Just got an 8.2
Started Oct 1, 2008 | Discussions
tashley Veteran Member • Posts: 4,189
Just got an 8.2
and within three hours will be able to put some glass on it and give it a going over. I'm particularly interested to see if there are any minor improvements over the 8.0 at higher ISO and will test that today.
How very exciting!
And if anyone else is after one, Richard Caplan in London has three or four left - as well as some brand new old style nocti stock.
Yum!
T
Gallery: http://tashley1.zenfolio.com/
TEBnewyork
TEBnewyork Forum Pro • Posts: 11,337
Re: Just got an 8.2
Hey Tim,
I'm curious to see what you think. I currently have 2 bodies and have been trying to decide what to do with upgrades vs. M8.2 vs. leave well enough alone
Did you get a black paint version?
Good luck with it....
terry
http://tbanet.zenfolio.com/
Stovall Veteran Member • Posts: 3,063
Re: Just got an 8.2
Keep us informed as to how it goes. I've been thinking about getting one late next year and keeping the original for the higher shutter speed. I could then sell my RD-1 which is a backup rangefinder then.
'No matter how capable it may be, any camera you have to hold out in front of you like a tourist is not cool.'
Dean Forbes
Peter Veteran Member • Posts: 4,303
Re: Just got an 8.2
today.
nice to see you back sir! Any Iso improvement would be the same offered by the 2.0 firmware in the original M8, and it does not appear there is any, unfortunately. Still, I'll be curious to see your findings. Enjoy the new camera.....Peter
http://www.innerimager.com
OP tashley Veteran Member • Posts: 4,189
Re: Just got an 8.2
Hi Terry,
Yup, I got the black - it's nice! And thanks!
TEBnewyork wrote:
Hey Tim,
well enough alone
terry
Re: Just got an 8.2
Hi John,
I just used the filters in Lightroom to tell me how many shots I've taken on two M8.0 bodies, and what percentage of those are taken at 1/6000th and 1/8000th second and the answer is that 1.25% were... so I'm not sure how vital those extra speeds are. But it's always nice to have the option!
Re: Just got an 8.2
Hi Peter, hope you're well!
I'm not sure you're right, but I'll post the reasons for that in a High Iso comparison post later in the thread.
Best
Tim
today.
M8.2 First user impressions
OK, so I've taken seventy five shots so of course I have unassailable opinions.
I wandered around a local museum today with my trusty 50 Lux - a lens I know to be correctly calibrated on two other M8s that i came to trust. It's the canary in my mine shaft and the first point to make is that, with this lens at least (and I take this to be a very good omen) focus appears perfect. Phew, no return to Solms - not for that reason at least!
Second point: the very first frame I shot was a de-focussed shot of the sky at F16 in order to see if the sensor was clean. I rocket-blowered the back of the lens first and put it on the camera with the sensor facing the ground.
The sensor was filthy. If 100% of expectation were no dust at all and 0% were an appearance that looked like someone with a heavy cold had sneezed on it, it was about a 75%, which is not good enough. I spent 100 quid on sensor cleaning services and kit for my 1DSIII yesterday - it too has been filthy since it arrived - and I can't begin to understand why manufacturers think this is acceptable. Worse, I suspect that like the Canon, some of this is grease not dust.
As for the rest:
  • I really really really like the new shutter sound. It's not as quiet as my MP but it's in the same rough ballpark when in discreet mode. I also like that the shutter then re-cocks when you let go of the button. No time to forget you're not cocked, but the easy opportunity to keep the second part of the noise for when you can drop the camera to your side and cough.
  • I really really like the Auto ISO thing. I set it to max 1250 and min shutter of 1/30th and it did it's thing. I did not feel the force was with me in terms of super steady hands today so one or two were less than perfect and I'd rather see an option at 1/45th than having the next one at 1/60th but I do think that all other things being even, Terry is right to suggest that the less clunky shutter might sometimes save you up to a stop of motion. Nice.
  • The new framelines are a Godsend. So I only tried one lens thus far but I am actually getting results very close to what I see through the finder. That means less cropping (or less pre-emptive overly wide frame then crop) which in turn means you get more pixels - i.e. better resolution and less noise. Fab.
  • I initially hated the exposure compensation dial. It requires such a gentle touch of the shutter to activate it that the process of tightening one's grip on the camera to provide sufficient traction for stage two, the wheel turny bit, too often makes you press the shutter to the next level and you therefore can't make the adjustment. It's hard to describe. By the end of my stroll I was getting used to it but I'm still not totally convinced.
  • I quite like the new covering (paint and vulcanite) but I prefer the old faux leather. It doesn't grip as well as the new, but it's more matte; the new covering is a bit shiny and expensive looking. I like the black dot, but then I quite liked the red one
  • I will test this later when it's dark but I think the ISO 1250 performance might be VERY VERY SLIGHTLY less noisy BUT I haven't done a lot of higher ISO with my 8.0 since I put the new firmware on. So I'll try it later.
I have yet to try the snapshot mode (it offends me to even think of it!)
