Output profile for Nikon Capture NX
Started Aug 27, 2008 | Discussions
Iliah Borg Forum Pro • Posts: 24,720
This profile does not waist space, nor does it clips colours - it is tailored to cover exactly the same gamut of colours Nikon designed in all current cameras. Profile may need further tuning - please report any issues.
First, you need to install it into the system, then to switch it on in NX Preferences, Color Management and check the box "Use this instead of embedded profile" and relaunch the application.
http://www.pochtar.com/NikonNX_out_Lstar_ICC4.icc.zip
NikonPhoto New Member • Posts: 8
Re: Output profile for Nikon Capture NX
Iliah, many thanks for sharing this, will give it a try out later today.
rhlpetrus Forum Pro • Posts: 25,776
Is D80 contemplated?
Thanks.
Regards, Renato.
http://www.flickr.com/photos/11435304@N04
OnExposure member
http://www.onexposure.net/
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
jwalker019 Senior Member • Posts: 2,601
any issues.
Thanks for posting, Iliah. I have an issue in using it, though: when I convert to sRGB at the end of the workflow (for posting on the web, etc.), the colors shift rather violently instead of appearing basically the same. Specifically, it almost appears I have changed the white balance several hundred / thousand degrees cooler.
What would cause that?
 jwalker019's gear list:jwalker019's gear list
Nikon D3 Fujifilm X-T2 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 24-70mm f/2.8G ED +5 more
OP Iliah Borg Forum Pro • Posts: 24,720
basically the same
Can you please send me a jpg with this profile, before conversion to sRGB?
Yes it is.
basically the same
sRGB?
On its way. I sent both the file with your profile and the result of converting to sRGB on my system.
Dear John,
But from the files you sent it looks like you are not converting to sRGB, but instead assigning sRGB to the image. Can you please describe the procedure you use to change the colour space for the case?
Iliah Borg wrote:
Dear John,
case?
Sure. In NX2, from the menu, choose "Adjust, Color Profile". In the resulting edit step, click "Convert to Profile" (default is "Apply Profile"), select the Nikon sRGB profile, use either "Relative Colorimetric" or "Perceptual" for rendering Intent, click "Use black point compensation". Pretty familiar with this process - this is the first time I've ever seen a color shift when using "Convert to Profile".
Dear John,
See this then
Iliah Borg wrote:
Dear John,
See this then
It appears you've demonstrated it works fine in Photoshop, which I'd already confirmed
I agree the effect I'm seeing is similar to assigning the profile in Photoshop, but that's not what I'm doing in Capture NX2. I'm clearly converting to sRGB and there is clearly a dramatic shift in color when I do. It's either a bug in my installation of Capture NX2 (that I've never seen before with any other profile) or a compatibility issue with the new profile.
jwalker019 wrote:
Iliah Borg wrote:
Dear John,
See this then
already confirmed
Just for grins, here are my screen shots:
Before:
After:
Only difference between the two is clicking the "on" button in the Color Profile edit step.
Dear John,
Lets say it was not your intent. Wnat NX is doing for you is a different issue, and it is assigning.
I was not able to replicate the issue in NX1, please see below:
Some OT here
Dear John,
On a slightly different, but probably rather important issue.
There is a reason why I do not make colour conversions in Nikon Capture, and it is because one can't control gamut mapping. In Photoshop you can do that easily, switching on gamut warning for the destination colour space, be it a printer colour space or sRGB or whatever. My conversions between colour spaces 90% of the cases start with converting to Lab space, as for me it is easier to use Lab controls to map the image colours into the destination colour space, using, of course, gamut warning as a guideline.
Iliah Borg wrote:
Dear John,
OK, some sort of incompatibility with NX2. It is even evident with Soft Proofing turned on: if I turn Soft Proofing "on" with the destination space as Nikon sRGB, the color shift is no longer apparent; however, if Soft Proofing is "off", as I usually operate with any other color space, the shift is there. Very odd - it appears NX2 does not "like" the profile - all others, including ProPhoto, Beta RGB, etc., work just fine - i.e., appearance is the same from end-to-end.
Dear John,
it
Have you tried any icc4 profiles with NX2? Any other Lstar profiles?
Iliah Borg wrote:
Dear John,
it
No, just the widely-available ones like ProPhoto, AdobeRGB, sRGB / Nikon sRGB, Beta RGB, etc. If you'll point me toward some profiles I could try, would be happy to do so.
xrdbear Veteran Member • Posts: 3,919
Just to say I've done eveything I can to replicate your problem with my copy of NX2 and I can't. No colour shift.
I'm using WinXP SP2
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
Pbase gallery Pictures from Isle of Skye
http://www.pbase.com/xrdbear
Dear John,
Can you try this one
http://www.color.org/sRGB_v4_ICC_preference.icc
I'm using WinXP SP2
I've since confirmed this doesn't happen on my Windows laptop, either, just the Mac
