K20D, don't like cold temperatures?
Started Nov 15, 2008 | Discussions
devisor Senior Member • Posts: 1,804
Ok, I have noticed this problem before with my k20D, but resolved it with taking a few long exposure pictures.
When I'm shooting in cold weather.. like today.. (2celcius).. the k20D produces some strange paterns on the images..
this image, in example:
and here is a 100% crop
Looks like its a bad newspaper print.
Has anyone had any simelar problems with the k20d, and found a fix for it?
Pentax K20D| DA* 16-50 F2,8 lens | DA* 50-135 F2,8 | FA 43 F1,9 Limited | I need more | Fuji s5600 | AlienBees | emfphoto http://www.emfphoto.no | fotofashion http://www.fotofashion.no |
viking79
viking79 Forum Pro • Posts: 14,156
Re: K20D, don't like cold temperatures?
It it only in some of the prints? If so it is likely RF interference from a cell phone, or other nearby transmitter. It happened to me when I was by an FM station that was broadcasting out of a truck.
http://www.flickr.com/photos/28177041@N03/
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Joseph Tainter Forum Pro • Posts: 11,359
This is vertical pattern noise. I did not know that it could be triggered by cold. I don't know why cold would affect it this way. Could it be that the cold has drained the battery? Or could the camera be defective?
It is a mystery to me.
Joe
leopold Forum Pro • Posts: 14,083
Hi,
i don't have a K20D but with my DS2 i took many times photos outside in temperature between - 20°C to -35°C without any problems for over 2 hours.
Leopold
Pentax forever
http://smarcoux.zenfolio.com/
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm F4L USM Fujifilm XF 14mm F2.8 R +3 more
OP devisor Senior Member • Posts: 1,804
its to me to..
dont think it is any mobile or RF that do this.. I have taken nature shots in the cold and have this patern show up. It also show up when I use my light setup (skyport trigger)..
But it newer shows up when the air is warm. Really strange.
btw.. can't think it is my memory cards either (tested with 3 cards, same thing). And I use battery in my grip. Both was on full power today.
tcom Veteran Member • Posts: 7,496
No problem here with K20D at -20°C
I used the K20D by -20°C without any problem
Dominique
http://www.pbase.com/tcom
 tcom's gear list:tcom's gear list
Ricoh GR III Pentax 645Z Nikon D5 Fujifilm GFX 50S Sony a9 +18 more
Re: No problem here with K20D at -20°C
a other shot that got wastet
100% crop
skinja Regular Member • Posts: 222
Grip or no grip
Some time ago heard about similar issues with the K10, it had something to do with the grip. If the grip is off the camera do you see the same issue? Do a search and see if you can get any history on the k10 with similar issues.
Good luck and please post your results.
John
artphoto Regular Member • Posts: 285
Re: Grip or no grip
John
I am with John on this.I didn't have any issue with my K20D in any weather but the grip proves to be troublesome when used with my K10 last year.Also,do you have the latest firmware installed on your K20 or the original firmware??
artphoto
Re: Grip or no grip
latest firmware.. I have also tested this without the grip.. Same problem..
Think I'll try to reflash my cam.. hope that helps. Don't have time to part with my camera:(.
steelski Senior Member • Posts: 2,555
Re: Grip or no grip
problem..
I would notify Pentax and ask for a replacement as this is not acceptable.
I would test the new one when it arrives. I will test my K20D in the fridge as this could prove troublesome, I have not been on a cold shoot yet. I am very sorry this has happened to you. Obviously if the problem resolves itself when the chip warms up then its a hardware issue and should be withing the tollerance levels.
Others have said that this is VPN, Its not. VPN is a K10D only phenomenon which I also experience and looks nothing like the stripes you have. Hopefully its something they (Pentax) can resolve. I am so sorry your work was wasted like that. And on Good pictures too.
Re: Grip or no grip
thx.. problem is that I bought from bh, and I'm in norway.. Pentax Norway will demand that I return the camera.. meaning I have to rent a other camera in the meantime.. Heck I earn some good cash with it, thats why I don't have time to part with it.
Re: Grip or no grip
oh well..
flashed my camera again, testet with and without the grip. Same problem, tryed also with 4 different memcards.
best solution for now is to use the live view to warm up the camera.
photorenes New Member • Posts: 6
Re: Grip or no grip
or go to a warmer country, your models would like that too!
I have the same issue when shooting at iso 800 with my k10d.
steephill Veteran Member • Posts: 9,861
Checking temperature
The exif data contains the temperature of the camera at the time of shooting. Photome can show this data. This would let you see if there is any correlation between temperature and pattern.
Re: Grip or no grip
I tested iso 100, and DN 200, 400.. same problem.
I guess it should be replaced.
Russell Evans Forum Pro • Posts: 12,617
Re: Grip or no grip
Your camera has a mechanical issue, either shutter or electronics. You are going to need to return it, or you are going to need to send it in for repair.
In the US, we tend to expect a vendor to work with us in resolving an issue. With this said, I would give B&H a call and explain the issue, provide some samples, explain that you are using the camera for paid work, and see if they can work with you on getting you a new camera body while you still have work with the old body. They might want to charge a credit card a deposit, for insuring the return of the defective body, or maybe not. In any event, giving them a call won't hurt.
Thank you
Russell
Re: Grip or no grip
yeah.. the problem is that I bought it from BH, so I don't have any support here in norway.. (well I have international serivce tough)..
I'll try that routh with bh,, thx:)
ManuH
ManuH Veteran Member • Posts: 3,898
The pattern is extremely regular, I would guess a defective electronic componant. It will need a trip to the repair shop.
Manu
sfa1966
sfa1966 Veteran Member • Posts: 3,474
I think Viking could be right (link)
See this old thread ...
http://forums.dpreview.com/forums/read.asp?forum=1036&message=24730963
sfa
A very limited photographer ...
 sfa1966's gear list:sfa1966's gear list
Sigma DP1 Sigma DP2 Merrill Pentax K-3 Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited +11 more
