fence and more so the 'earth from above' book photo. Nice Diane.
