On display calibration instruments
Started Nov 18, 2009 | Discussions
Iliah Borg Forum Pro • Posts: 29,053
http://lists.apple.com/archives/colorsync-users/2009/Nov/msg00175.html
http://lists.apple.com/archives/colorsync-users/2009/Nov/msg00204.html
For the purpose of printing, setting 0.45 to 0.5 cd/m^2 as a black point is quite correct.
lovEU Veteran Member • Posts: 3,176
Re: On display calibration instruments
Having read both the posts I'm not sure what you're hinting to -- maybe that such black point makes sense to avoid problems the devices can cause at lower black point values? If I didn't get it wrong, would that suggest to set 'black luminance" in a software like Display 4 manually to 0.45 cd/m2?
regards, eric
OP Iliah Borg Forum Pro • Posts: 29,053
There is an urban legend that colorimeters are better suited to calibrate monitors. This legend is disproved yet again in the referenced posts.
Many people complain that their monitors calibrated with different colorimeters do not match. That is especially the case when Spyders and i1 Display devices are used.
Any device, be it a camera, a colorimeter, or a spectrophotometer, adds noise in shadows. Setting black point below 0.5 cd/m^2 is impractical in most cases, because not only deepest shadows are read wrong (noise); but dark tones too are getting distorted while smoothing tone curves in a profiling software. Error in readings from the deepest shadows propagates up to Zone III.
It is extremely important to calibrate in complete darkness, otherwise the light leak through the panel distorts the calibration.
It is extremely important not to press the device hard against an LCD screen, it must just touch it.
It is important to calibrate to the same gamma as the gamma in the working space - 1.8 for ProPhoto and like, 2.2 for Adobe RGB/sRGB, L* for ECI RGB v.2 and like. If most of the work is done in Lab, L8 is the preferred tone curve. Thus screen posterization caused by gamma adaptation is avoided.
It is important to verify calibration and profiling; and for verification it is better to shift the device from the point where the calibration took place. Results of verification should be in the green zone. Some yellow is acceptable, but no orange or red is OK.
Monitor must be warmed up before the calibration, that is left to stand for one hour with the desktop filled with middle grey (L about 50, or RGB about 118..121).
While I understand the wrong-reading problem …
I don’t understand how a device adds noise. How does it work?
Would be interesting to get to know how many people are doing so -- not me, until now.
I’ve done that (pressing) once in my first calibration attempt when the Huey came out -- the result still can be marveled on my old monitor
Accidentally, I’ve done right using aRGB mainly and having gamma at 2.2.
OT: I’m not sure if it is a good idea to use aRGB when handling raw files saved as Tiff’s in Photoshop or LR. So, better change to ProPhoto and set monitor to 1.8 then?
Great advice as well, such easy but I had never thought about it.
It's new to me to let a monitor warm up with middle grey, makes a lot of sense.
Thanks for sharing, Iliah. And btw, a pity I couldn't I read such advice from i1d2 "manual"... (but maybe my fault and I didn't find it at their website)
regards, eric
It is the same problem as with the sensors in cameras - readings from the shadows are unreliable. There are some other critically important problems that must be taken into account - fading of the filters in colorimeters and temperature drift of both colorimeters and spectrophotometers. I actually let the device sit on the monitor during that hour it takes a monitor to warm up.
I'm afraid very very few.
Why not? I actually use ECI RGB v.2 or modified with L* BetaRGB most of the times.
No monitor can display ProPhotoRGB even remotely close. If you are not editing by numbers, I see no real reason to use ProPhoto RGB. But if you are going to use it, it is better to have one of the monitor profiles set with gamma 1.8. Creating a group of 3 profiles for each 3 common gamma settings, 1.8, 2.2, and L* is a good way to address the problem. I prefer to use v.4 profiles.
Generally, it is easier to sell something that appears as a push-button solution, at least on the surface. That is why detailed calibration procedures are rare and not encouraged by manufactures.
Fading of the filters?
What is the reason for the fading? I guess the filters are made of plastics, so is it a problem with evaporating softeners? Is it caused by the intended use of colorimeters and maybe increased because filters get warm when placed on the surface of the monitor?
And, could the fading slowed down somehow?
regards, eric
