Canon 450D records video too!
Started Jan 22, 2009 | Discussions
Adilka Forum Member • Posts: 97
I've downloaded program from here:
http://valexvir.narod.ru/
Here is result:
http://www.youtube.com/watch?v=5fgRhritWog
Very happy
450D + Tamron 17-35/2.8-4 + Sigma 30/1.4 + Canon 85/1.8 + Canon 50/1.8 + Elan 7E
Weth Senior Member • Posts: 1,291
Re: Canon 450D records video too!
What resolution are you recording at?
OP Adilka Forum Member • Posts: 97
It recodrs about 848х560 (yes its SD, but shallow DOF)
leorolim Junior Member • Posts: 32
Damn! It works!
Uploading to youtube...
 leorolim's gear list:leorolim's gear list
Olympus Stylus Verve S Fujifilm X10 Canon EOS 450D Canon EF 35mm F2.0 Tamron SP AF 11-18mm F/4.5-5.6 Di II LD Aspherical (IF) +2 more
savaytse66 Forum Member • Posts: 76
Here is result:
Very happy
Can I assume that you have to have the camera connected to the computer in order for this to work? I did not see any documentation, and I did not try it. If so, it really limits the usefulness, although I don't put a whole lot of value in shooting video from an SLR anyway. Pretty cool, nonetheless.
Chris
guinness2
guinness2 Veteran Member • Posts: 4,501
Guys, be warned, download an exe from unknown source can be very dangerous.
Adlika, I know you mean it fine, the site looks also quite safe, but please, if you uploaded it there, try to publish also some checksum, for example md5sum , otherwise someone can tamper it.
No offense ..
Here is result:
Very happy
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
2 scans with Kaspersky IS 8 came out clean
Yes, you must have your DSLR conected to the pc.
leorolim
http://flickr.com/leorolim
Eric E W Regular Member • Posts: 177
Live view... what about 1000D, 40D, 1D(s) Mk III?
So it's basically capturing the same stream as the "live view" and saving it to a file. I wonder if this would work with the other live view cameras like the 1000D, 40D, 1D(s) Mk III?
I'm sure that this will probably have the "Jello Motion" artifact, but it's still a very neat trick.
Afzal Ballim Regular Member • Posts: 222
Re: Live view... what about 1000D, 40D, 1D(s) Mk III?
It may not be all that useful for "real" video, but this may well be the start to an answer to a question I had on using the 450D for stop-motion animation (see this thread http://forums.dpreview.com/forums/readflat.asp?forum=1031&thread=30753846 ) without destroying the mechanical shutter.
Now THAT is interesting!
Canon EOS 450D
Canon EOS 1D
17-35 F2.8 L USM
28-80 F2.8 L USM
70-200 F2.8 L USM
50 F1.8
18-55 F3.5-5.6 is
http://www.ballim.com
kodakoid Forum Member • Posts: 99
Hi. Thanks for posting the link. I've tried it on my 1000D and it works fine.
I tried a couple of clips and uppd them to youtube, but the divx compression ruined them
Anyone got the videos playing faster than real time? Like in fast-forward?
http://www.youtube.com/watch?v=Nxps2He2Ktw
http://www.youtube.com/watch?v=_UkPOgyt-AQ
http://www.youtube.com/watch?v=OaMqgAw2VEU
leorolim
The high-quality versions were quote nice and clear. Yes they were going in FF, probably because they were tagged with the wrong framerate.
jkenny23 Regular Member • Posts: 139
The video has a bit of an erratic framerate when I tried it as well, not sure if converting the video might fix this or if it's just a problem with the program. Either way it's still pretty neat to play around with.
Try more light / fast lens. I bet it needs to be at least 1/framerate to be "realtime" rather than FF ( at least until they fix the program ).
the program ).
That seems a little closer to the truth after I tested again: In apeture priority mode, it would switch to different apetures to try and maintain the shutter speed? If I pointed it at something bright it would switch apetures and in the video there would be a little break/discontinuity for a half second or less.
In manual mode, if I set the apeture/shutter speed, that's what it is for the whole video. Thus, I set it to 1/25 second to match the 25 frames per second that the video information showed, and it seemed pretty consistent. So how the software handles exposure is a little mysterious, but you can at least get a pretty consistent output by setting the exposure beforehand in Manual.
Here is author link at forum.ixbt.com:
http://forum.ixbt.com/topic.cgi?id=20:26019
It's in russian
NOW with AF
Author has changed program - now we have AF with * button (similar to 5d-2)
Here his web site translated with google:
http://translate.google.ru/translate?prev=hp&hl=ru&u=http%3A%2F%2Fvalexvir.narod.ru%2F&sl=auto&tl=en
ledittmar Veteran Member • Posts: 3,495
another translation
Leon S Forum Member • Posts: 68
My test results
Thank you! It works!
The following was recorded at night inside the house. I don't know how to upload to youtube with high quality though.
Camera: XSI/450D
Lens: 70-200mm/4 IS
http://www.youtube.com/watch?v=nUUGNpV-nuM
G Honis Forum Member • Posts: 67
Another 450D Video test - Blue Jays
I am getting a capture rate of 25 frames per second now with version 1.2 of the software. The author has added some nice features to this free software. Took video of blue jays with an astro modified camera using a color correcting filter on the camera lens and posted it on Youtube here:
http://www.youtube.com/watch?v=shCCacbqa_s&fmt=18
The original video is much better than the video displayed on Youtube. It was my first time posting to Youtube. Never expected to be taking video with my 450D! Should come in handy for planetary, lunar and solar imaging:)
Gary Honis