I have learned one useful thing: don't try to activate sensor cleaning mode while in Discreet Shutter setting, or the camera will lock up and require a battery removal. Daft. Fix it please. Though to be fair there may be mention of this in the manual, which I haven't read.
So, first thoughts, was it worth the dosh?
Hmm... probably. If you look at what you get with an 8.2 that you can't get with an 8.1 it's really just down to the separate shutter cock. That is, unless you want the new exposure comp system, which I wouldn't pay for, the snapshot mode which most of us here would never use (though I will investigate it as a quick route to auto ISO selection, for which purpose it might genuinely be useful) or the new paint, which is a refinement so subtle that I really wouldn't pay for it.
BUT I do street shooting from time to time so the delayed shutter cocking is a real boon. I can't stress enough how much I prefer it.
By the way, Caplan's told me that part exchange for an 8.0 is unlikely to be mroe than £1,000 (for now at least) so I think a trade in is NOT worth it. You drop too much cash. So only get one if you need/want a second body.
Forgot to mention: you lose things as well as gain:
  • Top shutter speed is now 1/4000th. I filtered Lightroom metadata and 2.1% of my thousands of M8 shots were taken at 1/6000th or 1/8000th.
  • Flash sync drops from 1/250th to 1/180th. I don't see a problem there.
Any questions, just ask. I'm off to look at the higher ISO performance.
Tim
Alex Leach Senior Member • Posts: 1,041
Re: M8.2 First user impressions
  • it too has been filthy since it arrived - and I can't begin to
Yep, my new M8 had many specks of shutter oil on it.
Irakly Shanidze
Irakly Shanidze Veteran Member • Posts: 6,374
Re: Just got an 8.2
b@stard!!!!!!!!
Irakly Shanidze
http://www.shanidze.com/en
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Contax TVS Digital Leica M9 Leica S2 Sony Alpha a99 Leica M10 +18 more
High ISO comparison with 8.0 with FW 2.00
Right, scientific-ish but not perfectly so. Same lens, same exposures, same scen, very slightly different framing. First the scene as shot on the 8.2 at 1250 with a 50 lux at F2, shutter 750th
Now for some crops:
First the 8.2 at ISO 2500, 1500th sec
Now 8.0 FW 2.0 at ISO 2500, 1500th
Now 8.2 at ISO 1250, 750th sec
Now 8.0 FW 2.0 at ISO 1250, 750th sec
I leave you to draw your own conclusions but I would say that the 8.2 certaianly in all the shots I took got much closer to the correct AWB in this mixed tungsten and halogen.
Re: Just got an 8.2
Irakly Shanidze wrote:
b@stard!!!!!!!!
Oh yes. And the shutter is soooo quiet that I can wear outrageous clothes and not get noticed. No more bag-lady look for Timmy.
Irakly Shanidze
Re: High ISO comparison with 8.0 with FW 2.00
I agree abut the AWB, but see no difference whatsoever with noise level/structure.
I WANT ONE NOW YOU BSTRD!!!!
Irakly Shanidze
Irakly Shanidze
Re: Just got an 8.2
even the red handkerchief???
Irakly Shanidze
Jim Radcliffe
Jim Radcliffe Forum Pro • Posts: 11,919
Tim..
Good to see you posting again. You have been missed.
Also, thanks for the update and personal experience on the M8.2. I am still holding out on the M8 but one day might bight the bullet.
Jim Radcliffe
http://www.boxedlight.com/dp1
http://www.boxedlight.com/dlux3
http://www.oceona.com
The ability to 'see' the shot is more important than the gear.
 Jim Radcliffe's gear list:Jim Radcliffe's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-H1
l_objectif
l_objectif Forum Pro • Posts: 21,401
Tim
Did you check to see if it has the red dot?.... :))
Louis
 l_objectif's gear list:l_objectif's gear list
Leica D-LUX 3 Leica D-LUX 4 Leica D-LUX 5 Leica D-Lux (Typ 109) Nikon D300 +10 more
Re: Tim..
Thanks Jim!
I have to say that unless you're keen on shooting street in places where a quiter shutter might save you a fight (or unless you do PJ style weddings and the bride is jumpy) there seems to be little advantage. So on the bright side, second hand prices for M8.0 will be more affordable soon if you want to try biting that cherry - and aside from certain cosmetic and minor ergonomic differences, the IQ seems to be the same.
But as I've said to you before, you take great shots whatever you use!
Best
T
Jim Radcliffe
I know, I know, it hurts baby... shhh...
level/structure.
Irakly Shanidze
It has a black dot....
http://www.dalephotoanddigital.com/_e/Digital_Rangefinders/product/799429107116/Leica_M8_2_Black_Paint.htm
Dean Forbes
Edward in Chicago Regular Member • Posts: 473
great book collection - I must have about 50% of same...
http://www.pbase.com/edward_in_chicago/root
 Edward in Chicago's gear list:Edward in Chicago's gear list
Canon EOS-1Ds Mark III Fujifilm X-Pro1 Canon EOS 5D Mark III Leica M-Monochrom Fujifilm X-E1 +26 more
