What program do you view your images in?
Started Jul 26, 2009 | Discussions
porsche997 Contributing Member • Posts: 837
I have been using Windows Picture/Fax Viewer as a quick way to scroll though pictures while check focus and exposure. Processing them is done in Photoshop. Viewing EXIF is helpful too.
I also have DPP, ZoomBrowser, and Bridge but rarely use them. I can't scroll between pictures in DPP, I don't like Zoombrowser, and Bridge doesn't display full resolution pictures.
What program do you all use to view your images?
 porsche997's gear list:porsche997's gear list
Canon EOS 50D Canon EOS 5D Mark IV Canon EF 85mm f/1.8 USM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +1 more
Russell Fielding Regular Member • Posts: 160
Re: What program do you view your images in?
Faststone or XNView.
Faststone is great for comparing images side by side, fast magnifying and super quick viewing of camera settings used.
JackM
JackM Veteran Member • Posts: 8,447
Shoot RAW. Use DPP.
I can usually scan through and tell duds from potential keepers in the large thumbnail view.
 JackM's gear list:JackM's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.0 USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +5 more
mache1966 Regular Member • Posts: 186
I generally use Zoombrowser for viewing my photo's. I find it quick to set up slide shows to get the images full size and the fact that it will display raw image files, to me makes it very versitile. However would have to say I would love to double click an image and for it to popup full size and interact seamlessly with DPP, that would be good. Moving on...DPP for any editing at the moment. I currently don't own Photoshop or any other third party software. not in favour of the windows viewers at all, find them to be very poor resolution.
My thoughts.
Martin
Jim Graziano Contributing Member • Posts: 780
I use SmartPix Manager. Good viewer and does limited editing. Batch also, for downsizing etc.
One click loads the file into PSE or other editing program.
Good program, not expensive.
Jim
http://www.pbase.com/jgraziano
OP porsche997 Contributing Member • Posts: 837
Re: Shoot RAW. Use DPP.
The problem I have with DPP for viewing multiple images is the thumbnail size. I don't find it large enough. Once I click an image to enlarge it, I then have to close that new window in order to see another picture. I would like to be able to move with arrow keys/mouse click/etc. from photo to photo and edit as needed.
EDIT: Just found the "Quickcheck Tool". That's what I have been looking for. Image displays large enough, displays EXIF, and can be enlarged to full screen if necessary.
Delbert Contributing Member • Posts: 938
Second FastStone>>>
FastStone Image viewer is the best freeware graphic app going. In addition to great viewing tools, double clicking on a thumb opens full screen, move your mouse all the way to the right and exif data is shown. scroll through an entire folder with your scroll wheel. It's also got the best batch resizing tools.
 Delbert's gear list:Delbert's gear list
Olympus C-4040 Zoom Canon EOS Rebel SL1 Sony a6000 Canon EF-S 55-250mm f/4-5.6 IS Sony E 55-210mm F4.5-6.3 OSS +2 more
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Irfanview on PC; ImageBrowser (Canon) on Mac.
Phil .. Canon EOS 40D, 20D, G9, SD700IS; Panasonic LX3, TZ5; Fuji F31fd.
Pbase Supporter http://www.pbase.com/phil_wheeler
http://philwheeler.net
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
Doug J Veteran Member • Posts: 9,881
The program I prefer for this is Pixort - shows the histogram by channel and the EXIF; select to view either the embedded jpg image or a raw conversion; assign a numeric rating of 1-5 to each photo, creates folders for each rating and then does an auto move if told to.
For simple viewing of raster-type files & RAW I use Faststone Image viewer.
After I've selected the shots to process, I like Bridge if I will use ACR for the conversion, or I use DPP. The workflow with Bridge/ACR is smooth, but for some shots DPP still does the most accurate color conversion.
EDIT: I should add that the comment about color accuracy relates to my 1D mk III.
Best regards,
Doug
Galleries: http://www.pbase.com/dougj
Just birds: http://www.pbase.com/dougj/birds_birds_birds
Wayndom Senior Member • Posts: 1,933
One thing I find annoying about ZoomBrowser is that its "100%" magnification is more like 50%. The same image viewed in DPP at 100% is a bit more than twice the size.
I don't get it, but I don't like it.
I always shoot RAW, and prefer DPP for browsing and processing (unless I need to do some heavy highlight recovery or shadow fill, in which case I use PE).
khoss Veteran Member • Posts: 4,946
ACDSee Pro 2.5 ...
Interesting to see the different workflows each has. I set up CS3 as the external editor program and use ACDSee to weed out the ones I want to work on. ACR is usually sufficient but I do use DPP sometimes.
Kurt
For some random samples:
http://www.pbase.com/khoss/
http://www.pbase.com/susanshaw
http://www.susanandkurt.blogspot.com
http://www.slshaw.info
 khoss's gear list:khoss's gear list
Olympus Tough TG-3 Panasonic LX100 Sony RX100 V Canon EOS 50D Olympus PEN E-PL1 +4 more
MarkNicholas Senior Member • Posts: 1,512
Lightroom
And everything else like cataloging, key wording, editing etc.
 MarkNicholas's gear list:MarkNicholas's gear list
Kodak DC4800 Nikon Coolpix 5700 Canon EOS 30D Canon EOS 6D Canon EF 50mm f/1.8 II +4 more
ZoomBrowser only for downloading for me
The only thing I use Zoom Browser for is downloading, and it does this very well IMO. Plug a CF card into a reader, then 1 mouse click to create a folder based on the date and begin the download. Pretty darn simple & easy.
Best regards,
Doug
Jimmy Drew Senior Member • Posts: 1,477
I too use Faststone and even donate to them...
They do a great job.....I save on http://www.kodakgallery.com/jimmy . I am a poor person so it is a very inexpensive way to view and archive your photos....
Jimmy Drew
 Jimmy Drew's gear list:Jimmy Drew's gear list
Epson Stylus Photo R3000
Just gave FastStone a try ... great program!
Really like it; it does everything I need to do. Now I can view full screen images and check EXIF instantly. Looks like I can also link it so it will open the image with Photoshop/Bridge/etc if I choose to.
guy catelli Regular Member • Posts: 472
Irfanview
it's popular. it's free. and, it's perfect for browsing.
http://www.irfanview.com/
http://piedolatrie.com
'if we knew what we were doing, it wouldn't be called 'research'.' (attributed to Einstein)
dave lines Regular Member • Posts: 357
faststone
I shoot only RAW, I can see the whole photo, delete or open it in photoshop, photomatix or whatever I choose, also the shooting info is right there too, and it is quick and the price is free, DAve
Look,, you might see something worth shooting:
http://www.photographybydavelines.com/
Pat Heuvel Regular Member • Posts: 105
Re: Irfanview
...and it's fast,
"f" key toggles between fill screen and full size,
"e" key shows exif.
did I mention fast?
