Foveonizator (Was: Bayer - Foveon comparison)
Started Nov 26, 2008 | Discussions
jtra Contributing Member • Posts: 948
Hi all,
several people have asked me to get the code for the color transformation from "canon 50d" colors to "foveon" colors which I did here:
http://forums.dpreview.com/forums/read.asp?forum=1027&message=30123905
I originally had my code written in Ruby language using RMagick library, but it was quite slow and it could be hard to set up. Now I have something better to play with.
Download Processing 1.0 from http://processing.org/
(I use it on Linux, but you can use it on Windows or Mac too).
It is a cool tool for scripting images, animation and interaction.
... and paste this script in the code pane:
http://jtra.cz/download/foveonize1.txt
Save with "File-> Save as" so that you know the directory where to place input file, then click Run icon.
It will read input.jpg from current directory, display a portion of transformed image and saves full transformed image into result.jpg
forceofnature
forceofnature Contributing Member • Posts: 725
Re: Foveonizator (Was: Bayer - Foveon comparison)
Thanks for the Link. Looks like an interesting tool. I too use Linux so its nice to see all the linux tools.
Proud Pentax K10D and Hayabusa Owner
 forceofnature's gear list:forceofnature's gear list
Sony a7R II Sony a9 Sony FE 24-70mm F2.8 GM Sony FE 90mm F2.8 macro Sony FE 16-35mm F2.8 +2 more
LMC54 Forum Pro • Posts: 11,808
Kinda like putting stripes on the bonnet of a hummer and saying it looks almost like a Mini Cooper.
Larry
miketuthill Veteran Member • Posts: 3,228
Speaking of being offensive!:-)
Larry
 miketuthill's gear list:miketuthill's gear list
Sony a7 II Sony a77 II Tamron SP AF 90mm F/2.8 Di Macro Sony FE 28-70mm F3.5-5.6 OSS Sigma 105mm F2.8 EX DG Macro +14 more
John Sheehy Forum Pro • Posts: 21,735
jtra wrote:
Hi all,
here:
Might as well go all the way and simulate the spatial sampling as best as possible.
In Photoshop,
1) Take a high-MP Bayer or "foveonized" bayer image and upsample (NOT nearest
neighbor) to 7920*5280.
2) Downsize to 5280*3520 with nearest neighbor.
3) Pixelate|Mosaic to 2x2 tiles.
4) Downsize to 2640*1760 with nearest neighbor.
Now you've got a close look to Sigma sub-sampling. Works well with the 50D and its weak AA filter.
John
oluv Senior Member • Posts: 1,973
examples, examples please
 oluv's gear list:oluv's gear list
Panasonic Lumix DMC-GM1 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +1 more
alisD Contributing Member • Posts: 627
I never knew
photography could be so super duper exciting!
my makeshift collection of photographs:
http://www.flickriver.com/photos/nome_alice/
Re: I never knew
I never knew that some people would consider an image with missing content as being better ...
John
Tiffles Veteran Member • Posts: 4,975
Re: I never knew
 Tiffles's gear list:Tiffles's gear list
Sigma DP1 Sigma DP1 Merrill Sony RX1R Nikon D700 Sigma SD10 +7 more
Re: I never knew
Tiffles wrote:
Never heard of minimalism?
I've heard of it, but it is a style, an effect, not a quantitative quality.
John
yvind Strm Veteran Member • Posts: 4,130
Re: I never knew
What about "Less is more"?
quality.
Re: I never knew
Re: I never knew
It's a figure of speech, which makes sense in some contexts, but makes no sense in others. If you need less, you can always drop something later. You can't get it back later if you drop it from the beginning; IOW, you can't get the space between the Sigma subsamples, once they have been taken.
John
wrong
it's a qualitative quantity.
...and you're just making photography even more boring with every post.
Re: wrong
My posts here have nothing to do with photography per se. They have to do with imaging.
You know absolutely nothing about what I think about photography from this and many other threads.
This is ridiculous, really, if you drop your biases and step outside and look in. Someone started talking about how the 50D has "resolution" but not detail, which they said were different. Yes they're different, but they're different facets of the same thing. That person was completely FOS.
I showed how the 50D did, in fact, have a lot more real detail than it was originally credited for. I also suggested a method to make the 50D or similar bayer camera get a sigma-esque look, and certainly enough, it involved losing detail, and part of the witness of the focal plane.
You can always do interesting photography with a poor imager, and boring photography with a perfect imager. That has never been a point of debate with me.
John
Truman Prevatt
Truman Prevatt Veteran Member • Posts: 9,072
Take an analog signal, f(t) and take its Fourier transform F(w). Now take the signal g(t)=f(t+s) where s is either and advance (s> 0) or delay (s
The same thing holds for digitized images, but the concept is easier to see in one dimension. Therefore, an image can be calculated for any pixel location. This allows a side by side pixel layout to be used and to shift the locations so each RGB channel are effectively sampled on the same grid, not offset grids like the CFA. This in effect provides a "Fovenized" image from a CFA. Of course this needs to be done with the RAW prior to demoasizing. Take for example a 20 MP CFA. The lowest sampling is the R and B channels of 5 MP each. Take 5 MP of the Green and shift all the R, G, B channels to the same spatial grid and you have an 15 MP Foveon, or 5X3.
The reason it isn't done - it quite computationally expensive processing. But in theory it is not difficult.
 Truman Prevatt's gear list:Truman Prevatt's gear list
Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R XF 90mm +9 more
