Re: Most go with a simpler setup
dylanbarnhart
wrote:
Most wedding pros don't use external flash or softboxes at all.
???? Where did you get THAT information !!
I
have only seen enthusiasts do it. It's rather complicated to setup
such a remote flash, as the bride and groom are mobile, and there
might not be a place to set it up. At today's cut-throat pricing, it
doesn't make sense to share part of your income to an assistant.
Even with an assistant, it's hard to hold the softbox without
disturbing the wedding in some ways. Heck most churches don't allow
flash at all.
You can use remote flashes controlled from camera very easily, no assistant neccessary. Most professional wedding photographers are pretty damn good at co-ordinating when and where they use remote flash without interupting proceedings and that doesn't mean it needs to be used in church.
Softboxes are useful for the formals. That's about it. Other than
that, bounce whenever there's a low ceiling, or bump up the ISO with
the F1.2 prime otherwise.
Disagree. My 1.2 is a 50mm - far too long for general use - and you don't list one in your plan, so how do you manage?
I brought along my remote flash to the last 7 weddings, and could
only used it once.
Theres no rule saying that you have to use it. They serve a useful purpose when you need them or when you need an improvement over whatever you already have. Good photography exists side by side with good lighting. Lighting is more important than even cameras or lenses.
The OP wanted:
'Just trying to see what is the workable solution, before I empty my pockets.'
This requirement consists of a system capable of working at the basic level of a flash on camera through high speed sync to high output formals. This can all be achieved, but it will empty your pockets, so best to do it slowly and correctly.
After spending many months
years solving this problem I use Lumedyne and Quantum lighting with radio controlled remote lights (or just radio fired) with even studio strobe fired by the same system. The solution is totally scaleable, versatile and includes softboxes, grids, umbrellas and reflectors.. off camera flash makes a considerable improvement in the vast majority of situations.
