7D, "100% field of view" is NOT true
Started Oct 30, 2009 | Discussions
JJ Park New Member • Posts: 5
I have tested my 7D OVF frame coverage.
I concluded that 7D's field of view is under 98%, not 100%.
I'm very disappointed.
I think "100%" frame coverage means at least over 99% not under 98%.
I think "100% frame coverage" is an exaggerative advertisement.
Peace On Earth Contributing Member • Posts: 699
Re: 7D, "100% field of view" is NOT true
oh dear .. that's the feature I am looking forward to !!!
http://www.holeepassion.com .. photo gallery coming soon
Daniel Clune
Daniel Clune Veteran Member • Posts: 3,453
I will wait for pop photo who actually have test equipment let us know the true coverage. Exactly how did you come to this conclusion. Eyeballed it?
http://www.pbase.com/dc9mm
 Daniel Clune's gear list:Daniel Clune's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Epson Stylus Photo R1900
dimakitsov Forum Member • Posts: 65
isn't it only true for a certain lens, something like 50mm f/1.4 focused at the infinity?
OP JJ Park New Member • Posts: 5
I don't have enough equipment for testing frame coverage.
I am not professional photographer nor engineer.
I tested whith my eye, so I hope somebody test 7D's OVF frame coverage with precise method.
MomEngineer Contributing Member • Posts: 920
I think that is only true for the VF magnification not the field of view.
Pam
mailman88
mailman88 Veteran Member • Posts: 6,277
Pixel-peepin... field of view, Great!
Gotta love Canon forum...we peep everything!
 mailman88's gear list:mailman88's gear list
Canon EOS 7D Canon EOS 30D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 28-135mm F3.5-5.6 IS USM Canon EF 200mm f/2.8L II USM +4 more
Re: Pixel-peepin... field of view, Great!
I hope I understand this. I want whatever I see on the OVF to be what on my photo. Well, the logic should be ?
Otherwise, the advertising is a little misleading ...
http://www.cipa.jp/english/hyoujunka/kikaku/pdf/DCG-002_E.pdf
This is CIPA(Camera & Imaging Products Association, Japan) guide line.
See page 13, view finder-coverage/field of view.
I did my test under that condition.
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Clearly yours is defective. Return it.
Phil .. Canon EOS 7D, 40D; G11, SD700IS; Panasonic LX3, ZS3/TZ7
http://www.pbase.com/phil_wheeler
http://philwheeler.net
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Sony RX10 IV Panasonic ZS100
tko Forum Pro • Posts: 13,417
your 3rd post LOL
You are worried about a 2% difference? I doubt you can even measure it to within 2%. What method did you use?
Jeez, a new camera and everyone pops out of the woodwork.
Re: your 3rd post LOL
English is not my native language. So I have not posted here often. Just read posts.
As mentioned, I'm not expert. But, I think specifiaction and advertisement is a important promise between manufaturers and consumers. I think the Gap of the cost between 100% and 98%.
Maybe that problem is only applicable to my camera.
I took lots of pictures to find out the field coverage of my camera. But there are limits to my abilities.
If have time, I hope other people test it.
Nathan F Regular Member • Posts: 116
Agreed. It is important to hold all manufacturers to task. If Canon is making claims that aren't true, that is simply not acceptable.
And for the record, I own a 7D.
BSchultz Junior Member • Posts: 30
Well, to refute your claim, I have found that with a 1.4 50mm the viewfinder is truly 100%. In fact, I can literally place my right eye in the viewfinder, and open the other one and see almost normally with no difference in the images from either eye.
I didn't quite believe the 100% either at first, but that experience shocked me!
(And yes, I have also compared on computer screen to LCD to viewfinder)
davel33 Senior Member • Posts: 2,266
what Canon said ->
The spec on the Canon web site says "approx. 100%" and the manual that comes with the 7D says "approx. 100%". Anyway when I look through it, the VF on the 7D is AWESOME compared to my old 30D, 350D and 300D.
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 24-105mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon RF 24-240mm F4-6.3 +29 more
Klonk Forum Member • Posts: 79
Wake up..
Have you ever found any advertisement that was 100% true and not at least lets say a bit optimistic???
Well I haven't.
And here 100% are maybe optimistic (or measured on some special conditions which should be found maybe on the datasheet. Unless you don't the test with the exact same conditions/lenses etc. you mighht not get the same result.)
Regards
Karl
UCSB
UCSB Contributing Member • Posts: 993
I did a quick test and it sure looked like 100% to me.
Bill.
 UCSB's gear list:UCSB's gear list
Canon EOS 5D Mark III Canon EOS M Canon EOS M3 Canon EOS 5DS R Canon EOS M5 +25 more
nothsafoto Regular Member • Posts: 419
In your desperation to find fault.....
this is the most absurd thing to pick on. It shows you are ill suited to photography which is essentially a creative medium (unless you are a scientific photographer). I have successfully managed to compose photographs with cameras of leeser OVF coverage than the 7D as I have learnt the limitations and can overcome them without any trouble.
The problem with people today is they don't want to have to think for themselves. It will soon be the case that you will want a camera that you tell to go take a picture and it does without you needing to get out of your bed.
Pathetic.
Robbie
Canon Can...Can you??
ESfishdoc
ESfishdoc Senior Member • Posts: 1,896
Re: In your desperation to find fault.....
I guess I'll send mine back... darn...
My Flickr Photostream Slideshow
http://www.flickr.com/photos/33755787@N03/show/
My Blog:
http://esfishdoc.blogspot.com/
 ESfishdoc's gear list:ESfishdoc's gear list
Canon EOS 5D Mark III Canon EOS 6D Canon EF 24-70mm F2.8L II USM Canon EF 24-70mm f/2.8L USM Tamron SP 24-70mm F2.8 Di VC USD +6 more
I don't know why you are so generous to 7D, I think "specification" must be precise. In Japan, lots of people are discussing about 7d's OVF field coverage issue.
http://www.canon-dslr.net/digi_bbs/wforum.cgi?list=tree&no=64044&reno=no&oya=64044&mode=msgview
http://bbs.kakaku.com/bbs/K0000055429/SortID=10341660/
you can translate it by google.
I'm not japaness.
