Ghosting on 500L?
Started Oct 14, 2009 | Discussions
Luis Villablanca Senior Member • Posts: 1,454
Ghosting on 500L?
Last week I bought a used copy of the 500L at KEH (LN- condition) .
Most shots I've taken are fine, but today while processing some shots I noticed some strange ghosting effect.
Does anyone know if this is normal? or is this a defective copy?
I am trying to decide if I should return it.
Here is the unprocessed shot. The ghost image is very very faint:
Here is the same image after tweaking curves and contrast to enhance the ghost:
Thanks,
Luis
MoultonP Regular Member • Posts: 164
Re: Ghosting on 500L?
Looking at the ghosted image it seems to be different from the main outline of the bird suggesting it was captured at a different point in time (albeit very close) The lens couldn't do this. That would have to be either something to do with the shutter or the memory card.
Have you tried looking at the images taken immediately before and after to see if any match the position of the bird in the ghost image?
Maybe try a different memory card or try the lens on another body.
Aussie Rod Senior Member • Posts: 1,034
What MoultonP is right. They look to be 2 different images. The main one has the left wing up and the shadow seems to have the left wing down..
photonius Veteran Member • Posts: 6,895
Thanks,
Luis
cool effect, that's one for the Parapsychologists, those that believe in auras, orbs etc.
I agree this does not look at all like a problem of the lens, it looks like a different shot.
But - while memory cards can go bad, it seems very unlikely that you have an "analog effect" with a digital card, you cannot write a byte of data, and mix it with an existing old byte of data on the card.
The most likely effect seems to be something that looks like "burn in", i.e. when you look at something bright, and you close your eyes, you see inverted ghosts of what you looked at. Likewise, if you have CRT screens, and image can burn in, or linger even after it has been turned off.
A possibility i could imagine is that the sensor of the camera had some residual faint image data (which are analog after all) still on the chip, while acquiring the new image. I suspect the image is part of a series of fast, consecutive shots. i.e. like 5 fps, and the image data is not 100% completely flushed/cleared of the chip before the next exposure.
I have more problem seeing how this could be caused by the shutter, it would have to open partially prior to the real shot - perhaps not totally impossible again with high frame rates. (some "bouncing" due to fast fps??)
Life is short, time to zoom in ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
thien nguyen Senior Member • Posts: 1,369
Since the bird is moving forward here, it's more likely the camera hasn't finished writing data to the buffer before the next frame started to appear.
This could be what Canon has hoped no one will find out
Thien
 thien nguyen's gear list:thien nguyen's gear list
OP Luis Villablanca Senior Member • Posts: 1,454
That's it!
I don't have the previous frame because I erased it during my first review of the pictures, but I have the next one and the burned-in ghost of this frame is still there.
So much for fast fps, huh?
Now the question is, could it be a defective unit or a bug in 7D?
I'll contact Canon and see what happens...
Thanks a lot guys!
Luis
Lemming51
Lemming51 Forum Pro • Posts: 15,277
brilliant diagnosis!
photonius wrote:
... The most likely effect seems to be something that looks like "burn in", i.e. when you look at something bright, and you close your eyes, you see inverted ghosts of what you looked at. Likewise, if you have CRT screens, and image can burn in, or linger even after it has been turned off.
A possibility i could imagine is that the sensor of the camera had some residual faint image data (which are analog after all) still on the chip, while acquiring the new image. I suspect the image is part of a series of fast, consecutive shots. i.e. like 5 fps, and the image data is not 100% completely flushed/cleared of the chip before the next exposure. ...
Is this something that has been encountered by others before? Say with the high rate of the 1D bodies?
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
GordonAtWork
GordonAtWork Regular Member • Posts: 482
Re: brilliant diagnosis!
Perhaps a crippled HD video recording mode is leaking out !!
 GordonAtWork's gear list:GordonAtWork's gear list
Canon EOS-1Ds Mark II Canon EOS D60 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM +9 more
Schwany
Schwany Forum Pro • Posts: 10,169
Good luck
Canon won't admit to anything. Good thing your 7D is under warranty. Otherwise, they'd charge you to tell you nothing was wrong.
This looks sad for the latest version of the digic processing engine. Thanks for finding and pointing this out Luis. Although it is essentially imperceptible on my monitor in the first shot, it's not desirable. Another plus in the 1D column on my next camera list.
Thanks a lot guys!
Luis
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
tko Forum Pro • Posts: 13,687
wrong diagnosis
Umm, if this is true, then it has nothing whatsoever to do w/digic or processing, this would be an interesting issue buried inside the CCD.
