G1 + 4/3rds adapter + Hexanon 40mm f1.8
Started Jan 13, 2009 | Discussions
Brian Mosley Forum Pro • Posts: 20,710
Inspired by Karl's beautiful post of his G1 + Nokton 40mm f1.4 here :
http://forums.dpreview.com/forums/read.asp?forum=1033&message=30651429
I had a quick play with my Hexanon alternative this afternoon... you would be shocked how cheap these beautifully sharp lenses can be found on ebay - just search for Hexanon AR.
Here's how it looks mounted - ultra compact
And here's a shot with it wide open - not too sharp but fine for portraits and low light work... and this lens is extremely sharp from f4 onwards.
1/125s f/1.8 at 40.0mm iso250
Kind Regards
Brian
Preview Exhibition Book One here :
http://www.blurb.com/bookstore/detail/522280
Join our free worldwide support network here :
http://www.ukphotosafari.org/join-the-ukpsg/
 Brian Mosley's gear list:Brian Mosley's gear list
Sony RX1 Sony RX100 IV Olympus E-M1 Fujifilm FinePix X100 Olympus OM-D E-M5 +1 more
kernow Forum Pro • Posts: 12,441
Re: G1 + 4/3rds adapter + Hexanon 40mm f1.8
How much did you shim the Hexanon? I am using 2mm overall but I suspect it isn't necessary to be precise unless you want exact register distances.
Oll an gwella,
Jim
[LX1]
[FZ30] * IS/L B-300 * IS/L B-Macro * Minolta No. 0, No. 1 & No. 2 * Sunpak 383 * Benbo Trekker
[L1] * Olympus 25mm 2.8 * Hexanon 40mm 1.8 * Vivitar Series 1 135mm 2.3 * Tokina 500mm 8.0 *
OP Brian Mosley Forum Pro • Posts: 20,710
Ultra sharp results at f4...
This is from a burst of 5 shots at ISO 800, f4, 1/10sec handheld... combined in PhotoAcute to create a superresolution, noise free image.
Kind Regards
Brian
Exactly 1.5 mm I think. /nt
Re: Exactly 1.5 mm I think. /nt
Brian Mosley wrote:
OK, that must mean you used a single shim on the flange side rather than shimming the back of the flange as well. That is how I have mine done now but I am going to see if adding the .5mm shim improves things.
Oll an gwella,
Jim
ASR45
ASR45 Forum Pro • Posts: 37,028
Looks good brian,
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Canon EOS 5D Mark IV Canon 6D Mark II Nikon AF Nikkor 80-400mm f/4.5-5.6D ED VR Canon EF 70-300mm f/4-5.6L IS USM +8 more
m3
m3 Contributing Member • Posts: 945
Re: Ultra sharp results at f4...
Please DO explain ...
 m3's gear list:m3's gear list
Nikon AF-S DX Nikkor 18-140mm F3.5-5.6G ED VR
MaineTim Veteran Member • Posts: 3,086
Looks great, Brian...
I'm hoping mine will be here by the weekend, then we'll break out the jeweler's tools and see what's what. Any hints from you guys as to hidden traps when disassembling the lens?
Tim
http://mainetim.zenfolio.com/
Tips...
Hi Tim,
just be sure to use brand new, high quality screwdrivers... they need to be very sharp.
When you're unscrewing the screws, use the minimum downward force necessary - the threads are very fine, and the screw heads are soft metal - so if you press down too hard and turn the screwdriver you will charlie the screw head.
Make sure you have a large well lit flat space and work gently + slowly.
Did you google the Snaar website? Pete has some great instructions there.
Good Luck! email me if you get stuck
Kind Regards
Brian
Thanks...
for the tips, Brian. No, I hadn't seen that site, great info. I had looked at the fourthirdsphoto article on it. My biggest concern is just what you warned about, the removal of those screws. That's where it always seems to go wrong, so I'll tread carefully. Hard to believe clean copies of this lens can be had for as little as $10. I wish Nikon MF stuff was priced like that.
Tim
KZ3 Forum Member • Posts: 92
Re: Tips...
I have a few Hexanon lenses, where can I get the shim from?
Jose Garzia
Dave Lewis Forum Pro • Posts: 10,425
Looks plenty sharp to me. I have one of them and a 50 mm 1.7 neither of which I have gotten around to adapting. Wish someone did them professionally. I would ship them off to them.
Dave Lewis
Re: Thanks...
I watched the prices of that lens go up to more than $50 for a while after a couple of these threads last winter. Folks listen and put the pressure on ebay.
dave
Tim
Dave Lewis
Re: Tips...
Jose Garzia
If you mean the raw stock, most hobby shops stock brass sheet in various thicknesses. There are no ready made shims available, each is a custom job.
Oll an gwella,
Jim
Re: Looks great, Brian...
Tim
Mark the orientation of each part as you disassemble the lens. I had no trouble with the screws, if a screw is stubborn, try turning it the opposite way as though tightening, it will usually break loose. I press very hard when removing the screws as it keeps better contact with the screw head. The aperture ring will be free to fall or get knocked off once you remove the chrome flange, there is a small detent ball bearing being pushed on by a leaf spring that can shoot out. It is easy to put back in but not easy to find. Leave a lens cap in place whilst working on the lens, a plastic bottle top can protect the rear element.
Oll an gwella,
Jim
Lamprecht Contributing Member • Posts: 864
Is there no off-the-shelf adapter which will fit to the 4/3rds systems without having to go through all this work?
Richard
Richard
For 4/3 it would have to be only 2.0 mm thick, so not possible. However it is possible someone might make one for the m4/3 camera.
Oll an gwella,
Jim
m4/3rds adapter is a very good possibility.
The Hexanon AR lenses have remained extremely good value so far, due to the need for DIY modification - a m4/3rds adapter would be awesome.
Recommended lenses
21mm f4
24mm f2.8
35mm f2.8
40mm f1.8
50mm f1.4 or 50mm f1.7 sharpest
57mm f1.4 or even better 57mm f1.2
85mm f1.8
135mm f3.2 or 135mm f2.5
Kind Regards
Brian
Goffen
Goffen Veteran Member • Posts: 3,301
That extra shim.
Improves nothing, but you might get an exact infinity focus @ the end of the scale.
You will however always be able to get to infinity without it.
Goffen
 Goffen's gear list:Goffen's gear list
Panasonic Lumix DMC-GH1 Olympus OM-D E-M5 Pentax K-30 Olympus E-M1 Panasonic Lumix DMC-GM5 +13 more
And with the G1...
You get perfect focus confirmation via the EVF anyway - I'd keep it simple and forget the inside shim.
Kind Regards
Brian
