Date time stamp - canon eos rebel
Started Apr 8, 2009 | Discussions
bmwooo New Member • Posts: 2
How do I turn on the date time stamp? I see the date / time on the menu, but nothing that says on or off.
ChiliPepperD Regular Member • Posts: 218
Re: Date time stamp - canon eos rebel
There is no ON/OFF switch to imprint date/time on your shots.
When you set the date and time (should have been done when you did your original camera set-up), the camera keeps track and includes it in the EXIF data. But, there's no way to imprint it on your photos except by using 3rd party software.
Joe
EOS Rebel XSi, G2, SD450, Konica Autoreflex-T, Olympus 35RC
hansdoddema New Member • Posts: 20
I like the exif data much better, how many times it has happened to me that I forgot to adjust time/date settings after traveling through timezones!
husky91 Regular Member • Posts: 259
There may be many ways to add it to your photos, but I've used Better Jpeg and it works well. It adds the date in any date format you want, font color, size, etc. and it's lossless.
Slaterholdings Regular Member • Posts: 125
From memory you can add it if you reduce picture size to 3mp?
I think...not sure.
At least on the Xsi (450D) that doesn't appear to be an option either via the menu screens or from the Owner's manual or David Busch's book.
Maybe on one of the earlier models??
Joe
Y0GI Veteran Member • Posts: 5,257
Duplicate post. Apparently he is asking about an S-40?
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31543566
Yogi
See my 'Profile' for my current equipment.
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Knallbert Senior Member • Posts: 1,170
NO date/time - that is good. This nonsens kills every picture.
All data included in EXIF you can - if necessary - print in picture f.e. with IRFANVIEW (free program)
Forget ISO, noise, mpixel & other nonsens!
Don't talk about these things like a guru.
Go out, make photos and have fun!
Gene Laratonda New Member • Posts: 2
Would someone with a Canon eos rebel 2000 please share what photos with the timestamp feature on would look like? Specifically, I'm looking for an example using the day/month/year format.
Thank you!
