G1 size: Detailed analysis with photos
Sep 14, 2008
Pana G1:
Leica M8:
Much of the criticism for the G1's size and the suggestions for how it can be made smaller are based on misconceptions IMHO. The critics almost always attack the hand grip and tilt and swivel LCD as the main contributors to the large size of the camera. While in reality, most if not all lenses will make the additional thickness added by the hand grip irrelevant. As you see in the illustration above, the grip adds about 8mm over the thickness of the body up to the lens mount level, the lens mount itself is protruding 5mm from the front of the body, there is no interchangeable-lens camera with a flat lens mount even the Leica M8's mount is not flat as you see in the 2nd photo above.
When the 14-45 is attached to the G1, the combo is about
117mm
thick, the lens alone is about 59mm long, when attached to the body 8mm overlap with hand grip protrusion, resulting in only 51mm additional thickness. Since the G1 is not a fixed lens camera, these 51mm should not matter to you, you can get the already available 25mm Olympus pancake or wait for the upcoming 20mm mFT pancake (photo in the next post), and if any of them adds less than 8mm thickness when attached to the body, you can complain about the 1 or 2mm that the grip is adding to the thickness of your combo (tongue-in-cheek, of course).
It is difficult to estimate how much thiner the G1 would have been, had it not had a tilt & swivel, the extra thickness due to swivel that you see above is about 5mm, but the LCD does not occupy all the rear area which is flat with the LCD, so if the camera had a fixed LCD, the internal & external parts benefiting from the extra thickness of the swivel would have to be pushed away elsewhere by the designer of the camera.
The biggest contributer to the thickness of the G1, is the EVF, about 11.5 or 12mm that are not shared with any other component. Personally I would easily accept a camera with nothing but a tilt & swivel LCD as my only viewfinder, many disagree, I know. But at least you now have an idea which part is contributing how much to the size of the G1. I have a Pro1 with a tilt & swivel LCD + EVF and I NEVER use the EVF, it just makes the camera unnecessarily more bulky IMO.
The other two dimensions (width and height) of the G1 are quite good, very close to my Pro1 or the FZ28 and actually smaller overall than the Leica M8 as you see in the comparison photos on the next post.
In conclusion if another G is made without an EVF to make it more rangefinder-like, the thickness can be made as small as 66-12=54mm + the lens length. Reducing the grip won't make a difference as no lens is likely to be of
zero thickness (unless you buy a P&S with an internal [retreating] lens). As for the tilt & swivel , having a fixed instead of movable screen could reduce 2 or 3mm -->
54mm - 8mm - 3mm= 43mm (body only meaningless measurement) not too far from the M8's 37mm, but the ergonomics of a design like the G1 is --at least for me-- much better than that of Leica M8.
