ZS3/TZ7: moon with TCs
Started Jul 10, 2009 | Discussions
Ianperegian
Ianperegian Veteran Member • Posts: 3,597
I made an adapter for my TZ7/ZS3 based on the design kindly provided about a month ago by Tom K: http://forums.dpreview.com/forums/readflat.asp?forum=1033&message=32058552
The other day I used the adapter with attached TCs to take some shots of the waning full moon with the ZS3 set at 5MP and AWB. Although at max zoom the ZS3 has a FL of only 280mm compared to my FZ28's 486mm, the ZS3 seems to perform well with TCs, and even stacked TCs. Here's a shot taken with the FZ3 using an Olympus C180 stacked in front of an Olympus C210, giving an effective FL of about 770mm:
Ian
Ianperegian
 Ianperegian's gear list:Ianperegian's gear list
Panasonic Lumix DMC-FZ35 Nikon Coolpix P900 Panasonic ZS100 Panasonic Lumix DMC-ZS60 Olympus PEN-F
timiano Senior Member • Posts: 1,091
Re: ZS3/TZ7: moon with TCs
Well done, that's ace!
Not perfect high quality, but none-the-less, "Way Cool!"
Ianperegian
OP Ianperegian Veteran Member • Posts: 3,597
Thanks! I think it's a very versatile little cam.
Ian
Ianperegian
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 21,986
Very crisp - great!
-Erik
DP Review Supporter.
'He who hesitates is not only lost - he's miles from the next Exit.'
http://www.flickr.com/ohlsonmh/
ANAYV Forum Pro • Posts: 19,454
Wow that came out really good,Ian !!
Better than the moon shots i took last week,with my FZ28 (5mpEZ at around 650mm)
yours has much better detail !
very impressive,considering you used TC's !
Keep shooting
ANAYV
Ianperegian
Thanks! I think the smaller lens on the ZS3 works well with the smaller TCs like the C180 and C210 whereas those TCs on the FZ28 tend to be not so good and give vignetting.
Ian
Ianperegian
Ianperegian
Thanks Erik, I did some sharpening and levels in PP. I thought the result was quite good considering it was stacked TCs which seem to give more CA on my FZ28.
Ian
Ianperegian
