Can you sharpen this picture?
Started Sep 23, 2009 | Discussions
carlie1 New Member • Posts: 19
http://www.flickr.com/photos/39204337@N08/3946417478/
I took some pics for a friend for her upcoming wedding and this is the one she choose to have made into an 8x10. It is blurry if anyone can help sharpen it I would most greatly appreciate it. He looks as if he also has a smirk on his face can anyone correct that?
Priscilla Messinger Senior Member • Posts: 2,992
Re: My try
Picture is too small to do much. I cropped & brightened it.
Glenn_Sydney Senior Member • Posts: 1,449
Re: Can you sharpen this picture?
two versions.
James Kay Senior Member • Posts: 1,373
My try at it...
Didn't even try to fix the smirk but....
FCAS Member #127
My Gallery:
http://www.flickr.com/photos/jfranciskay
WineO Veteran Member • Posts: 4,321
The picture you posted is too small to warrant much time spent on it. Post a larger version if you want to see a good results. Here is a quick thought from me - how about what I call negative sharpening.
Claude
OP carlie1 New Member • Posts: 19
James Cafferty Veteran Member • Posts: 5,364
If you don't like the changes I made - let me know and I will delete the picture from my smugmug site.
All the best,
Jim
Photographers take pictures, not cameras.
RayGuselli
RayGuselli Forum Pro • Posts: 15,784
Another take
Blurred bg and sharpened subject to add to dof.
Would also suggest you crop from the top.
Ray
 RayGuselli's gear list:RayGuselli's gear list
Nikon D300 Nikon D700 Nikon D750 Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +2 more
twomoocows Regular Member • Posts: 197
Here's my very quick try. Really difficult with such a low res file though. Some shadow/highlight, a slight liquify on the smile and butt (hope that's ok), some dodging and a little sharpen (not much). Needs a little more work on the skintones though. It may be a little saturated, what do you think?
For info, fill flash would have made this much easier, but I'm sure you already knew that. Enjoy.
Michael Edward Rudge Veteran Member • Posts: 7,078
Re: My humble try
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EOS 60D Canon EF 50mm f/1.8 STM Canon Pixma MG5350
imqqmi Veteran Member • Posts: 8,631
The image is too small to judge sharpness, please post the full size.
I've blurred background, sharpened the couple, corrected WB and tone:
Kind regards
Imqqmi
http://www.pbase.com/imqqmi
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm f/1.8 II Canon EF 85mm f/1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
AllanW Senior Member • Posts: 1,286
Here you go!
Sharpened, fixed BG, curves and colour cast.
Chers
Allan
RayGuselli
Cropped, resized and framed
I went for the crop as I suggested above and also removed some of the image to the right to provide a balanced image. Sharpened couple and blurred bg for dof
Hope this is ok
Best wishes
Ray
Focus Photoeditor User Senior Member • Posts: 1,022
two versions:
Sunshine_boy
Sunshine_boy Veteran Member • Posts: 4,823
Re: Here you go! - Let's go further...
Super job Allan, beautiful rendering of lighting and scene.
I just worked on your version on the smirk and one or two other minor adjustments (I hope you don't mind. You keep the copyright!...)
My version (based on Allan's)
Best Regards
Sunshine
Fuji F30, F31, S6500, OLY C4000Z, Canon Film EOS,
Nikon D60, 18-55VR, 18-105VR, 55-200VR, 35/1.8, SB-400
 Sunshine_boy's gear list:Sunshine_boy's gear list
Fujifilm FinePix F31fd Olympus C-4000 Zoom Nikon Coolpix P7100 Nikon D60 Nikon D5200 +2 more
nand
nand Veteran Member • Posts: 3,122
 nand's gear list:nand's gear list
Fujifilm X100F Olympus E-M1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Olympus 12-40mm F2.8 Nikon Coolpix 995 +30 more
Thanks for all the help. You guys are amazing!! You all did a super job!!!!!
