canon 50 1.4 or something else for that price for portraits?
Started Dec 7, 2009 | Discussions
lukx
lukx Regular Member • Posts: 226
Does cannon has something better than 50 1.4 in similar price for portraits?
 lukx's gear list:lukx's gear list
Canon EOS 5D Mark III Canon EF 50mm f/1.4 USM Canon EF 85mm f/1.8 USM Canon EF 24-105mm f/4L IS USM
John A Clark Senior Member • Posts: 1,518
You might want longer for portraits?
Portrait are usually done with 80 - 135 mm to make them appear 'flatter' - with a 50, you get closer (especially head-shots) resulting in 'larger' noses ...
Beauty is only a light switch away ...
http://www.clarkfamily.com.au
 John A Clark's gear list:John A Clark's gear list
Sony RX100 Canon EOS 5D Mark II Leica M9 Canon EOS-1D Mark IV Sony Alpha a7R +23 more
Mark van Oostveen Regular Member • Posts: 365
Re: You might want longer for portraits?
85mm 1.8
kind regards Mark
Time is Critical.
Andreas Helke Senior Member • Posts: 1,204
Re: canon 50 1.4 or something else for that price for portraits?
On a crop camera 50mm is just about long enough to be a good portrait length. On a full frame camera its a bit wide but still somewhat usable. The 85 f1.8 has better image quality wide open much better build quality and probably a better autofocus. So its a much better choice as a portrait lens for about the same price.
verybiglebowski
verybiglebowski Veteran Member • Posts: 3,970
Maybe also EF-S 6O 2,8 Macro can be taken into consideration if 85 is too long for you. But if not, I agree that EF 85 1,8 is just outstanding piece of glass for portraiture for its price.
 verybiglebowski's gear list:verybiglebowski's gear list
Sony Alpha a7R Sony Alpha a7R II Sony Alpha a7R III Zeiss Otus 1.4/55 Zeiss Otus 85mm F1.4 +2 more
lukx
OP lukx Regular Member • Posts: 226
Thank you all. So 85 for Christmas
http://lukx.zenfolio.com/
http://www.lukx.com/
lukx
Just one more question, is this 85 focusing fast enough for sports (squash)?
The 85 f1.8 has the reputation to be one of the fastest focusing Canon lenses.
Trevor Sowers
Trevor Sowers Contributing Member • Posts: 866
You bet.
It doesn't get any faster. I use it for volleyball.
 Trevor Sowers's gear list:Trevor Sowers's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS Rebel SL2 Canon EF 24mm f/1.4L II USM Canon EF 28mm f/1.8 USM +19 more
Joe Photo Lover Veteran Member • Posts: 3,040
A little more information:
While 50mm on a Canon crop camera will produce a field of view the same as an 80mm lens of a full frame camera there is another factor to consider. The 50mm lens that you mount on your crop camera is still only a 50mm lens so the image that hits the sensor produces a subject size that equals an 80mm lens but the distance perspective is still that of a 50mm lens. Therefore, some may feel that 50mm is too short a lens for a traditional portrait. It could produce large noses, hands, etc.
With a little care, this shouldn't be a problem but the photographer should be aware of the issue. For a portrait 80mm to 100mm is the classic portrait length but these lenses can at times be too long for indoors in a typical apartment setting.
Actually the problem is much greater when using a 17 to 28mm setting on a crop camera than it is at 50mm setting.
Sal Baker Forum Pro • Posts: 10,716
Are you on a crop camera or FF? I have the 50/1.4 and the 85/1.8. On a crop I rarely used the 85/1.8 because it was too long for indoor use. On FF the 85/1.8 is marvelous, but for contextual portraits (not extreme head/shoulder shots) the 50/1.4 looks good at f/1.8 while the 85/1.8 needs to be above f/2 to look sharp.
They're both good affordable lenses for either format.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Fujifilm X-E2 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R +2 more
richj20 Veteran Member • Posts: 6,276
I've heard that before, but I find that @f/1.8 looks pretty good:
regards,
-rich
Careful photographers run their own tests.
 richj20's gear list:richj20's gear list
Panasonic Lumix DMC-GX8 Panasonic Leica 100-400mm F4.0-6.3 ASPH Sony Alpha a7R II
Trevor Sowers
Mine looks sharp at 1.8 as well!
Of course this is relative and some people are just pickier.
I shoot mine wide open with not hesitation (something I won't do with my 50 1.8).
lukx
yes I'm on crop (7D) hmm, so now you got me thinking maybe 50 ?
lukx
Basically I'm usually standing 5m, (16 feet) from center of the court (squash). So for this case 85 or 50 ?
Gene L. Veteran Member • Posts: 3,788
At 16-ft., 85mm will make a fine portrait lens. It won't give enough field of view for team shots, but should be about right for isolated shots of individual players.
My 85 f/1.8 does not get much use because it is too long for indoors. The last time it got used was for some baby portraits. I was around 8-ft. away for full-length portraits of a 6-month old. Outdoors where there is more room, the 85mm focal length works well.
-Gene L.
http://www.ttl-biz.com
http://www.studiography.blogspot.com
 Gene L.'s gear list:Gene L.'s gear list
Canon EOS 60D Canon EOS 60Da Canon EF 85mm f/1.8 USM Canon EF-S 60mm f/2.8 Macro USM Sigma 10-20mm F4-5.6 EX DC HSM +3 more
