D3s Sensor Data - relative to D3
Started Nov 26, 2009 | Discussions
MOD Marianne Oelund Veteran Member • Posts: 7,856
Wouldn't you know it: The first thing Marianne does with her new D3s, is to take a bunch of photos of a blank wall!
I'm glad that I did, though, because it's yielded some interesting data to share with everyone who's curious about how Nikon endowed the D3s with its high-ISO performance. I hope you will find this report to be worth my staying up until 1am to finish the set through ISO 12800.
Base ISO
This was the first check to make. If the new sensor has much improved quantum efficiency, this could result in the base ISO rising, so I wanted to make sure that ISO 200 is still a "real" ISO. The check came out good; just as with the D3, ISO values below 200 are artificial, but from 200 and up, the RAW data scales linearly with ISO setting, given a constant exposure.
Full Well Capacity and Quantum Efficiency
I re-tested both of my D3 bodies, plus the new D3s, for this - just to make sure I produced a valid comparison. For some obscure reason - sunspots or moon phase or other strangeness - photons are behaving better today, and I achieved higher FWC results for my D3's than I have before. Because of this discrepancy, I am only going to report relative performance between the D3s and D3, instead of giving absolute measurements.
To make a long story short, I found a 37% increase in quantum efficiency for the D3s, i.e., given the same exposure, the D3s collects that many more photons in each sensel. That is almost 1/2 stop improvement. Along with that increase, the full well capacity has gone up by just about the same factor, which is the reason why the D3s keeps the same base ISO.
The Q.E. improvement will give the D3s that 1/2 stop advantage in shot noise across the entire ISO range, and across the tonal range as well. It isn't a huge change, but I would say it is still important, as it does affect apparent noise levels in the entire image.
Color Filter Array
So far, the data I have suggests that the color filters haven't changed. At least, I know the R:G:B ratios seen by the D3s for my light source are essentially identical to what the D3 sees. Additional testing with various subject colors will be needed for confirmation that the CFA is indeed the same.
Low ISO Performance
At low ISO, the camera's DR is limited by the A/D converter S/N ratio. It appears that the same converters are being used, as I find no difference in DR from ISO 200-400.
Higher ISO Settings
As we proceed up the ISO scale from 800, the D3s starts to acquire a substantial advantage over the D3, due to improvements in read noise. The behavior of the D3 with regard to read noise, is that it scales with ISO, from 800 and up; this is equivalent to a constant read noise measured in electrons.
The D3s design is a significant departure in its behavior as gain is increased for the higher ISO settings. As gain rises through the ISO 800-6400 range, read noise referred to electrons gradually decreases, and at 6400, it is almost down to half of the D3 noise level. This improvement, combined with the 1/2 stop gain in shot noise performance, results in a DR advantage of up to 1.5 stops for the D3s, compared to the D3.
Here is how the D3s DR compares to that of the D3 over this ISO range:
  • ISO 800 - D3s +0.3 stops
  • ISO 1600 - D3s +0.7 stops
  • ISO 3200 - D3s +1.2 stops
  • ISO 6400 and 12800 - D3s +1.5 stops
Above ISO 6400, D3s read noise is holding constant in electron units, which means it will show a steady DR decrease of one stop, for each one-stop increase in ISO (which is how the D3 behaves from ISO 800 and up).
In summary, the D3s shows modest improvement at low ISO settings due to the 1/2 stop reduction in shot noise (which however does not improve the noise level in blacks below ISO 800). There is moderate improvement in the ISO 800-1600 range, and substantial improvement - more than a full stop - from ISO 3200 and up.
I suppose I can live with that!
Ralf Ronander
Ralf Ronander Contributing Member • Posts: 797
Re: D3s Sensor Data - relative to D3
Just one Q:
how can more captured photons give less shot noise?
Bill F. Regular Member • Posts: 183
Looks to be a very nice and worthwhile improvement on an excellent camera to begin with, especially for an "s" upgrade. I can see where these benefits will be very important for photographers who are constantly shooting at ISO 1600 and above. The new improvements allow the D3s to compliment the D3x even more so than the D3 did. Thanks for sharing your results.
Bill
rhlpetrus Forum Pro • Posts: 27,171
Thanks Marianne, great report, and quite surprising, I thought most of the improvement was coming from ADC and some tricks, but your tests show more is actually happening, indicated by the low ISO 0.5stop gain.
Base ISO
Great result!
Color Filter Array
Very good, Nikon hasn't needed to reduce CFA strength, thus weakening its filtering properties, to improve high ISO (as some companies seem to do ;)).
Low ISO Performance
I think Iliah or Emil have mentioned that D3 already could use 16 bits at low ISOs. Hopefully they'll bring that in a D4 or D4x.
Higher ISO Settings
Outstanding! Visually, from this test (ViewNX conversions), I note about 1 stop advantage in the 6400 to 12800 range:
so, given sample variations (+- 1/3 stop error margin), within your measured values.
Who can't? Great job by Nikon
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
jeff-c Senior Member • Posts: 2,096
1.2 - 1.5+ stops improvement is also what we are seeing in real life comparision.
This is great news and confirms Nikon's claim about the redesign of the sensor.
 jeff-c's gear list:jeff-c's gear list
Nikon Coolpix 990 Sigma DP3 Merrill Nikon D50 Nikon D700 Olympus PEN E-P1 +26 more
jb_va2001 Veteran Member • Posts: 7,741
Thanks Marianne. Impressive results. /nt
Base ISO
Color Filter Array
Low ISO Performance
Higher ISO Settings
gefrorenezeit Contributing Member • Posts: 564
Even not in the course of getting a D3 like Nikon in the next future (having a D700 and a 1DsMkIII - which is more then sufficent for me ATM) - it was a very interesting read. Thanks for your efforts - very much appreciated!
