From DXOMark: More pixels offsets noise
Started May 21, 2009 | Discussions
photo nuts Senior Member • Posts: 1,364
Just noticed this:
http://www.dxomark.com/index.php/eng/Insights/More-pixels-offsets-noise !
"Contrary to conventional wisdom, higher resolution actually compensates for noise"
Will this persuade DPReview to change their stance on high pixel density sensors since they seem to hold certain amount of respect for DXOMark.
Phil Askey
Phil Askey Veteran Member • Posts: 9,822
Re: From DXOMark: More pixels offsets noise
"Read it in the Newspaper, must be true"
photo nuts wrote:
Just noticed this:
DXOMark.
Phil Askey
Editor, dpreview.com
 Phil Askey's gear list:Phil Askey's gear list
Leica Q Sony RX10 III Panasonic Lumix DMC-GH4 Canon EOS 5D Mark IV Leica M10 +11 more
dw1337 Regular Member • Posts: 117
"Read it in dpreview.com, must be true"
photo nuts wrote:
Just noticed this:
DXOMark.
Oly Canikon
Oly Canikon Senior Member • Posts: 1,307
Its time that dpreview came forward with a proper analysis of this issue. Lets see the evidence that you base your views on and lets have some informed discussion. Not just sniper attacks.
Makinations
Makinations Veteran Member • Posts: 5,688
I think this is the dpr take on the subject ...
http://blog.dpreview.com/editorial/2008/11/downsampling-to.html
I believe it has been debunked by a few people but as comments are not enabled on that it is hard to tell.
 Makinations's gear list:Makinations's gear list
Canon PowerShot G9 Olympus XZ-1 Canon EOS 40D Panasonic Lumix DMC-G3 Olympus OM-D E-M5 +13 more
kwik Forum Member • Posts: 84
Zing!
Nice one! I read this on dpreview.com though:
http://forums.dpreview.com/forums/read.asp?forum=1018&message=30211624
and it looks pretty convincing. Comments are even allowed. ; )
Richard Butler
Richard Butler dpreview Admin • Posts: 2,842
Ultimately the main dispute is between whether you measure noise at the 1:1 level or at an arbitrary image size. dpreview has always worked at the pixel level because it doesn't make any assumptions for what you're going to do with the images. As soon as we start deciding for you what size and what method you would use for outputting your image, the more quickly the reviews lose relevance - our results are consistent with each other and we provide full-size samples for you to download and process, so that you can see how things work in your workflow.
Richard - dpreview.com
Oly Canikon
But by choosing to stay with 1:1 you are introducing a sliding scale. You give a huge disadvantage to the higher MP camera. When what is relevant is how both cameras would do for a set (arbitrary but the same for both) output size.
Working at pixel level is misleading if the two sensors are a different size. What you are doing is effectively printing an 8x10 from one camera and a 16x20 from the other and saying " oh look this one is noisier."
By the way, I do appreciate your taking the time to respond and having this dialog. I'll keep an open mind as much as I can. Please try to convince me.
cheers
workflow.
I think it's safe to say that you're going to be printing the images. Or, maybe not. Maybe just downsizing them to display on the web.
workflow.
There's no need for "you" to "start deciding" what method anyone will use for outputting their images. DPR consistenly blasts camera manufacturers for raising the pixel count on the basis of increased noise, when, in fact, the overwhelming evidence is that increasing the pixel count is the most direct path to greater IQ.
ck3
ck3 Senior Member • Posts: 2,925
Sorry, but that's not true. While there is nothing wrong with looking at the pixel level there is a lot wrong with looking exclusively at the pixel level. A statement like "High ISO performance worse than 40D" (from the 50D conclusions) does indeed make assumptions about what the user wants to do with the high ISO images - namely compare them at 100% on his computer screen.
tkpatric Senior Member • Posts: 1,893
Re: Zing!
Noise factor is old-fashion. Take the dimension of the picture when you start to see noise as reference.
http://users.telenet.be/patric/
 tkpatric's gear list:tkpatric's gear list
Panasonic ZS100 Sony a6000
BertIverson Veteran Member • Posts: 4,315
Especially since the vast majority of digital photos are shot at low ISO . Indeed others have said that it is mainly the sensor size not pixel density that determines IQ.
Bert
 BertIverson's gear list:BertIverson's gear list
Sony RX10 IV
igb Senior Member • Posts: 2,637
I take you mean "at an other arbitrary image size", no?
dpreview has always
Is that the real reason? Or the fact that in 1999 digicams ouput 0.3 Mp and conclusions derived from pixel level analysis were more meaningful coupled with hard wired resistance to change?
How's looking at an 15Mp image at 100% in a > 2Mp display even remotely relevant?
  • our results are
workflow.
Which is good, and totally uncorrelated with whether or not you noise comparisons are useful and/or your conclusions misleading.
Imagine for a moment that you drop pixel level noise analysis, how much would your productivity increase? 20% more reviews?
My Galleries: http://webs.ono.com/igonzalezbordes/index.html
Lee Jay Forum Pro • Posts: 56,673
Sure you are. You are assuming that the final printed or displayed image size will always be proportional to the original image pixel dimensions.
The other approach is to assume that the final printed or displayed image size will be a constant regardless of original image pixel dimensions.
You can't assume nothing, you have to assume something. Those two above are the most reasonable. You chose the former, virtually every user of their cameras chooses the later. I've never once had a client chose a print size based on the pixel dimensions of the camera with which I shot their image.
Lee Jay
(see profile for equipment)
 Lee Jay's gear list:Lee Jay's gear list
Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III +10 more
Henrik Andersson Senior Member • Posts: 2,454
dimensions.
dimensions.
Eventually DPReview will change their mind, I guess. It's so obvious. For instance when they compare high-ISO performance of cameras.
Henrik
GaborSch Veteran Member • Posts: 7,203
Worthless results, not only DxO
DxO creates comparison results without any practical use; for example downsizing a 21Mpix and a 65Mpix image to 8 or 12 Mpix.
On the other hand, DPReview's dynamic range measurements are of great entertainment value, like when the DR is increasing with higher ISO. In fact, many if not most of their DR measurements are jokes.
The difference
The difference between taking a given print size for the comparison and using the pixel level measurements is, that the latter represents an "ideal" measurement, which can be transformed in other measurement, while the former is good for nothing but the given size.
Please walk me through
the transformation of pixel level measurement into "other measurement"
Steen Bay Veteran Member • Posts: 7,418
Noise and resolution..
workflow.
When you (DPR) measure/compare the resolution, you assume the same output-size, and compare at 'image level' (Lines Per Picture Height). Wouldn't it be reasonable to do the same, when you measure/compare the noise?
Barry Fitzgerald Forum Pro • Posts: 29,888
I don't really trust anything DxO say being blunt.
Near 11 stop compacts for DR, yet nobody manages to get that in the real world!
