Ricoh Lens Cap for LX3
Started Jan 26, 2009 | Discussions
Waterdoc Junior Member • Posts: 38
I modified the Ricoh lens cap to fit the LX3 in a different manner than previously described. I machined it down about 3 mm .. just to where the tabs are that hold the springs in place. I then epoxied it to the front lens ring. It now screws on and off just as the front lens ring did originally. Works perfectly without any other modifications. I have some photos and more detailed instructions if anyone is interested. All I need is someone to tell me the best way to post them. I do not have a gallery of my own.
Rossuziers
Rossuziers Forum Pro • Posts: 12,855
Re: Ricoh Lens Cap for LX3
http://www.tinypic.com
The Amateur Formerly Known as 'UZ'pShoot'ERS' 'Happy Shootin' Comments, Critique, Ridicule, Limericks, Jokes, Hi-jackings, EnthUZIastically, Encouraged... I Insist!
* rrawzz'a'gmail'dot'com * http://www.pbase.com/rrawzz *
Lx3Fz50Fz30C8080wzE100rsC2100uz
 Rossuziers's gear list:Rossuziers's gear list
Panasonic Lumix DMC-FZ50 Olympus C-8080 Wide Zoom Olympus C-2100 UZ
OP Waterdoc Junior Member • Posts: 38
Rossuziers
Waterdoc wrote:
Test:
Lose the [IMG]'s
This is my first attempt at posting photos. Please bear with me.
http://tinypic.com/view.php?pic=qzfytg&s=5
1. Sand down rim until you get to the tabs that hold the springs.
2. Sand the surface of the front lens ring slightly to allow epoxy adhesion. Mark top of ring.
3. Line up ring top with cap top and epoxy together. Use slow setting epoxy to allow precise alignment.
4. In the photos showing the cap on the camera, I have not screwed it on fully since the epoxy had not cured. When tightened, it aligns much better.
Norm
gsqd Regular Member • Posts: 236
Nice job.
Where's the best place to get the caps from please?
Alex
I got mine from http://www.popflash.com . Really fast service!
Norm
Brilliant - thanks,
A
Anfy
Anfy Veteran Member • Posts: 3,465
Q for Waterdoc
Does tha cap cause shadows when making use of flash, at wide angle?
Ciao,
  • Anfy
I can't find these things in stock anywhere????
Anyone have any idea where to find them?
A
DezM
DezM Forum Pro • Posts: 35,658
gsqd wrote:
Adorama.com
Dez
http://photos.dezmix.com
 DezM's gear list:DezM's gear list
Nikon Z6 II Nikon Z7 II
Thanks Dez but they're out of stock too!
I'll keep looking as I need 2.
A
RussC
RussC Regular Member • Posts: 348
Could you post the more detailed instructions?
RussC
 RussC's gear list:RussC's gear list
Canon PowerShot SD1000 Panasonic Lumix DMC-LX3 Panasonic FZ1000 +2 more
Re: Q for Waterdoc
The cap sits behind the lens so it cannot cast a shadow.
Norm
What is not clear? Here is a photo of the back side of the completed modification. It looks "factory". Do you have any specific questions?
Norm
DezM
gsqd wrote:
I didn't check the site but that's where I bought mine.
Dez
One other comment. Of course, when the lens retracts for Tele shots the blades will collapse over the lens. If this happens, it is a simple matter to unscrew the device. I did not use the original front lens ring for this project. I purchased several from Panasonic.
With the other modification previously described (the push-on) one has to add "sliders" to the blades. However, it does allow Tele with the cap in place. I plan on working with my screw-on cap and see how I can modify it to work in both full T & W.
Norm
One additional comment: If you want to prevent any significant collapsing of the blades ( very slight vignetting at full T) when going to T all you have to do is add some good quality felt pads to the inner side of the blades as shown below. The pads should be as close to the outer aspect of the blades as possible without touching the spring.
Anfy
Re: Q for Waterdoc
http://forums.dpreview.com/forums/read.asp?forum=1033&message=30775341&q=lx3+ricoh+shadow&qf=m
I was referring to a possible "eclipse" due to the lens cap's flaps blocking the inboard flash light.
Ciao,
  • Anfy
Norm
cgladney New Member • Posts: 11
Nice job on the modification Waterdoc.
What tool did you use to sand down the rim of the LX-1?
Thanks, Courtney
