Nitrogen Filled Lenses - Why Not?
Started Nov 20, 2008 | Discussions
I Beam Veteran Member • Posts: 3,492
Good quality binoculars and scopes are usually filled with nitrogen. As far as I know no camera lenses are nitrogen filled. Some pro lenses have dust and waterproof rubber seals but but these are at the mount only. Nitrogen would make a lens waterproof, dust proof and mould proof.
I realise that a lens would need to have internal focussing and that it should not change length when zooming. So why are some of the zooms such as the 70-200VR and pro level primes not nitrogen filled?
Regards
Paul
Nikko aus London Senior Member • Posts: 1,219
Re: Nitrogen Filled Lenses - Why Not?
It leaks out.
 Nikko aus London's gear list:Nikko aus London's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 8mm F1.8 Fisheye Pro Olympus 12-100mm F4.0 +1 more
Genix Senior Member • Posts: 1,444
Not to mention that the refractive index inside the lens changes.
Binoculars have to be "close enough". Lens don't have that luxury.
maljo@inreach.com Veteran Member • Posts: 8,002
Air is 80% Nitrogen
100% Nitrogen gets rid of the oxygen.
Is oxygen a problem for lenses?
maljo
 maljo@inreach.com's gear list:maljo@inreach.com's gear list
Olympus E-M1 Nikon D500 Nikon D850 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R
parisphotog Senior Member • Posts: 2,074
Did you mail Nikon and ask them?
mould proof.
Regards
Paul
David Rosser
David Rosser Veteran Member • Posts: 3,491
Nikko aus London wrote:
It leaks out.
Hasn't leaked out of my Leica Scope.
Dave
http://www.rosser.pwp.blueyonder.co.uk
http://www.pbase.com/dgrosser
 David Rosser's gear list:David Rosser's gear list
Panasonic Lumix DMC-LC5 Sony RX100 III Nikon D40 Fujifilm X-Pro1 Fujifilm X-Pro2 +10 more
David Rosser
Re: Air is 80% Nitrogen
Nitrogen is inert, oxygen reacts with all sorts of things (and yes even with Nitrogen to form Nitrous Oxide but only at the very high - 2000K - temperatures you get in the primary zone of a jet engine combustion chamber), far better to eliminate internal corrosion posibilities by not having any oxygen.
maljo
David Rosser
Don't see what you are getting at surely refractive index between known nitrogen lens surface interface is going to be as consistent as between air and lens.
Dave
String
String Senior Member • Posts: 2,199
Its my understanding (and I could be completely wrong here) that any zoom lens still needs to have a "vent". As the zoom mechanism is moving, its drawing air into the lens/letting air out of the lens so the only lens you could do this with would have to be a prime.
 String's gear list:String's gear list
Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 75mm F1.8 +4 more
It is - however, unless you seal against leakage, over time air (78/21/1
N,O,other stuff) will replace the N in the cylinder, changing the refractive
index. I don't want to pay the extra for the seals, when what we have
works now.
Bob GB Senior Member • Posts: 1,826
The reason is it is not feasible. In a binocular, the construction is simple enough so it can be made relatively gas tight. For a camera lens, this is not possible to achieve. Most camera lenses are far to complicated to make gas tight, particularly for zoom lenses. There are so many moving parts and internal volumes that changes size that it would be prohibitively expensive and partly impossible to make everything air tight. In addition, I would expect the resulting frictions with a number of o-rings to be excessive. The important part of filling with nitrogen, is that they get rid of moist, so read: dry nitrogen.
And no, the refractive index will not change when altering the internal gas mixture.
David Rosser
I think you are right here as Scopes and bins are fixed focal length devices - all the zooming in variable magnification scopes takes place in the (interchangable) eyepiece.
James Sherman
James Sherman Senior Member • Posts: 2,480
With lenses that don't grow while focussing all they need is internal venting from one space to another within the lens to prevent turning them into "optical shock absorbers". But I agree that over time, due to zoom ring movement and focus ring movement they'd leak. No such thing as a perfect seal on a moving object (at any affordable price anyhow).
Jim
 James Sherman's gear list:James Sherman's gear list
Samyang 7.5mm F3.5 Fisheye Olympus E-M1 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +1 more
Outbacker Regular Member • Posts: 245
No, good sealing would do that. What gas it's filled with makes no difference. Dry air is commonly used for some critical optical assemblies, such as laser rangefinders and thermal imagers.
Cheers
