DelphiNikonian
Well-known member
Okay, I picked up a used AF 2X teleconverter (Quantaray 2X AF). Now when I slap a lens onto my D90, the Info display works fine. But when I slap the 2X onto the lens and then put the combination onto the D90, the Info display shows just the underline bars where one would normally see the shutter speed and aperture - or sometimes I get the underline-only for the shutter speed and a "F--" where the aperture should display. I get the same type of display if I turn on the D90 with all lenses removed. Could there be disconnected wiring/cabling in the 2X? And I don't get any response when I switch from "P" to "Auto", "M" or other modes. And the D90 won't fire at all - but as I manually focus the lens, the D90's viewfinder will signal if I'm focused.
Anyone experience this on a D90?
Derek
Derek