Andy
whatever you do - do it with passion.
http://www.gefrorene-zeit.de
 gefrorenezeit's gear list:gefrorenezeit's gear list
Sony RX100 VI Sony a7S III Leica Noctilux-M 50mm f/0.95 ASPH Sony E 20mm F2.8 Sony FE 70-200 F4 +3 more
djsphynx Contributing Member • Posts: 542
While I didn't understand everything in your short essay, I would like to thank you for your efforts in providing some good information to the community.
Hats off.
R
Base ISO
Color Filter Array
Low ISO Performance
Higher ISO Settings
Kaj E Forum Pro • Posts: 10,541
Ralf Ronander wrote:
Just one Q:
Photon noise decreases with more photons. Read up on Poisson distribution.
The read noise is addressed later down in Marianne's post.
Kind regards
Kaj
http://www.pbase.com/kaj_e
WSSA member
It's about time we started to take photography seriously and treat it as a hobby.- Elliott Erwitt
pixelpepper Regular Member • Posts: 323
Thank you, Marianne. A useful piece of work on your part, and an incredible achievement on Nikon's. A reduction of read noise by a factor of two puts it up with Canon's latest, but the really amazing part is the 37% increase in QE, over a sensor which was already the best in the business for QE.
You haven't, by any chance, got the figures in electrons?
Base ISO
Color Filter Array
Low ISO Performance
Higher ISO Settings
Just one Q:
He's right, the noise increases as the number of photons, but only as the square root of the number, so the signal to noise ratio increases as the square root of the number of photons.
Paradoxically, the magnitude of shot noise is highest in the brightest areas, but you can't see it because its masked by the signal. That is the basis of Nikon's lossy raw compression, not so much encoding precision is needed in bright areas because the dithering of the noise means that the number of useful levels is smaller.
photoforfun Veteran Member • Posts: 6,084
Thanks Marianne for your efforts, again.....
...and congratulations with your technical background, it's both a pleasure and highly interesting to read you.
Kindest regards,
Stany
http://www.fotografie.fr/
http://www.fotografie.fr/fotoforum/index.php
I prefer one really good picture in a day over 10 bad ones in a second...
antonoat Veteran Member • Posts: 3,786
Hi Marianne
I'm not going to pretend I understand this at your level but I think I can grasp what you are saying.
Thanks for taking the time and effort to share your findings, I consider myself a photographer and not a scientist but from your expertise comes a further understanding that's for sure!
Best regards
Tony
http://www.wildoat.zenfolio.com
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,683
Thanks! Others are saying the same thing!
Very interesting information, Marianne.
Thanks for the great post.
Steve Bingham
http://www.dustylens.com
http://www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Sony RX100 VII Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D +33 more
drip01
drip01 Veteran Member • Posts: 3,057
Nice work
Do you happen to have data by color channel?
It appears to me your definition of QE is much broader than the classic one. But that's okay. By knowing the spectral response, we may know what's behind the improvement.
 drip01's gear list:drip01's gear list
Sigma 150-600mm F5-6.3 | C Sony a7R IV Canon EF 600mm f/4.0L IS USM Canon EF 24-85mm f/3.5-4.5 USM Canon EF 70-300mm f/4.5-5.6 DO IS USM +3 more
bikinchris
bikinchris Forum Pro • Posts: 21,640
Easy explanation
Easy to explain. Your D3 are bodies are jealous of the D3s, so they are on good behavior.
Don't turn your back on them, they will gang up on the new kid!
I am an expert at contradicting myself. Just wait a while. It will be evident.
Chris, Broussard, LA
 bikinchris's gear list:bikinchris's gear list
Nikon D4S Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +1 more
M Lammerse
M Lammerse Forum Pro • Posts: 11,607
It is very understandable information,
Even to me
Thank you for sharing.
Michel
Base ISO
Color Filter Array
Low ISO Performance
Higher ISO Settings
Disclaimer: Posts written by me are my views, ideas and opinions only, and should not be taken as facts, unless stated otherwise.
Light is eveything
http://www.fotopropaganda.com
http://www.fotopropaganda.nl
http://www.pbase.com/photopropaganda
sebastian73 Contributing Member • Posts: 598
Re: D3s Sensor Data - relative to D3 / * AF speed test *
Thank you very much for the test Marianne
So, I'm also interest in the AF speed test.
Nikon D3, D700, AFS 17-35/2.8, AFS 24-70/2.8, AFD 85mm/1.4, AFS 105mm/2.8VR, AFS 70-200/2.8VR, TC-1.4E II, SB-800
Gitzo GT2540 tripod, Markins M20, Markins TB-20, Manfrotto Neotech 685B monopod with RRS clamp
my gallery: http://www.fotocommunity.de/pc/pc/mypics/19199
 sebastian73's gear list:sebastian73's gear list
Nikon D4 Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 200mm f/2G ED-IF VR +5 more
Jola013
Jola013 Senior Member • Posts: 1,851
Thanks !!!
Great effort !!!
Bill_Mellen New Member • Posts: 7
Thank you
Thank you for this succinct review of the D3S v D3. It is educational, informative and most helpful.
Bill
http://www.billm7.smugmug.com
