Re: Seriously doubt it's that simple...
Mark H
wrote:
Your description makes it sound simple - but the underlying 'problem' probably isn't.
I seriously doubt that Canon are simply neglecting to do something that basic and simple.
As I'm sure you know, Canon's sensor technologies are quite sophisticated - supposedly with both 'fixed pattern noise' and 'random noise' reduction mechanisms built in to their CMOS sensor designs, on a per-pixel basis.
http://www.usa.canon.com/uploadedimages/FCK/Image/White%20Papers/Canon_CMOS_WP.pdf
You seem to have a quite a faith in corporate cohesiveness and integrity. Canon consistently says things which are not correct in their white-papers. For example, they said that the bigger pixels in the 5D and 1D2 make for better high-ISO performance than the 20D pixels, because the former, being bigger. collect more photons. The fact is, all three collect the same number of photons with the same exposure. The 1D2's real benefit was lower banding noise, and higher contrast from the lenses, with a weaker AA filter and larger pixel pitch.
Perhaps 'the problem' here is quite simply that there is a fault and/or quality issue.
No kidding. And I solved it. Coarsely of course - I just did a quickie, but the accuracy can be improved, and splitting the blind pixels to both sides of the columns would eliminate ramping better, which, I believe, may account for some of the small amount of vertical banding remaining in the lower image.
You point out yourself that the 'masked' pixels in the top '~32 rows' don't work as an effective 'mask' for subtraction - there probably is an explanation for this, but we will probably never know it.
What difference does it make? 100 rows from the bottom works very well. If Ii were to have these pixels painted black in my camera, I could do this with every image. Why doesn't Canon do this right when anyone else can?
Canon is either stupid, apathetic, or malicious. There is no noble excuse.
Developing that idea though (purely hypothetically) - possibly, a subtraction has already been carried out on the main unmasked area, and you might therefore be trying to double subtract - but at this stage I/we are just extrapolating on speculation.
It doesn't matter what has already been done - the fact is, it wasn't done right, if there is still simple pattern left. The only mystery with the top border is how Canon managed to mess it up so badly.
I can't fathom the mentality of someone who sees such solid evidence as this, and says there must be some insurmountable problem as an explanation. Get with Reality; Canon doesn't care - and they're not going to care if all their toadies keep defending them.
John
