f30zoom vs f200exr (exr sn) on iso800 and above
Started May 14, 2009 | Discussions
learning_photography Regular Member • Posts: 229
1st of all, "exr sn" of f200exr produces 6mp and f30zoom is a 6mp camera, it is fair to compare them ;).
f200exr iso 800 exr sn (6mp):
http://www.imaging-resource.com/PRODS/F200EXR/FULLRES/F200EXRhSL_SN_I0800.HTM
f30zoom iso 800 (6mp):
http://www.imaging-resource.com/PRODS/F30/FULLRES/F30hSLI0800.HTM
take a look at the black cloth's patterns on the left, u will notice that f200exr blurred the patterns until virtually non existant but f30zoom retain it although a bit softer than its iso 100.
f200exr iso 1600 exr sn (6mp):
http://www.imaging-resource.com/PRODS/F200EXR/FULLRES/F200EXRhSL_SN_I1600.HTM
f30zoom iso 1600 (6mp):
http://www.imaging-resource.com/PRODS/F30/FULLRES/F30hSLI1600.HTM
this time u will notice that f200exr will "makes" the black cloth totally black without any patterns but f30zoom still retains a rather soft but visible patterns on the black cloth.
there are stronger noise reduction evidence on the f30zoom compared to its lower isos. but based on the above findings, it still produces better details compared to the f200exr which has less noise reduction and with "exr sn".
correct me if i'm wrong, my assumption is, the black cloth can be somehow "used" to represent dark areas. if one is to be picky about low light details, f30zoom is a better choice compared to f200exr.
well, of course, f200exr has much better features like dr 800%, etc, but i'm just pointing out that f30zoom still fares better at high isos fyi, i didn't own a f30zoom (i wish i did!) and was eager to buy f200exr but bumped into imaging-resource.com and hope to share with u all on my findings.
if anyone interested, shall take a look at lx3 samples at imaging-resource, lx3 does very well on the black cloth's patterns too:
iso800: http://www.imaging-resource.com/PRODS/LX3/FULLRES/LX3hSLI0800.HTM
iso1600: http://www.imaging-resource.com/PRODS/LX3/FULLRES/LX3hSLI1600.HTM
EXR Senior Member • Posts: 1,437
Re: f30zoom vs f200exr (exr sn) on iso800 and above
Well I actually see more detail on the F200, especially on the filaments on the right side and more NR on the F30. Overal there is not much to choose between this 2.
Joel Stern
Joel Stern Forum Pro • Posts: 10,926
i though that the F 200 did show both more noise and more detail....it was more real (I have an F30)
zygh
zygh Senior Member • Posts: 1,798
I wouldn't exactly call the 200EXR output as "noisy", much more like "grainy" which is much more pleasing than the soft touch of the 30. There is definitely more detail in the EXR, though grainier. I have the 31fd, it's good and I like it. The 200EXR is, however, quite a piece of work.
 zygh's gear list:zygh's gear list
Nikon D40 NEX5R Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +2 more
Anastasios Papatsoris
Anastasios Papatsoris New Member • Posts: 14
Well, your findings come to no surprise at all. The F30 performs better at higher ISOs, despite the F200's clever pixel grouping in its SN mode. To my opinion the F30/F31fd remains the low light champion and the perfect social camera. In a previous post I was making exactly this point when suggesting 'Why you should keep your F30/F31'.
Anastasios
 Anastasios Papatsoris's gear list:Anastasios Papatsoris's gear list
Canon PowerShot G12 Fujifilm X-T3 Tokina AT-X Pro 11-16mm f/2.8 DX Nikon AF-Nikkor 80-200mm f/2.8D ED Fujifilm XF 14mm F2.8 R +15 more
rax Regular Member • Posts: 413
Quite correct assessment, but...
don't forget, we're really pixel peeping here.
Step back 20-30% or print up to 8x10 and you won't be able see any difference.
However, having said that, if you already have a F3x, then the F200 is not for you... unless you really need to have 5x zoom with 28mm WA, wide DR capability, or IS.
Joel Stern
Re: Quite correct assessment, but...
difference.
or consider a recoh cx1, i am.
Russ Yost Senior Member • Posts: 1,534
Pattern is clearly visible on my monitor.
But thiis scene doesn't seem suited for resolution testing since the objects are at varying distances from the camera - thus some objects will be out of focus!
and with "exr sn".
I prefer to shoot in a dark closet with lens poked into sleeve of a black sweater to block light from the LCD. The result is the noise generated by the camera. Visit my galleries so see results for several Fuji cameras. But currently I have neither of the two cameras discussed here.
too:
iso800:
iso1600:
Russell
Galleries at http://www.pbase.com/russ
That would only be valid without NR.
Right! The result includes the effects of in-camera NR.
For resolution (acuity - fine detail) testing, the subject must be entirely within the DOF, such as a flat chart and attention paid to focussing.
Russell
