CC - Sony a700 High Speed Sync with External Flash
Started Jan 31, 2009 | Discussions
GBsoftware Inc
GBsoftware Inc Regular Member • Posts: 253
I was testing my a700 with two Interfit 150w at the ridiculous speed 1/5000 at f4.0
here the result
I have some great result too at the max speed of 1/8000 and f2.8
 GBsoftware Inc's gear list:GBsoftware Inc's gear list
Sony a6000
headofdestiny Veteran Member • Posts: 9,230
Re: CC - Sony a700 High Speed Sync with External Flash
How did you get those speeds?
siddidy Regular Member • Posts: 226
how is this possible
GBsoftware Inc
OP GBsoftware Inc Regular Member • Posts: 253
Amazing isn't it ??? I'll post and explain the trick later
Sony a6000
Ah, you're killin me!
vwgn Senior Member • Posts: 2,106
I am very curious as well....
GBsoftware Inc
Ok, here we go, nothing complicated.
  • Hot shoe. I used a WEIN Safe Sync HSXLD With PC connector (I think you can do it with any Optical Hot shoe trigger)
  • Pocket Wizards for your external flashes
  • SONY HVL-F56AM or HVL-F58AM Mounted on A700 or A900
Mount one pocket wizard on the Optical Hot Shoe Trigger ... well you know what to do next, but NO POCKET WIZARD MOUNTED OR CONNECTED TO THE CAMERA
THE MOST IMPORTANT THING IS THAT YOU HAVE TO SET YOUR SONY FLASH TO MANUAL TO AVOID THE TTL PREFLASH AND THE FLASH HEAD TO NORMAL POSITION (the high speed sync does not work when the Flash head is in bounced position).
When you are shooting outside with strong sunlight, keep the Optical trigger close to your camera in order to capture the light from your Sony Flash.
Also, use some black electrical tapes to cover the optical sensor on your external flashes
Here my setting with 2 Interfit 150w
And one pict taking at 1/8000th sec the flashes were about 5 feet from the backgound (see EXIF)
This weekend I'll try it with more powerful flashes.
That's ALL now you can shoot at any speed, and please reply to this post and let me know your results.
Sony a6000
Robert Lynch Senior Member • Posts: 1,765
Why are you bothering with the PC connector when the PW sits on the trigger's shoe?
GBsoftware Inc
Robert you're right it's no required to use the PC Connector, but since I had some issues when using the PW sitting on the hot shoe (loose connection), so I don't mind having the PC connector as backup.
trigger's shoe?
Sony a6000
Awesome. I have a couple of questions, since I've don't have much insight as to how this works.
1) Do you think that any Sony-hot shoe flash (like Sigma) that has a manual mode would work?
2) Do you think other radio devices, besides Pocketwizards, would work?
3) How does this affect the power of your flashes, if at all?
Thanks a bunch, d
GBsoftware Inc
From what I have already tested I know only Both Sony HVL-F56AM and HVL-58AM work, since they are HS compatible with a700 and a900
I "THINK" any radio devices mounted on THE OPTICAL Hot shoe trigger would work.
3) How does this affect the power of your flashes?
I cannot give you any numbers, but keep in mind with more shutter speed you'll have less power from your flashes, the key is your flashes will be still in sync
Thanks a bunch, d
Sony a6000
Gotcha about the shutter speed vs. power, but I probably won't use much more than 1/1000. Pretty incredible trick. I can't wait to try. thx
BTW, for those wondering, the Sigma 500 DG super does do high speed sync.
GBsoftware Inc
You're very welcome headofdestiny, I don't really need that much speed either, I posted the pict at the "suicidal" speed of 1/8000 just to show that the trick works at that speed.
Gaby
try. thx
Sony a6000
GBsoftware Inc
Cool, did you try it with the sony at High Speed?
sync.
Sony a6000
Not yet. I just looked it up. I use on-camera flash so rarely that I wasn't sure if my Sigma did HSS or not. lol. In fact, I'll have to dust it off, since I think I've only used the flash once.
Are you able to dial down the flash power on the on-camera flash to a low enough point that it doesn't affect exposure?
andrea buso Veteran Member • Posts: 3,319
Great technique and thank you for sharing.
All that pocket wizard gear is still cheaper than a leaf shutter lens from hasselblad and the body that goes with it.
But I guess there is a catch on all this: you need of pointing the Sony flash mounted on the camera toward your subject on order to have the high speed working.
Am I correct?
thank you again for sharing.
GBsoftware Inc
You're welcome Andrea.
All you need is to
1- have the Sony flash mounted on your camera in normal position, the High Speed Sync Does not work in bounced position. Anyway in high speed you'll never reach your subject with your on camera flash. The "Sony 56AM or 58AM mounted on camera" is used only to trigger the Optical HS with the PW mounted in it
2- Keep the Optical hot shoe with the PW mounted on it in range of your Sony Flash Light.
You can have your external strobes plus your subject as far as the PW radio signal can go.
Gaby
Am I correct?
Sony a6000
Am I correct?
GBsoftware Inc can correct me if I'm wrong, but I think HSS is disable when you tilt or rotate the flash head.
I wonder if you could tape the Optical trigger directly to the lens on the front of your flash, and then block the rest of the flash's output with electrical tape or something, and then run a pc cord from the Optical trigger to a Pocketwizard in your....pocket?
GBsoftware Inc
Am I correct?
Yes you're right HSS is disabled when you rotate or Tilt it. Just keep it in normal position
on your flash, and then block the rest of the output with electrical
LOL that's should work, if you don't need the light from your on camera flash on your subject
Sony a6000
