get rid of camera shake icon?
Started Jun 15, 2002 | Discussions
norbyn Regular Member • Posts: 170
Hi all
I know why the icon apears , but I'd like to know some tips for minimalize or eliminate the efect of it (except the tripod ).
thank's all in advance
Mike K Veteran Member • Posts: 5,525
Re: get rid of camera shake icon?
The icon means that your shutter speed is slow (slower than 1/60? sec) and does not mean that your camera is moving around. The Icon will appear while the camera is on a tripod too. If you are in P mode you can try" program shift" to a faster shutter speed, or go to Tv and input a faster shutter speed, or use a higher ISO or shoot manually or turn on the flash or...one of many strategies to increase shutter speed. Is the effect you are talking about the motion blur from too slow a shutter speed?
Mike K
norbyn wrote:
Hi all
 Mike K's gear list:Mike K's gear list
Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS D60 Canon EOS 6D Canon EF 135mm F2L USM +9 more
OP norbyn Regular Member • Posts: 170
You right ,mike.I didn't know the other stuffs.For my it was just that camera is not still.But I'm learning..:), so thanks..Bdv.., how exactly I change the sgutter speed in "p" mode?Can you please tell me all that strategies?thanks
Mike K
norbyn wrote:
Hi all
CIS Regular Member • Posts: 319
Mike...I am very interested in this as well. How do you do "program shift" to a faster shutter speed in P mode?
Mike K
norbyn wrote:
Hi all
mike savad Veteran Member • Posts: 3,071
norbyn wrote:
Hi all
either speed up the exposure (maybe adjusting it in AV to let more light in for a faster exposure). or bracing yourself. shoot close to the body, lock your arms, hold your breath, and squeeze the button, not push it. if your near a tree use that. use a rail, or even someone's head (you should know them first).
in P mode you can't. you need to turn the dial to AV (for fstops), TV for exposure time, and M to adjust for both.
Mike Savad
Mike K
norbyn wrote:
Hi all
http://www.pbase.com/savad/
http://www.photosig.com/userphotos.php?id=9050
thank's
Thank's all for the advices.I already tryed some., and they work.You guys are wonderful.
Don Ellis Veteran Member • Posts: 3,762
Half-press your shutter button and press .
Let up on your shutter button.
Use your left and right rocker switches to change your shutter/aperture ratio.
Half-press your shutter button again to achieve focus.
Press your shutter to take picture.
This technique keeps your exposure the same by balancing your shutter speed with aperture. You must repeat the process for each shot.
Another advantage of this method is that it gives you a quick readout of the camera's setting preferences which you can use in Manual mode.
Don
 Don Ellis's gear list:Don Ellis's gear list
Canon PowerShot G1
Kristian Salo Junior Member • Posts: 30
Go here for more info
Hi
When I started this was the place I used alot. There is lots of good information for beginners:
http://www.photo.net/learn/
Here is article about the exposure and shutter speeds:
http://www.photo.net/making-photographs/exposure
This is also a good place to go for good tips about good pictures:
http://www.kodak.com/US/en/consumer/pictureTaking/index.shtml
Have fun!
Kristian
thank's all
For all your help
beluga Regular Member • Posts: 432
Hi Don,
What is rocker button? You mean the 4 directional omni button? I tried your steps in P mode but nothing happened. The locked aperture and shutter setting disappeared when I tried.
Beluga
shot.
Manual mode.
Don
omni button?
Yes... I forgot the terminology. Apparently it's "omni selector."
Hmm, don't know what to say. I just tried it again and it works perfectly.
Perhaps you can try it again. I followed exactly the steps I listed below.
each shot.
Failing that, check pages 75-76 in the manual in case my explantion is off (I'm off to bed now).
Sorry it took me so long to reply. These messages tend to disappear fairly quickly. I only found it by doing a search on my name which I do every once in a while to see if I've missed any threads I've commented on.
Let me know if you can't get this to work. It's really quite a useful feature.
Don
Canon PowerShot G1
Hi Don,
Thanks for replying, though it took a long time. No problem.
I know why it didn't work for me now. It's because I left the flash on. It worked when I switched it off. I have 2 questions.
1) What is the effect of different shutter speed and aperture combination?
2) Is I tried them out, some of the combination are displayed red in color on the LCD screen. What does that mean?
Thanks again.
Beluga
Don Ellis wrote:
omni button?
perfectly.
below.
each shot.
commented on.
useful feature.
Don
KenR Senior Member • Posts: 1,600
Hey Mike, there's an idea!
"Excuse me Ms. Hot Looking Babe. I'm a "professional photographer" and I really need to use some part of your body to steady my camera for this critical picture. Strictly professional you understand. If I had some other option I wouldn't be bothering you".
OK .. not politically correct. But we all know men are basically dogs.
Teig New Member • Posts: 1
By changing the aperture ratio, this does help a bit but definitely still not a clear photo. Is there a way to take photos when there is action in the shot? I feel like I want to be able to use this camera for multipurpose (both for family photo shoots as well as recording everyday life with the kiddos) and I'm unable to do either- I've had this camera since it came out and only used a couple of times as it's always blurry! Any help greatly appreciated as I'm debating buying a different camera before starting to take on family sessions.
Thx!
KEG
KEG Veteran Member • Posts: 4,910
Thx!
I am fairly sure that the op resolved their issue at some time in the last 2 decades.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
KEG
KEG wrote:
Thx!
If your camera has aperture priority, shutter priority or M then you could try to keep the shutter speed above 1/60 sec.
KEG
KEG
Supisiche Senior Member • Posts: 2,028
KEG
Supisiche wrote:
Exactly
KEG
KEG
which camera are you using?
Thx!
KEG