I'm sure an imperceptible problem in a unique situation is a good reason to stay away from a camera. You did note how far the image had to be pushed to see the ghost?
But I guess Konica user's are very picky : )
Thanks a lot guys!
Luis
unlikely, it's read in rows/columns so you'd get some kind of stripe/band appearing at one edge.
Thien
Re: That's it!
probably not a bug, it's probably due to the fast frame rate (8) they try to squeeze out of the 7D. As suggested, it's probably in the CCD (the CMOS).
a pixel is a "bin" that gets charged as light hits. To read it out, the charge is read and converted to digital, as that happens the charge goes down to baseline, but that is probably an exponential process, like with a capacitor.
I don't know if they do something to clear any tiny remaining charge, but obviously here, with the fast frame rate, it's not sufficient to remove the charge completely.
Might happen with other fast cameras too, but perhaps nobody noticed.
Or Canon, when testing, missed this, and would now need to do something to ensure complete clearing. (apply some strong drain, after the read out? lower the frame rate).
Thanks a lot guys!
Luis
Schwany
Huh?
What is your Canon employee number? giggle snicker
I shoot with Canon as well. Just tools.
My 40D shutter failed at 12K actuations, and this issue that Luis discovered is a real issue regardless of how perceptible it is. There is nothing unique about shooting at the fastest frames per second setting that a camera can shoot at. It is a typical use of a camera for sports as well as birding. The xxD series has been off my first choice list for a while.
I am very picky, but that has nothing to do with any specific camera brand.
I know Luis. I've been out shooting with him. My comments were directed at him.
The CCD and Digic are very tightly linked. One does nothing without the other. I pretty sure it has a lot to do with software at the machine level in the camera. The CCD is probably not being refreshed properly. Digic is also the camera OS.
Thanks a lot guys!
Luis
bronxbombers Forum Pro • Posts: 18,226
IS twitch?
maybe IS did a tracking hitch and exposed it way over there for a bare fraction of a second?
Thanks,
Luis
Julio Veteran Member • Posts: 4,886
You might be on to something!
3456p?
http://fotoman99.smugmug.com/
pancamo
pancamo Regular Member • Posts: 233
that looks like a camera flaw... hopefully it's just on your camera...
Any reply from Canon?
Also, how did you postprocess to see the ghost?
There are pictures posted in the 7D forum, some of them of BIF, so I thought one could try your enhancement on these shots as well - but one would have to ask if they were done at a fast frame rate.
Thanks,
Luis
Canon said I should send the body in to the factory service for further evaluation.
I also called my dealer and they are going to do an exchange instead.
I hope the next camera will be ok.
To better see the ghost image I just increased the contrast and manipulated the tone curve on DPP.
The ghost could also be seen on the original images after PP. It was quite annoying, so I had to do some cloning to remove it from this one:
Luis
12234563
Look it up : )
The point is, if you magnify and process enough you can always find a flaw. If it's not visible in real life, then why is it a problem? And even if it is a slight problem, I'd still buy the camera w/minor problems that can't be seen 99.99% of the time over one w/lower performance.
Try this. Take any camera is the world, take a blank shot, and use the PS equalize function, and the resulting image will look terrible, showing all types of sensor gunk and other things. Not a real world problem, why fret over it?
CCD are automatically refreshed when the signal is read out. As long as you pumping the signal out they're getting refreshed. There is no way to "partially" read them out, or partially reset them. There isn't an in between, it's the way they work. At the digital control level it's all one's and zero's. If the sensor wasn't getting the right refresh signals there would be a major problem, not something like this. If it means anything, it means the sensor isn't capable of being refreshed fully at this particular FPS and shutter speed, at least not down to the 14 bit level.
How many CCD systems have you designed?
Thanks a lot guys!
Luis
Schwany
Re: 12234563
I'm not fretting about the issue Luis brought up at all. I did find it interesting without a doubt. Luis is a very mellow guy. Last guy to make a wild accusation or stir the pot. He was just looking to see if this has happened to anyone else while using a 500f4. I wouldn't have purchased a 7D as my next camera anyway. It looks like a fine camera with many useful features, but I need a couple of old low performance technology features only the 1D series provides.
Your third Paragraph ends with essentially what I was saying. I just skipped all the techno speak, since I had already started happy hour.
As exciting as it sounds, I think I'll skip your "try this" suggestion.
I believe I've designed as many CCD systems as the average poster at DPReview, possibly a few more. I lost count somewhere in the late 1990's. Thanks for asking..
tko wrote:
Look it up : )
