D300s video example: Big Sur
Started Sep 9, 2009 | Discussions
Kevin Nguyen Senior Member • Posts: 1,659
Here are some examples I did using D300s video function. Note I am no pro at this video thing and have never used it before. This was the first time. I am still trying to firgure out all the functionality.
http://www.youtube.com/watch?v=R_53SvKtXhY
http://www.youtube.com/watch?v=BYJZBmAlt48
http://www.youtube.com/watch?v=4rtYJgmqwd0
http://www.youtube.com/watch?v=_gYbbRfTFdY
Example of extreme low light condition
http://www.youtube.com/watch?v=7X7s5FKmZmo
Woodfire Junior Member • Posts: 43
Re: D300s video example: Big Sur
Thanks for posting, Kevin. Every bit of video helps to see what the camera can do.
MinoltaMan78 Contributing Member • Posts: 781
Check the cleanliness of your sensor
Kevin,
Thanks for posting these videos. I've had a D90 since January, but haven't been interested in trying the video feature.
In two of the videos, ones where the sky was shown quite a bit, I saw a dark blob just north of center. Check to see if that appears when shooting stills. Your sensor may need cleaning. Be sure you set the sensor cleaning feature in the camera to work when you turn it off and on.
Good luck with the D300s.
Fred
Switched to Nikon (D90) in January 2009
JTatyosian Senior Member • Posts: 1,765
Re: Great stuff (n/t)
John Tatyosian
Check out my site: http://sites.google.com/site/JTatyosian
OP Kevin Nguyen Senior Member • Posts: 1,659
Re: Check the cleanliness of your sensor
Thanks. It was on the 17-55mm lens and was on the inside. I had to air can that when i got home to remove it.
patrickhall Senior Member • Posts: 1,180
I think to really show what this camera can do you gotta go extreme. You need to put it in an underwater housing and shoot WIDE or shoot with a prime lens like a 1.2/1.4 not a 2.8. I understand the video is new and people want to see what it looks like but it's not any different than the D90 video at all. I've been using my D300s a bit now and hopefully will have some video stuff up soon. Showing a video with everything sharp (f8 or more) looks no different than a normal camcorder. Let's see some crazy DOF and extreme lens usage (macro, lens baby, panning 70-200 at 2.8)!
http://www.wedding-photographer-charleston.com
drent Regular Member • Posts: 256
You will be a pro soon with this camera.
Try moving around a lot slower. The images should move by itself, not by moving the camera. Check real life examples from pros. Panning goes very slowly.
If you have a Mac you can improve the shaking by using iMovie.
See you in Hollywood...
