Error saving JPG in Photoshop CS2
Started Apr 11, 2009 | Discussions
Alan Hartmann Senior Member • Posts: 2,497
I'm getting an error message:
Could not complete your request because of a program error.
when I attempt to save a file as a JPG. I get through the "Save As" OK, then select the quality level (10) on the JPEG Options screen, then this error comes up.
I've already double checked that I don't have a read-only copy of the file. I can save in other formats without problem, this seems to be limited to JPG only. Running under Vista 64 -- I've been working in this environment for about a month or two without difficulty.
Can anyone offer any suggestions?
Buzzzman Veteran Member • Posts: 3,775
Re: Error saving JPG in Photoshop CS2
Never got that message while saving-I use a mac,though. Are you working in 16 bit mode?
You can't save a 16 bit jpg. Only thing I could think of.
Buzz
OP Alan Hartmann Senior Member • Posts: 2,497
Thanks Buzzzman, but no, CS2 doesn't even include JPG in the list of choices when in 16bit mode or not RGB.
That is the way it is on my Mac. Actually, I didn't think that is what is was- i but gave it a shot anyway. Try saving in in another format( tif of psd)-then open that file up and try to save as a jpg again.
Buzz
i
cspringer Forum Pro • Posts: 19,632
You can edit in 16bit, you just can't SAVE a jpg in 16bit. That is usually the problem people have. They forget to convert to 8 bit for saving.
If you have several copies of the file open (i.e., you Duplicate your work) then it will not save them. You need to change the name or close the duplicate files.
saving.
Thanks, but just one file open, it's 8 bit RGB. Doesn't matter if I change the name either, same error message. It's as if Photoshop has forgotten how to write JPGS.
again.
The problem isn't with the file I'm editing, since I get the same error if I open other files (TIF), do nothing to them, and try to save as JPG.
You might need to reset PS Preferences
also...have you closed PS and rebooted your computer? This often solves the problem. Save file before closing.
saving.
Re: You might need to reset PS Preferences
Did that a few times already. BTW, I have no trouble saving as TIF.
Looked through all the tabs in the "preferences", section, didn't really see anything relevant -- was there something specific you wanted me to reset there??
how to reset preferences
http://www.lancelhoff.com/how-to-reset-photoshop-to-default-settings/
You might also try Windows System Restore.
Additional info
Did some hunting around on the Adobe forums, and found a reference to deleting the user preferences file ("Adobe Photoshop CS2 Prefs.psp" in the "Users\\AppData\Roaming\Adobe\Photoshop\9.0\Adobe Photoshop CS2 Settings" folder). Deleted it, tried again, same error.
Also tried creating a new file and saving as a JPG, that worked -- implying some sort of metadata problem -- the files that cause the problem are from Lightroom. I did find some older (~ 7-10 days ago) TIFs from Lightroom that save as JPG correctly. And the files that are causing the problem today save OK when I use Save for Web.
So I'm suspicious that the metadata in today's files are causing the problem, but I'm not sure what to do about it.
Any other ideas???
The work-around...
Just following up, for the benefit of anyone else that might hit this problem -- the work-around is to remove all metadata from the file. Here's an easy way to do it:
http://photo.net/digital-darkroom-forum/00OBHu
